home depot 3c triple $8
75 posts / 0 new
snakebite
snakebite's picture
spotted this looking for info on my similar side switch single.
might order a few for the hell of it.
3c triple
EasyB
Last seen: 1 hour 49 min ago
3×26500 in series, if they fit length-wise, connected to 3 XPL in series would make a bright light.
Lexel
Lexel's picture
Last seen: 2 hours 22 min ago
depends of the heatsinking, who knows hollow pill or other crap inside
202bigmike
Last seen: 1 min 59 sec ago
In this Defiant flashlights’ stock/factory form with it using x3 “C” cells , what needs to
be done to convert it to the use of a (x1) Li-lion 18650 Question
khas
For $8 I would definitely buy a couple, but not Home Depot around here Big Smile
sac02
sac02's picture
Last seen: 2 months 5 days ago
I know the description says, “casing material:aluminum” but I can’t shake the feeling that is wrong. I was looking at all the flashlights on the home Depot shelves last week and I would have bet money that it was plastic based on my memory (which has been known to be wrong from time to time, ask my wife). If it is plastic, forget any dreams of putting 3×26650 and 3x(any real well driven LED) in it.
202bigmike
I have one and it looks , feels and sounds—when you tap it— like it’s aluminum !
However of course keep in mind , there’s a saying “Looks can be deceiving “ .
sac02
sac02's picture
OK if you have one then your info is better than mine, I was just basing it on a very fuzzy memory of a light I didn’t even look that closely at. So I’m very likely wrong in this case. Carry on!
Pete7874
Pete7874's picture
Last seen: 19 min 12 sec ago
Probably nothing needs to be done, other than find something to fill the rest of the tube with since a single 18650 (or 26650) will have similar voltage to 3xC cell.
So on that note, what’s the easiest way to fill remaining space in the tube? Are there some adapters out there?
DIY pointers welcome.
ImA4Wheelr
Last seen: 1 week 5 hours ago
I'm using 2P 18650's with no issues or other mods.  Pretty nice light.  I pulled down my protype pics because I was worried others might copy them and there was some risk with the design.  Dchomak made a very nice version here.
Pete7874
Pete7874's picture
What kind of LEDs are in this light, does anyone know?
bikenber73
bikenber73's picture
Last seen: 15 min 25 sec ago
I grabbed 2 of these for Christmas presents. Good gifts for old people who cough at anything new like unfamiliar batteries.
dchomak
This light comes out every year about this time. In the past they have always been 850 lumen with the 3 emitters. Here is a shot of one I picked up a couple of years ago.
Notice that the emitter in the upper left is larger than the other 2. It looks like an XP-G2
When I do a search for the SKU# 1001396908 on the HD site I get 2 different hits. 1 for an 850 lumen light and 1 for a 1000 lumen light.
In the gift section in the stores they display the 1000 lumen one.
At the time I checked the 3 emitters and all 3 look like XP-G2’s Probably why the light is now rated at 1000 lumen
Pete7874
Pete7874's picture
Thanks. What is the beam pattern like? Im guessing somewhere in between a thrower and a flooder? Can the strobe be bypassed? Im guessing no.
dchomak
It is probably a perfect combination of the 2. This is the perfect gifting light for the non flashaholic.
beginner12
Just ordered 2 of these today at 12.88/ea and one of the $10 set which includes 150 lumen defiant light and a headlamp could not pass it up. Thanks Thumbs Up
snakebite
snakebite's picture
working on a 3d printed 2p 18650 cartridge for these.
stay tuned for the .stl and bom.
