edit: my AE strips were all hit and miss. not bright enough, sometimes I had to reflow LEDs because they didn’t light up. I have not bought the linked product though.
Thanks. Both for confirmation that I shouldn’t trust the stuff on Ali and for offering an alternative.
Though the alternative ain’t great either:
brightness at the very bottom of acceptable
efficiency at the very bottom of acceptable
CRI great
density good
price/m at the very bottom of acceptable ($25 shipping to my place doesn’t help)
price/lm which matters for some of my uses, but not for others - too high
So overall I could use it in some places, but not in others. Which is not a problem really, it’s surely better than what I’ve seen before. Still, it ain’t great.
I believe there are a few manufacturers that pump out millions of strips weekly. After buying many different LED strips at different price points I am certain they are all the same product or came from the same factory. They all have the same issues (low CRI, tint not great) but also similar advantages (cheap, reliable, and they light up).
good applications for cheap strips:
- I build a low-cost light box without PWM (tint not great, bad CRI); good enough for ebay sales pics
My general hobby room interior light are just several strips on an aluminum profile (quick build, low cost)
In my garage the light strips didn’t have enough lumens, same for a trial I had in the kitchen. Just not bright enough and the food looked weird.
Also tried COB LED light applications, they were cheap and light up but that was it.
COB modules with drivers on the same MCPCB in WW I ordered came out great
for a good 5m 1 row 60 LEDs per meter strip with CRI9080 you pay like 20-25$
Get those with ICs regulating the current not just the cheaper with resistors, so you can use longer rows without having on end less bright
then you look at >40$ for 5m
I’d like to get a single line of light in alu profile, that’s why I want density. I’m afraid the gaps between individual COB modules will ruin the effect, though otherwise they would be superb….
The aliexpress string seems to be the same that I found. If it really meets the specs, it’s good. The German ones are technically even better, though the price is above my capabilities….
Do you already have this profile?
If I had to make hi-cri hi-density strip, I would buy 219b nichias in 3S config from KD, then solder them to the copper busline, connect each star in parrallel with extra resistor (similar to 12v strips) and choose suitable size aluminium heatsink.
No, I can pick one to adjust to the needs. 219b / KD would be a great option if:
I wanted a very wide profile. In some cases it’s good, in some not (I don’t need a single solution for all places though)
I had the budget for it. That’s over $200/m, way more than I can afford.
Actually I’ve been thinking that maybe I can find some nice PCBs and solder the LEDs / resistors / regulators of my choice. Though I think I’d need a reflow oven for that, my puny Yihua may not work.
Right now I’m searching for linear COBs on Aliexpress. Some are really nice, with up to 1170x6 mm sizes I could usually do with just 1 COB per section. And profile selection would be way easier, even a frosted lens would do for a nice efficacy improvement. Also, I could make very thin lines.
But these come in CRI “60-80”
Overall, I have troubles searching for “COB CRI” on Ali. The results that I’m getting are “COB Crystal”. :person_facepalming:
Your requirments are impossible.
First of all, you need to choose illuminance you need. And calculate how much lm/m you have to use.
When you have lm/m, you can calculate W/m. Dont forget than you won t have more than 100lm/w with small leds (not hi CRI!) and 60lm/w with COBs. (Most COBs from ali are UNDER 60CRI, never use them in living place!).
After you need to remember most simple formula than I have posted several times on BLF - at least 20sq. sm per each led Watt. Surfaces that dont have direct air flow are not included, so actually profiles that are insertes into walls/ceiling etc. should be calculated as 30-40sq. sm. per Watt.
I have used regular 36 leds/0.5m strips on aluminium pcb, power consumption near 15W/m. Most people use them “as is” (without heatsink), I have bought most cheap alu profile that I don’t like (I didn’t feel it enough for strips, in my opinion they get too hot) so I added extra aluminium heatsink with ribs cutted into strips from the backside. In real life this construction gets hot but safety hot (45 degrees progile~55 degrees pcb~75 degrees leds, don’t forget that this pcbs have big thermal R). Only after this improvements Im sure in LEDs lifetime.
As you can suppose, wide alu profile is much cheaper and faster assemble (just imagine extra several kgs of extra heatsink, its cutting, glueing etc.) than my solution.
To make it budget friendly, you have to exclude buying hardware parts from china. If you will find local supplier, you will get much lower prices for profiles and heatsinks in comparation with aliexpress.
You can find bare pcbs, but most of them are made for smaller leds (2828 2835 etc.) that are not available in 90+ cri and lm/$ wont be better than nichias from KD.
Thanks, that’s mostly what I’ve been doing except that I didn’t know how to chose a heatsink.
When you write sm you mean cm, right?
The only light that I’ve done so far sits comfortably within the limit (35 cm^2/W enclosed, but I will PWM it to way lower output, probably at most half). The next one which I intend to do soon would be much worse at about 12 cm^2/W mounted under cabinet (counting exposed surfaces). PWMed too, but not much. I’ll look into other profile options, so I’m safe…though I may have to increase height more than I’d like. I’ll think about heatsink.
That’s interesting, thanks. I tried reverse image search for the spectrometer results, found nothing. The date seems OK. Use of different fonts? Weird….especially as it doesn’t look like the information that they would edit.
As to dense, I’ve seen some 300 led/m strips. The leds were smaller than 3528 though.
I like the idea of having large number of small LEDs to avoid spots in the light beam.
But the supplier of the 3528 above offers all color temperatures from 2700K to 6500K plus red, green, blue, yellow with the same lumens/LED and Ra>95. :person_facepalming:
Anyway I am tempted to try the first one…
One other thing to mention today is the overall wattage of such a strip. If you are using several meters long strips the printed PCB may have problems handling the overall current. You will need additional power feed-in cables on the way. And a big power supply.
You have to use frosted transparent plactic anyway.
Yep, leds are not modern low Vf so with 12v power supply there is no much room for voltage drop. Same time traces on pcb are not thick. I wouldnt use more than 1m strip connected from the one side, or more than 3m strip connected from both sides. So you cant only connect all strips, you have to use extra thicker wires between ps and strips.
Having power supply with adjustable output voltage is usefull option, but please check resistors wattage limit before voltage regulation.
I don’t think a frosted cover will do, you need milky for that.
But you don’t need anywhere near this dense, take a profile that has 8 mm distance between the strip and the cover, 120 LED/m and you’re done.
Do note that there are milky covers that are <30% transparent and ones that are 80%, depending on how much they scatter the light and on quality. It’s worth to pay some more.
I tend to use 24V strips. Cutting sections are twice as large and PSU selection is somewhat lower, but there’s more uniform light distribution and slightly higher efficiency. Also, so far I targetted mid-end strips; resistor based, but with good PCBs.
24V is also somewhat better when it comes to controller selection; I’ve been limited by current in my next light and that’s just over 3m.
Here I have a 2m light connected from 2 side. Considering double voltage it would be your limit. I don’t see any brightness difference between the sides.
ADDED: BTW recently I’ve seen 24V strip with 7 LEDs per section (and not 6 like usual). Higher efficiency, but more vulnerable to voltage spikes. If you use good PSUs, that’s a good thing. I use medium level, so I’m not so sure.
The Cchips are really big inside and the LEDs don’t get a lot of current - so these stripes will last.
CRI at 3000 and 4000K is good and the color of the light as well.
