[Modding] Astrolux MF01 --> OSH park NarsilM
I contacted banggood and they are supposed to be sending me a v1 mcpcb.
I wired according to diagram and all leds are working except for 2 leds at mateminco label when you hook up positive wire for the two leds the 2 at mateminco come on an all others go off.If anybody has any ideas let me know.
In the pcture on the bright area the traces are not really good visible, maybe the real trace is there different and another ground wire needed
Looks a mess but got all leds working.
Everything was working nice put it in light box with fresh charged vtc6’s and got 15000 lumens . But something has went wrong light still works it ramps up to about 4500 lumens the shuts off if you let go and ramp down it will come back on at 4200 and ramp down to moon.
Sounds like the FET died or its signal connection is broken
Should go to pin 3 of MCU
Yeah been gone gonna check it out tonight.
Did some checking there is zero voltage on pin 3 when light is on .when you ramp up and light turns off or you double click for turbo there is 5.11 volts on pin 3.Anybody got any idea.
I changed the fet and light is working now nearly 17000 lumens on turbo .
I got today also a light from Canada v2, so modding the MCPCB as well
I connected it the was it lights up with central connection, but I will place the main current cables to the spots where the resistance is optimized
What size wire did you use ? I used 20 awg . I bypassed all te springs on the driver and carrier and got 19100 lumens on startup, it stepped down before 30s with a 60c temp setting.
I wired the briges up to connect 2 leads for V+ and V-
I used 0.35mm² for the small bridge wires, as they only carry one 2S LED pair
so if I get this straight not reducing the mm² to the driver I would need 9x0.35mm€ so 3mm²
The leads to the driver I can go with 2x2 1.0mm² or barely fit 1.5mm² leads, so 2-3mm² each combined wire
I have now his light fully modded
leads are soldered to spots to get lowest resistance
Have you measured it please?How many Lumens-Candelas I mean?
I’m interested to see what output you get i ran mine last night and got 17800 lumens stepped down before 30s.I got 19000 last week i don’t know if it was because of the colder temps in workshop or just an anomally. This is probably my favorite light right now.
One thing has come up since the driver change. the springs in the carrier are not up to the task.My solder blobed vtc6’s will fall out now unless you hold them in.Anybody else had this problem. Mine are bypassed.
They should have bronze alloy springs, those usually conduct well and should not get hot especially when bridged
swap out for steel springs and 0.5mm² bypass, almost no current flow in the springs and they are a lot stiffer and more elastic than bronze springs
[quote=Lexel]
swap out for steel springs and 0.5mm² bypass, almost no current flow in the springs and they are a lot stiffer and more elastic than bronze springs[/q
I checked springs after a run on turbo and springs are not hot they have just got more compressed with use.
Cool mod but over my head.
too bad :frowning:
To me it looks like spaghetti. I keep thinking there has got to be a better way.
Too bad someone (the mfg) does not make the correct mcpcb so we can plug and play two parts instead of one and spaghetti.
Come to think of it this sounds like a group buy opportunity. have the mfg drop the better driver and make a new mcpcb for the emitters.
