Not sure, I guess it depends on how much can a negative side of the battery wiggle while inserted backwards… Someone made lexan plastic rings that looked great
I dont see simple ways to make outer ring. If inner is enough to improve safety, I can make them.
Inner hole in mine Q8 stock ring is elliptical :zipper_mouth_face: from 20.0 to 20.5mm.
Can anyone check this on your Q8?
Mine looks circular and is barely outside the black line on the driver. Don’t have a caliper to check properly.
The widest I can spread the cells apart at the top is about 9mm. So any ring 15mm and up would offer enough protection (3mm overlap with the cell) if well centered.
I would like to buy 2 copper spacers for the Eagle Eye X6 and 1 copper spacer for the Convoy S2+.
Can I get 2 S2+ triple pills, the one with the stock retainer ring.
pm sent,i need some space,need some spacers plz
So…it definitely looks like a head. One set of threads screws battery tube, the other - the pill. There is probably the third one for the bezel. But there were ‘head’ guesses before…
Added: though I don’t understand why the pill needs different threading, so the above is probably wrong….
Maybe a quad led head for s2+ ?
I will say a complete head for a triple setup .
Possibly a heatsink before fins are added, but it looks like the beginning of a crenelated bezel for the S2+, useful for self defense.
It’s the shortest most edc’able DIY (18350/16340) quad with crenelated bezel in the world!
And the world went wild!!! :partying_face:
Well the BLF world went wild!
For crying out loud, just hurry up so I can order one of these, will you! :smiling_imp:
:+1:
oh man,cant wait!ill be sure to order one.
I’m going to go with electromagnet. I’ve really wanted a pocket electromagnet.
Perhaps its a heating device to make something hot or to discharge the battery.
The other Idea I have, It could be a pocket Laterna with down-light in tailstand.
Hey kiriba-ru, thanks for getting me that HD2010 spacer, and for shipping it out so quick, the machining is excellent! It’s great that you make these special parts for us! Also much thanks for the free gift! (spare 2010 reflector) It will be a big help for my project. Sorry I didn’t reply sooner been off the forum for a while, you’re awesome!
Are there any C8 triple setups still available?
I dont know why I need to say it each month, but once again:
Yes, first post is updated as soon as some item is sold and most time actual quantities are listed.
Upd.
When I dont leave exact quantity but write “in stock” this usually means more than 10pcs stocked.
