Astrolux MF03 - new pictures + video
340 posts / 0 new
Mindaugass
Last seen: 11 months 2 weeks ago
Wow! Interesting.
Theodore41
Last seen: 4 hours 34 min ago
What about the cooling?
DENGOH
DENGOH's picture
Last seen: 4 months 1 week ago
I was thinking will it be mixing LED yesterday… what a Mr. hindsight I am.
Great! Flood and Throw at the same time.
cool i'll see you when you get there
djozz
djozz's picture
Last seen: 1 hour 3 min ago
A 30Klumen light must dissipate a huge amount of heat and care must be taken in getting it away from the leds. In the design pictured in the OP there is some nice deep fins (but only a fraction of the surface area needed to dissipate the close to 200W of heat, as all big-lumen lights this light needs to stepdown fast) but they neglected the most important thing with these power levels: spreading the heat over the body as fast as possible so that the heat can actually get to those fins (and further over the body). You need a heat highway and they made a bottleneck just under the leds. The result is unneeded fast heating up near the leds and shorter time in Turbo. In my view they can buy significant turbo-time if they sacrifice some finning near the led-shelf for body-material, like this:
Jtm94
Last seen: 3 days 10 hours ago
Interesting light… not sure where exactly it’s going, but it’s going somewhere.
Maybe they’ve found the secret heat dissipation we’ve all been waiting for. Shocked
Lexel
Lexel's picture
Last seen: 8 hours 47 min ago
as it has a 2S/4P battery compartment the active heat path at the base of the shelf has at least a diameter of 45mm, this is well enough to conduct 1000W of heat, the fins are really thick, no need to widen the head as you show
the LEDs wont be sittingh at the edge of the light like the X80, head is bigger and less LEDs, so they more more to center
JasonWW
JasonWW's picture
Last seen: 8 hours 39 min ago
This once sexy light just got a whole lot ugly.
How are you supposed to turn it on with an overhand or reverse grip with the light by your shoulder? This is how I use my L6, but this light has a weird finger cutout preventing this.
The ugly grenade style battery tube. The 4 ugly flat cutouts on the battery tube. The big, diagonal slices on the head. The screws holding the switch cover in place.
What happened to the sexy looks of the earlier MF01 and MF02? Did they hire the designer that Haikelite fired after he designed their MT03 and MT07? I see a lot of similarities.
I know they are trying to save weight by cutting a lot of material out, but geez, don’t turn it into a ugly monstrosity only a few will want to buy. So far these teaser pics make the Imalent it’s competing against look like a beauty queen.
IDK, I sure seem grumpy for some reason.
DENGOH
DENGOH's picture
Can we have options of 8 xhp35 hi?
Theodore41
The Acebeam X65 has five of them and gives 12,000 lumens plus 423,000 candelas.
M4D M4X
M4D M4X's picture
Last seen: 2 min 41 sec ago
we will see...
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
DENGOH
DENGOH's picture
Ya, imagine 16000 lumens 600kcd, continuously.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 8 hours 41 min ago
M4D M4X wrote:
we will see…
… sounds like a MF04 Wink
DENGOH
DENGOH's picture
Let’s discuss how much is too much for kcd? Do we want to use binocular to see so far. The answer is yes, please make it shoot the farthest as possible.
When I play with 450kcd, I am worried I shine on people at distance unknowingly because I can’t see clearly anymore. So everyone please use our big toy responsibly. I am thinking to bring my binoculars to be safe.
djozz
djozz's picture
I’m sorry that I do not I understand that calculation, especially why the battery configuration matters, I just see 200W of heat that is generated at the front part of the head, that either stays where it is or it goes somewhere else and thus keeps the head temperature a bit cooler for a bit longer time. And the little practical experience that I have with these power levels is that to funnel 200W to elsewhere it needs a large aluminium cross-section, a tube in the center with common wall thickness will not do that sufficiently.
(btw, always I’m all for keeping material thickness as low as possible, don’t like big chunks of material where it is not needed, but here I see a very good reason to add that material)
DENGOH
DENGOH's picture
Wieselflinkpro wrote:
M4D M4X wrote:
we will see…
Just options is enough. Save on engineering cost. MCPCB changes only.
