M4D M4X deals - Astrolux WP1 and WP2 LEP
Thanks for A1!! :smiley:
Hello my dear friends!
i added some new items to M4D M4X DEALS
LUMINTOP EDC05
XP-L 800Lumens Magnetic Tail EDC LED Flashlight AA/14500
Features:
• XP-L LED (CW and NW for options) with a lifespan of 50,000 hours
• Max Output: 400 lumens(Ni-Mh), 800 lumens(14500)
• 4 output levels plus Strobe, SOS and Beacon
• Most efficiency constant current circuit, max runtime up to 171 hours
• Size: 86.2*20mm (length*diameter)
• New weight: 44.5g (excluding battery)
• Aerospace-grade aluminum boy, premium Type III hard-anodized anti-abrasive finish on the surface
• Aluminum alloy OP reflector creates a smooth and balance beam
• Toughened ultra-clear glass lens with anti-reflective coating
• Titanium coated stainless steel clip
• Magnetic suction tail cap with tail standing ability
• Waterproof to IPX-8 (2 meters under water), impact resistance to 1.5 meters
• Applications: hiking, camping, traveling, EDC or tools etc.
• Operation:
-When off, one click to access Moonlight, another click to circle through moonlight-low-medium-high. Long Press for off.
-When off, long press to access the memory output last use (except Moonlight), one click for circle.
-When off, double click to access Strobe, one click for circle: Strobe-SOS-Beacon, Long press for off.
-When on, double click to switch between general modes and flash modes.
Package included:
1x LUMINTOP EDC05 XP-L 800Lumens Magnetic Tail EDC LED Flashlight
1x User Manual
1x Lanyard
Nitecore DL10
Xp-l Hi V3 1000Lumens Under Water 30M Diving LED Flashlight With Red Light
Features:
Diving light specially designed for underwater sport
Utilizes a XP-L HI V3 LED with 1000 lumens max output
Integrated red auxiliary light for underwater photography
Crystal Coating and Precision Digital Optics Technologies for extreme reflector performance
Built-in threads for connecting the scuba diving pointer
Reverse polarity protection
Toughened ultra-clear mineral glass
Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
Tail stand capability
Package included:
1 x Nitecore DL10 XP-L HI V3 1000Lumens Diving LED Flashlight
1 x Scuba diving pointer
1 x Diving lanyard
1 x Spare o-ring
Imalent MRB-186P30
3000mAh High Power 18650 Battery
Specification:
Product:
Imalent MRB-186P30 3000mAh High Power 18650 Battery
Brand: Imalent
Model: MRB-186P30
Capacity: 3000mAh
Voltage: 3.7V
Charging Current: Recommended 0.5A (Maximum 1A)
Weight: 48g
Size: Diameter 18.5mm, Length 69.2 mm
Package included:
1 x Imalent MRB-186P30 3000mAh High Power 18650 Battery
Some more deals for today!
limited units available...
Model =my Link Code old price DEAL price
Fitorch MR35 HMR35 $76.25 $38.90
Fitorch P20R HP230R $54.99 $29.10
Fitorch P26R HP26R $103.29 $48.55
Fitorch EC10 HEC10 $38.59 $20.84
Fitorch P30Z HP30Z $50.49 $27.26
Fitorch P30R HP30R $63.79 $35.00
LUMINTOP Tool AA HLTAA $21.00 $17.22
Convoy S2+ HCS2 $15.95~$17.95 $13.24~$14.89
New Convoy L2 HCL2 $39.99 $29.99
JETbeam Mini-1 TI HJTM1 $35.95 $20.85
CooYoo Fermion HCYFE $58.95 $17.68
Lumintop Prince Copper HLPCX $54.00 $21.60
XPL Magnetron HXPLM $18.95 $6.80
1. IMALENT DT35 XHP35 LED Flashlight
Price: $132.99
2. IMALENT DM21T LED Flashlight
Price: $27.98
Do you have a xiaomi power bank coupon code that is recent and works, thanks
Tried all the codes, couldn’t get one to work
try Bfriday210
for https://www.gearbest.com/power-banks/pp_600939.html?wid=83?lkid=11586067
Says coupon not for this warehouse
after the (still running) member gaw i have another for the facebook users...
https://m4dm4x.com/insta360-giveaway/
Folomov looks like amazing deal—only downside—The Folomov cannot do NiMH as the similar Olight charger can.
thats right
but Olight is twice the money and cannot be used as power bank (1A)
and olight has only 750 mA charging current
BOTH are not good chargers for cels below 18350 !
so one can choose what is useful and buy either one :)
I pre-ordered a couple of the Folomov A1. Looks good!
Emisar D4 Titanium
i hope we get that to sell :)
Yes Please.
Would Emisar D4 Titanium be much heaver than the regular one? Would you know the weights of the regular one and also the Titanium D4?
Titanium is 65% heavier than aluminum. But an aluminum light has internal parts of aluminum, copper, steel, et cetera. So does a titanium light. And the same battery goes in, of course.
Don’t forget titanium is much stronger than aluminium and can thus be made thinner for the same amount of strength. Aluminium might be lighter (lower density), but looking at total weight for the strength needed titanium is the better option (except for cost of course).
None of this applies in this instance though, as the head seems to be made out of the much heavier copper for better heat sinking and dissipation.
the deals are to low for public eyes and seach bots ;)
please check my deal list or contact me if you are interested!
LUMINTOP Geek
XPL HD 350Lumens Multifunction USB Rechargeable Portable Mini Keychain EDC Flashlight
Nitecore TINI
XP-G2 S3 380LM 4Modes USB Rechargeable Mini Metallic Keychain Light
LUMINTOP EDC05
(please click the links for detailed product descriptions)
Lumintop hit it out of the park with that Geek! Too pricey however.
have you checked my price?
not as cheap as other competitors, but knowing Lumintop i think worth it...
The geek is too expensive for me and too red. I think in bare aluminum color or black it will be more stylish.