Gea2427
dchomak wrote:
This light comes out every year about this time. In the past they have always been 850 lumen with the 3 emitters. Here is a shot of one I picked up a couple of years ago. Notice that the emitter in the upper left is larger than the other 2. It looks like an XP-G2 When I do a search for the SKU# 1001396908 on the HD site I get 2 different hits. 1 for an 850 lumen light and 1 for a 1000 lumen light. In the gift section in the stores they display the 1000 lumen one. At the time I checked the 3 emitters and all 3 look like XP-G2’s Probably why the light is now rated at 1000 lumen
Awesome I will go check them out at my home depot looks like a nice light. Regarding the sizes of the led’s do you think those two smaller ones are the old production xp-g2’s and the larger one, the new production led?
beginner12
Just picked up ours from home depot today. I am just a noob but the light shines great. Its a good combination of flood/thrower. Even the little $10 lights were a good surprise. We can use the $10 ones and put them in the “Box Of Lights” for general everday use. And that would allow me to keep my better lights stored for emergencies. Great gift items. I will definitely be getting more while they last.
Pete7874
Pete7874's picture
Here is the 1000-lumen version:
snakebite
snakebite's picture
can you measure the id of the tube?
if 26650 fit a spacer dummy makes this more versatile.
Pete7874
Pete7874's picture
I don’t have calipers, so I can’t provide an accurate measurement. It looks to be about 1 and 1/32”, so about 26.2mm. The C cells are pretty loose in there and rattle away when the tailcap is screwed on. Maybe some 26650 cells would fit?
dchomak
There’s your answer.
There wouldn’t be room for a 2P mod, and I would worry about the strip on a protected 26650 shorting out if only 1 cell is used. You would have to make a spacer anyway.
And a 2P setup with 2 – 18650’s would have more capacity.
This is last years 850 lumen model
BROODMASTER
Last seen: 3 weeks 2 days ago
Hello, I bought this recent version of the light to gift to a co-worker but discovered a Husky 500 lm version with an XP-G3 that will better suit the use. So, what do I do? … test it! I was happy to see a Shockli 26650, 4200 mAh fits and pulls +7 amps at the tail end. Beam pattern has a lot of artifacts but the trifoil-shaped spill and long throwing, neutral white beam aren’t too bad.
My question is who makes the LED?
h
Pete7874
Pete7874's picture
What are you using for a spacer?
BROODMASTER
1/2” copper tube, w/ nibco caps and PVC insulator
h
sovereignknight
sovereignknight's picture
Last seen: 1 day 18 hours ago
I have the 850lm Defiant one. Looks like three Cree XM-L2 emitters. It’s ok for a “throw in the back trunk and use it for emergencies” kinda light. That’s about it. It’s build quality is very cheap. It’s bright for what it is but I doubt it really is the claimed 850lm. The light included three Defiant branded C cell batteries. The head is glued on so I’m not going to even bother taking it apart. I would not bother trying to mod such a light as you’d be better off spending your money on a more worthy project.
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x6 Sk68 modded 3 Nichia 319AT, 3 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, w/ Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x6 Lumintop Tool AA - x1  x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light - x1 Lumintop Zoom 1 - x2 Zebralight Sc700d
BROODMASTER
sovereignknight wrote:
It’s ok for a “throw in the back trunk and use it for emergencies” kinda light. That’s about it. It’s build quality is very cheap. It’s bright for what it is but I doubt it really is the claimed 850lm…
That’s the reason I buy them too. I replace the batteries with primary lithium AAs so the the light works when I need it.
I actually bought the 850 lm light you have but returned it because I didn’t see any improvement over my 3C DST.
One thing to note, this light and a 500 lm Husky I bought this year have modes, flashy good for emergency signaling. And this is an improvement over single mode lights previously sold. The best part is that they are CHEAP!
h
eas
eas's picture
Last seen: 1 month 1 week ago
Does anyone have teardown photos of the 2017 edition of this light?
mmalive
Last seen: 1 hour 58 min ago
Hey guys, I finally picked up the 1000 lumen version of this light. Anyway to MOD to accept 26650? BTW, I also have the Husky 650 lumen 3 D cell light. Again how to MOD? Please advise. BTW, if any of you do MODS and charge a labor fee I will hire a helping hand.
mmalive
FYI: HomeDepot listed a 1200 lumen version of this light. Can’t add it to cart though.