Bo4ka
M4D M4X wrote:
we will see…
That would be great Smile
Wieselflinkpro
I think for the approximately size of the tube which transfers the heat to the fins.
djozz
djozz's picture
I see, so the idea is that that central shaft is close to massive then, with a small hole for the wires? (in that case I still think that a higher cross-section would matter))
KawiBoy1428
KawiBoy1428's picture
Last seen: 49 min 20 sec ago
Rather see 3-XHP70’s with 3 big deep reflectors at 8-9000lm Turbo like a huge BTU shocker and 5-70’s at 8-9000lms Turbo like a Ace beam X60. Not one for mixed emitter, multi-emitter lights. Rather have them all the same, but this is still very interesting… Thumbs Up
KB1428 “Live Life WOT
Litefighter
Litefighter's picture
Last seen: 1 year 1 month ago
JasonWW wrote:
leaftye wrote:
Are they working with any of the BLF driver wizards for this one? It’d be nice to get a great firmware UI to go with that dual button physical UI, and it’d be one less thing they could screw up.
No, it’s another Mateminco/Banggood light like the MF01 and MF02.
Which is a shame. You’d think some manufacturers would take notice after the Q8’s positive reception.
Lexel
Lexel's picture
Take a look on current >100W lights like X80, MF01, they are barely bigger than a Q8 and handle the heat for more than a minute
The MF03 compared to them has a huge head and also way more surface to loose some of the heat, that will increase sustained output
unknown00101
I agree. It doesn’t really make sense to have such a bottleneck directly under the heat source even though that (hopefully) thick tube is large. Trying to funnel 100% of the heat into 50% of the heat conducting area isn’t ideal.
Still looks like a very cool light though. Interested to see more details.
djozz
djozz's picture
I’m sure that with its clunky build it will do much better than those tiny monsters, but with my simple suggested correction in the design that hardly costs extra (if any) I’m pretty sure it will still perform noticably better.
DENGOH
DENGOH's picture
djozz, is it you are suggesting to have more thermal mass under leds mcpcb seating by reducing the length of fin? Those deep section of fin don’t have much airflow anyway, might as well make the fins shallower?
djozz
djozz's picture
It is not the thermal mass I want it for (although it does add a bit that will help lengthening the turbotime somewhat just because of that), but I want it for a large enough cross-section to help the heat getting through to the rest of the body of the flashlight.
(and with 200W power the fins are mostly cosmetic, they will do a certain job at lower powers)
ramptosd
Last seen: 22 hours 1 min ago
wolfdog1226. Are you four?
wolfdog1226
wolfdog1226's picture
Last seen: 10 months 6 days ago
See what led up to my comments before you judge me….then mind your own business. Wink
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
texas shooter
Last seen: 14 hours 20 min ago
And what will this “little darling” be powered with? Driver and batteries is the next question. I do like my 20700’s, I just got a few for $7.91 each from a U.S.A. store.
giorgoskok
giorgoskok's picture
Last seen: 2 months 1 day ago
Quote:
7 pcs Cree xhp70.2
and
one Cree xhp35 hi
Awesome !
JasonWW
JasonWW's picture
KawiBoy1428 wrote:
I would rather see 3-XHP70’s with 3 big deep reflectors at 8-9000lm Turbo like a huge BTU shocker and 5-70’s at 8-9000lms Turbo like a Ace beam X60.
You know they can’t push them that hard due to the poor efficiency.
The Imalent DX80 does 8 × 70.2 at 4,000 lumen each which is about 5A (6v). That’s about 32,000 lumen at 40 amps.
If this light had 8 × 70.2 at 8,500 lumen each that’s about 16A. Which is about 68,000 lumen at 128 amps.
You get double the output, but triple the power consumption.
Would we need to triple the batteries? Load it with 24 18650 cells? 6S4P.
The Imalent draws maybe 10A per cell on 8 cells.
This light would draw 32A per cell on 8 cells. So you’d need to at least run 16 cells to get it down to a more manageable 16A per cell. So at least 16 18650 cells. That’s a long battery tube.
I haven’t even mentioned the heat. You’d probably be triple at over 750 watts.
These are the reasons we are not seeing manufacturers push things so hard. The light would be so big and bulky and expensive to produce. It would not be practical at all and would therefore not sell well.
Kawiboy, I’m sure you know all this already, but I wanted to explain to all the newer folks the major hurdles involved.
