☢ [Bilakos10 Premium Deals] ● Astrolux FT03 SST-40 ● Astrolux A01 UV ● Seeknite X6S ● JCD 8898 Hot Air Station ● SQ-D60
OMG, there is no way it expired that fast.
Gearbest sent it expired to me…
The other ones should work.
DQG on the way, thanx!
expired?
As usual for Gearbest, the code for Convoy C8 6 / 8 x 7135 L2 T6 - 4C LED Flashlight - 6 X 7135 WHITE LIGHT and INR18650 - 25R 2500mAh 30A 3.7V 18650 Li-ion Battery - 4PCS is not applicable for shipments to Germany.
What's the deal? I intended to purchase multiple lights for Christmas but that is gonna happen on another platform now.
The coupon isn’t expired.
Try to remove the product from your basket and add it again.
Unfortunately, there is nothing I can do about it.
Gearbest’s managers are the ones who decide for which countries the offers will work.
You could convey your customers' disapproval of their coupon policy. Maybe it works...
Additionally, Gearbest will ship to or direct neighbors without issues but not to Europe's largest country. That's weird. If they have a sound reason, maybe I could understand those restrictions.
Same for BE btw, almost always excluded…
tjoep, exactly the same problem I have. No one coupon “BlackFriday” worked for me. reason unknown, nobody can explain it.
I have personally tested the coupon for the S2+ and it works OK for me.
Maybe you could try to ‘Proceed to Checkout’ in order to see whether the actual price reduces.
DQG Tiny ordered!
Thanks
EUR vs USD, maybe?
It should be 10€. Other global coupons work fine for me. But when it’s a NL specific one, it doesn’t.
£, $, € or any other currency is not making any difference.
no, it doesn’t.
the price is 17, after coupon applied as you can see at the picture provided, the price jumps up to 27, next page it is 17, like without coupon as points are acceptable. Weird.
coupon is not expired, otherwise it would be clearly stated.
by the way USOL39 code expired.
A quick note to those that are having problems with showing higher prices in their basket subtotal:
You can see that there is a bold orange FIXED PRICE Coupon showing.
Try to complete your order and you will see that you are going to be charged the coupon price.
It was irritating for me first, but it worked for me. At least at times when Germany was not excluded from all the coupons.
Just ordered the Convoy UV, thanks for the deal!
Thanks for pointing out the expired coupon.
As for the price adjustment with the coupon, try to do what @F_B suggested and report back.
hm, F_B, i’m afraid i’ll be charged full price. as i mentioned before i can use points, what is impossible when coupon applied.
@DmK
pity that it doesn’t work for you. Unfortunately i can’t check myself as I’m not able to use any of the good coupons
If I didn’t have 3 already (2 at 20bux a pop :expressionless: ), I wouldda pulled the trigger on this one so fast…
