if you have 6 its V1 and you can solder 3 of each kind to new driver
if you got only 2 you have V2 and you need to modify the MCPCB as well
cut in 6 places as shown
and
wiring the red circles together
wiring the black circles together
Please correct me if I’m wrong - if I understand correctly, for V2 you basically sever the traces on the star that connect the LEDs where the straight black lines are, and the squiggly black and red lines are where short pieces of cable are soldered onto the star?
Since this is my first ever project, I’m now wondering whether I should dare to rewire the LEDs, or whether I should keep the V1 configuration. I’m assuming I can just make the cuts with a carpet knife?
Thanks for the help. This is all new to me, and I really want to get it right. Got my rework station today, but I’m not even sure if the solder that I bought has a sufficient diameter … I’m eager to get started though once I’m sure I understand everything!
for V1 star no changes needed, not even opening up the head front
for V2 6 cuts on the marked lines are needed and all same color dots need to be wired to the driver adding bridges and 4-6 more leads (3 or 4 pads on driver), as you should increase the gauge of the wiring by 3 as the current goes up 3 times compared to V2
each wire should share 6 diodes current balanced
you don’t need to follow my painted wiring
I wired according to diagram and all leds are working except for 2 leds at mateminco label when you hook up positive wire for the two leds the 2 at mateminco come on an all others go off.If anybody has any ideas let me know.
Everything was working nice put it in light box with fresh charged vtc6’s and got 15000 lumens . But something has went wrong light still works it ramps up to about 4500 lumens the shuts off if you let go and ramp down it will come back on at 4200 and ramp down to moon.
Did some checking there is zero voltage on pin 3 when light is on .when you ramp up and light turns off or you double click for turbo there is 5.11 volts on pin 3.Anybody got any idea.
I got today also a light from Canada v2, so modding the MCPCB as well
I connected it the was it lights up with central connection, but I will place the main current cables to the spots where the resistance is optimized
What size wire did you use ? I used 20 awg . I bypassed all te springs on the driver and carrier and got 19100 lumens on startup, it stepped down before 30s with a 60c temp setting.
I wired the briges up to connect 2 leads for V+ and V-
I used 0.35mm² for the small bridge wires, as they only carry one 2S LED pair
so if I get this straight not reducing the mm² to the driver I would need 9x0.35mm€ so 3mm²
The leads to the driver I can go with 2x2 1.0mm² or barely fit 1.5mm² leads, so 2-3mm² each combined wire
I’m interested to see what output you get i ran mine last night and got 17800 lumens stepped down before 30s.I got 19000 last week i don’t know if it was because of the colder temps in workshop or just an anomally. This is probably my favorite light right now.
One thing has come up since the driver change. the springs in the carrier are not up to the task.My solder blobed vtc6’s will fall out now unless you hold them in.Anybody else had this problem. Mine are bypassed.
