Q8 $45-$50 with discount
Lii500 $18-$23
4x30Q $16-$22
All together $79-$95 depending on what discounts you manage to grab, Black Friday is just around the corner.
Biggest potential saving on that ($10) would be opting for a Ā±$7 on discount Lii non-LCD 4 bay charger (I got one for $5 recently), half speed and no analysis. If you are lucky with discounts you would come in just under $70.
Worth the extra for a Lii500 though.
Great News! ! BLF Q8 flashlight will be available on amazon USA soon. If you would like to order more, we have limited quantity promo codes(49% off)and the price would be the same as Group Buy: $40.
And If it is convenient for you, could you please spare a few minutes and help to share an honest review of BLF Q8 light on amazon? Here is the product link.
BLF Q8: Amazon.com
If any question, please feel free to contact.
Best Regards
ThorFire
Oh boy, phone issues and real things needed doing, to beat at night, and it all looked so peaceful (phone not getting emails, only some āupdateā marked things, so I did get some mails, and thought it was really not busy and was glad with that, have to do things before the real frost sets.
BUT seeing a lot of activity here, heck a new topic 312+ post about GT logo, and 416+ new posts in the GT topic, oh oh.
Here it seems better.
One things that popped out
This says a great deal about how dedicated you have been, The Miller. Itās impressive and very worthy of praise. You have gone the extra mile and continue to do so. Really. Itās rare in this day and age to see someone dedicated and helpful like you are. Your karma bank must be pretty dang full! So many people try to get by with the bare minimum but thatās not you at all. Thank you.
Has anyone found a heat conducting material that also lubricates for the threads between the head and cylinder? It could get a bit more heat out of the hot part.
I thought of heat sink transfer goo. But nothing that says it wonāt dry out or turn liquid. Drying out could be a bad thing. Liquid metal bad on the not drying out side.
Copper Grease/Copper Ease/Copper Slip would have good thermal conduction I would expect, not sure of its viscosity at high temperatures but its commonly used on the back of brake pads to dampen vibration and does not seem to melt and run out, so expect it to be OK at Q8 head temps?
I think all the same arguments that applied to the pages of electrical grease discussion pretty much apply to thermal grease but even more (more because for thin layers thermal connection is affected far less than electrical), and the conclusion then was, just get a good thin grease.
If we are looking for an aftermarket tail cover, Iād like to see one with enough room inside for a charging board. Iām fine with taking the tail cover off to plug in a USB cable. Some minor mods to the tail PCB and a TP4056 board and we would be well on our way to onboard charging.
Better make a tail cover that supports magnetic charging instead, that would make charging much easier since there will be no need to unscrew the cover to plug it in.
My first thought was that this is a genius idea. Around the house and even in the car it would be a quick way to charge it up and would definitely be quicker and cause less wear. My second thought was that battery banks have USB, but not inductive ports. Which means that you would need to carry a wireless charger as well if you were taking this camping for instance. My third thought is that the obvious answer to this is a product that I have not seen - a USB battery pack with a built in inductive charge pad.
[edit]annnnd like most of my ābrilliantā ideas someone else has already had it, done it, and posted a video on how to do it. Still going to work on it.[/edit]
I apologizeā¦ The thread is long, my memory poorā¦
I impulsively purchased 8 30Q batteries on eBayā¦ Didnāt pay attention, and they are flat topā¦ā¦I was a bit mad at myself, but this morning I popped them inā¦and the light worked ,ramped right up to Max outputā¦
But is there something I should worry about, am I forgetting something . The battery discussion was so long agoā¦.
Thanks
Tony
