1300Lumens Long Shots LED Flashlight 18650/26650 (link is external)
Is there a 2 cell version of this? Dont much care about the guts, just want the host.
Basing on the pictures and item description, it appears to be the CPF Italia Cometa 2016 (but “forbidden” to label as such due to some ‘controversy’, which is why there’s no brand indication on the item listing).
That Folomov A1 looks really nice, and compact, but so is a Nitecore F1, which also blinks out the voltage.
I guess this will still fit where a solid charger won’t though.
One of those semi-rigid earphone zip cases is ideal to keep this and a USB cable together and protected.
A spare 18650 fits in the ones I have as well, but the Nitecore won’t.
Features: • XP-L LED (CW and NW for options) with a lifespan of 50,000 hours • Max Output: 400 lumens(Ni-Mh), 800 lumens(14500) • 4 output levels plus Strobe, SOS and Beacon • Most efficiency constant current circuit, max runtime up to 171 hours • Size: 86.2*20mm (length*diameter) • New weight: 44.5g (excluding battery) • Aerospace-grade aluminum boy, premium Type III hard-anodized anti-abrasive finish on the surface • Aluminum alloy OP reflector creates a smooth and balance beam • Toughened ultra-clear glass lens with anti-reflective coating • Titanium coated stainless steel clip • Magnetic suction tail cap with tail standing ability • Waterproof to IPX-8 (2 meters under water), impact resistance to 1.5 meters • Applications: hiking, camping, traveling, EDC or tools etc. • Operation: -When off, one click to access Moonlight, another click to circle through moonlight-low-medium-high. Long Press for off. -When off, long press to access the memory output last use (except Moonlight), one click for circle. -When off, double click to access Strobe, one click for circle: Strobe-SOS-Beacon, Long press for off. -When on, double click to switch between general modes and flash modes.
Package included: 1x LUMINTOP EDC05 XP-L 800Lumens Magnetic Tail EDC LED Flashlight 1x User Manual 1x Lanyard
Features: Diving light specially designed for underwater sport Utilizes a XP-L HI V3 LED with 1000 lumens max output Integrated red auxiliary light for underwater photography Crystal Coating and Precision Digital Optics Technologies for extreme reflector performance Built-in threads for connecting the scuba diving pointer Reverse polarity protection Toughened ultra-clear mineral glass Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish Tail stand capability
Package included: 1 x Nitecore DL10 XP-L HI V3 1000Lumens Diving LED Flashlight 1 x Scuba diving pointer 1 x Diving lanyard 1 x Spare o-ring
Titanium is 65% heavier than aluminum. But an aluminum light has internal parts of aluminum, copper, steel, et cetera. So does a titanium light. And the same battery goes in, of course.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Don’t forget titanium is much stronger than aluminium and can thus be made thinner for the same amount of strength. Aluminium might be lighter (lower density), but looking at total weight for the strength needed titanium is the better option (except for cost of course).
None of this applies in this instance though, as the head seems to be made out of the much heavier copper for better heat sinking and dissipation.
M4D M4X, thanks for the Folomov A1!
I preordered this…
Interesting. Though I got too many chargers….
Strange why 21700 is not in the list of supported battery.
i assume they just did not test because that size is quite new
looking at the wires i think the extra 5 mm will not be a problem
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
see various reviews here:
http://budgetlightforum.com/node/47225
http://budgetlightforum.com/node/43817
http://budgetlightforum.com/node/46658
Folomov A1 preordered !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Beam me up!
limited units!!!
Thanks for A1!!
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
Hello my dear friends!
i added some new items to M4D M4X DEALS
LUMINTOP EDC05
XP-L 800Lumens Magnetic Tail EDC LED Flashlight AA/14500
Features:
• Operation:
Package included:
1x User Manual
1x Lanyard
Nitecore DL10
Xp-l Hi V3 1000Lumens Under Water 30M Diving LED Flashlight With Red Light
Features:
Package included:
1 x Diving lanyard
1 x Spare o-ring
Imalent MRB-186P30
3000mAh High Power 18650 Battery
Specification:
Product: Imalent MRB-186P30 3000mAh High Power 18650 Battery
Brand: Imalent
Model: MRB-186P30
Capacity: 3000mAh
Voltage: 3.7V
Charging Current: Recommended 0.5A (Maximum 1A)
Weight: 48g
Size: Diameter 18.5mm, Length 69.2 mm
Package included:
1 x Imalent MRB-186P30 3000mAh High Power 18650 Battery
Some more deals for today!
limited units available...
1. IMALENT DT35 XHP35 LED Flashlight
Price: $132.99
2. IMALENT DM21T LED Flashlight
Price: $27.98
Do you have a xiaomi power bank coupon code that is recent and works, thanks
Tried all the codes, couldn’t get one to work
try Bfriday210
for https://www.gearbest.com/power-banks/pp_600939.html?wid=83?lkid=11586067
Says coupon not for this warehouse
after the (still running) member gaw i have another for the facebook users...
https://m4dm4x.com/insta360-giveaway/
Folomov looks like amazing deal—only downside—The Folomov cannot do NiMH as the similar Olight charger can.
A well regulated Militia, being necessary to the security of a free State, the
right of the people to keep and bear Arms, shall not be infringed.
thats right
but Olight is twice the money and cannot be used as power bank (1A)
and olight has only 750 mA charging current
BOTH are not good chargers for cels below 18350 !
so one can choose what is useful and buy either one
I pre-ordered a couple of the Folomov A1. Looks good!
Thier ain’t no bones in a hot dog. F. York
Emisar D4 Titanium
i hope we get that to sell
Yes Please.
Would Emisar D4 Titanium be much heaver than the regular one? Would you know the weights of the regular one and also the Titanium D4?
the deals are to low for public eyes and seach bots
please check my deal list or contact me if you are interested!
LUMINTOP Geek
XPL HD 350Lumens Multifunction USB Rechargeable Portable Mini Keychain EDC Flashlight
Nitecore TINI
XP-G2 S3 380LM 4Modes USB Rechargeable Mini Metallic Keychain Light
LUMINTOP EDC05
(please click the links for detailed product descriptions)
Lumintop hit it out of the park with that Geek! Too pricey however.
have you checked my price?
not as cheap as other competitors, but knowing Lumintop i think worth it...
The geek is too expensive for me and too red. I think in bare aluminum color or black it will be more stylish.
Reviews: Sofirn SP40, YLP Panda 3R and Unicorn, Armytek Prime C1 Pro, Acebeam M50, Imalent MS18, Convoy M3, Nitecore TIP2, Imalent RT70, Wuben T70, Sofirn SP32A, Thorfire VG15S, Thorfire VG10S, Thorfire TG06S
Mods: Astrolux MF01-20K, Small sun T08 MT-G2, Eagle eye X6 triple XPL, Ultrafire F13 MT-G2, Convoy C8 XHP70, Solarstorm T3 triple XP-L HI
Big flashlight measurement and beamshot collection
3D printing stuff for flashlights
My flashlight related Instagram
My Flashlight related Youtube channel called Zozzlights
My Patreon page to support my reviews and mods
Hello my dear friend!
today i got a bunch of nice codes!
hurry up – they are limited…
i wrote a small review yesterday of this one: https://m4dm4x.com/xiaomi-yeelight-ceiling-light-experience/
and i just bought 2 of the bigger ones too
$95.99 with the code: XMY480
