so have installed my TA driver into my L6 and got my hands on some liitokala 50a 26650s I did a tailcap measurement and it came up at just under 11amps.
can anyone tell me what my lumen output would be approx.?
Keep in mind that measuring lumens requires a special setup to get any type of consistent measurement. With just a lux meter, you can do simple ceiling bounces to measure increases and decreases in output.
I’ve got a lux meter, but no integrating sphere. It’s easier to just measure the amp draw and consult a chart to see about how many lumens it’s putting out.
This is a cold Lumens test with T solder point 25°C djozz and others do tests while the LED is likely hotter
djozz has as well N2 bin and has 3750 Lumens at 5A, while this chart has 3900 Lumens at 5A
I would also say that this homemade Lumen readings always can be +/-10% off
yes just the XHP70 at the mo but I do have an XHP70.2 on its way from Kaidomain.com
i was considering following one of Adventuresportsflashlights videos on how to create a lumen Tube. i know it wont be super accurate but will be able to give me an idea on what gains im making while modding.
Lexel do you have a similar chart for the XHP70.2?
Lexel, have you ever messed with a Crelant CH10 head mounted light? It has a 22mm driver with the switch on the battery side so there are 2 holes for the E switch wires to go through.
Do you think you could make a narsil driver for this light?
I need to unsolder the emitter to see the component side of the driver, but haven’t done that yet.
F*!!! I think I may have just destroyed my Driver. :rage: :rage: :rage:
today I received an SMO reflector for my L6 when I put it in it had a horrible look to the beam. I was trying to focus it and I think it touched the terminals on the Led star. I now have no modes. if I use the rear switch it comes on but I have no mode selection with the side switch.
A dead short with unprotected batteries likely killed the FET, easy to repair if you send me the driver, I had one driver before that got killed that way
Removing the FET and the light is at least useable with AMCs in the low and middle modes
If the FET is conductive when you use a DMM it needs to be replaced, not sure if you can do a reflow of it on your own if I send you one
Ok I got here one Narsil 17mm build but soldered already ba accident spring and cables to it, but got an error when I tried flasing Bistro OTSM :person_facepalming:
