Noise isolating In-Ear Monitors (IEMs) earbuds headphones like iLuv iEP322's
I have read a few reviews on these they appear to be good. They are duel driver units a 6mm and 10mm my only concern is they may be hard to drive duel units with out an amp.
I bought the KZ ED12 after owning the ATZ they are both good especially for the price i was looking at the duel driver unit models i will get a pair soon. I just bought 3 Benjie DAPs to try out lol.
I’v bought 2 pairs of these, I quite like them as the ear pieces are really good. And it comes in under $10 budget as well.
https://www.aliexpress.com/item/Original-AWEI-ES-70TY-3-5MM-Plug-Stereo-Music-Deep-Bass-In-ear-Earphones-Headphones-with/32789065866.html
They are $16.19 right now. I’m tempted to buy them. I just ordered a new DAP and looking for some decent IEMs to go along with it, although I’m still pretty happy with my old trusty Panasonic HJE350.
Yep, I’ve tried those and the others (including the newer ZS6). They are WAY too bright (huge bump @ 10-12k). However, the ZS3 is actually very decent, and is one of the cheaper models.
With a coupon you should be able to get them for under $10. That is the only KZ offering I’d bother with at this time. YMMV… :beer:
Is there a page in English? Can’t find click link for English.
What DAP did you buy?
Shanling M3s.
Are any of those mentioned remarkably good at just blocking ambient noise, without being used to play an audio file?
kids…or wife? :wink:
I think those are called ear plugs.
Hey, if anyone is looking for some great bluetooth buds, get the Oontz Budz They’re $34, but sound as great as a $100+ wired pair I used to own. I tore up my first pair, and turned around and ordered another pair to replace them.
(OT)
Is there a way for these headphones to enter a number for selecting a choice in answering phone menu?
Ended up ordering these in the end…
Airplane flights, or screeching subway wheels on curves.
Most noise blockers don’t suppress human speech frequencies, I’ve read that’s a FAA requirement so people don’t miss aircraft emergency instructions, but don’t know if that’s true.
Isolation varies with different earbuds, but it’s mostly a function of the tips. The cheap/flimsy tips that most low-dollar IEMs come with typically don’t offer a high level of isolation. A good set of silicone tips (of the right size) usually do an OK job. For me, the best isolation almost always comes from memory foam tips (again, of the right size), with my favorites being those from Comply.
The only downside is that good memory-foam tips can be expensive, and don’t last very long. YMMV…
So far I have bought 3 Benjie branded DAPs. Sound and performance to price is amazing people compare them to players costing hundreds. They are at least as good as my walkman and have a much more neutral sound. The eq are a bit basic but they can play high resolution audio and have decent built in amps.
OP, if you are still looking, I recently tried a bunch of different IEMs. These UiiSii CM5 are a little over your budget but have excellent bass and come with many different ear tips, so you are sure to find something that provides good fitment and noise isolation. They are very comfortable. Really fantastic sound at this price point…
http://a.co/4duF6gI
do you prefer these to the T2s you purchased?
thanks.
They’re quite different, and I like each for different reasons. It really depends on the sound signature that you prefer. The CM5 has a typical V-shaped response - boosted lows and highs, so if you’re a bass head, you’ll probably enjoy them more. The T2 has more of a neutral signature - flatter frequency response - the bass is still there, but not in the same amount as in CM5. However, the T2 is overall clearer/cleaner sounding. The T2 also has detachable cables (MMCX), which allows you to upgrade the cable and/or use a balanced cable if your amp/DAP has a balanced output. Alas, the T2 is more than twice the price.
FYI, you can partially seal the front vents on the T2 which will produce a lot more bass, but you have to be careful not to completely seal them as then the bass/midbass may become overpowering.
Those look really good, with great feedback on Amazon.
They're a little expensive, but I'll keep my eye on them.
