Some people like TIRs more than reflectors as there is less spill.
“The cheapest I could find” usually is not the best quality. Check the Convoy TIR thread and see if you like it.
I just experimented with focus. Before, I didn’t remove the centering ring. Now I did and it helped a lot, judging by the eye the hotspot is brighter than the reflector now. It seems that the LED itself doesn’t let it sit low enough, so there should be further gains after dedoming. Anyway, I’ll try a better lens too.
One trick I forgot, but got reminded in another thread. I can try to make the stock MCPCB DTP.
Instead of filing down a 20 mm PCB it might be easier to file down the protruding part of the pill where the 16 mm PCB sits. (Just an idea, haven’t done this yet.)
And I don’t believe it’s worth to do spring bypasses as long as you don’t use a FET driver or stack plenty of 7135. Same with thicker wires.
Dedoming is good for throw - and not too difficult with XM-L2.
Coated lens gives only little lumen gain but might worsen the tint.
Most easy mod for throw probably is to get a cheap XP-L HI on DTP board - KD usually has fair prices - and a BLF A6 driver (look for coupons). And spring bypasses and thicker wires in this case.
Most beautiful mod of course is a triple with carclo and high CRI LEDs but this will exceed your budget slightly. KD has triple boards with Nichia 219C 4000K CRI92 for little money, cheaper than single LEDs. But the boards are crap, you should reflow the LEDs to a noctigons. I did this mods with copper spacers but I’ve seen some old posts here where members did it even without spacers.
is there any way to fit metal tail switch for grey or black S2+s?
Like this?
No. :innocent:
The opening for the silicone tailcap is bigger than the thread for the metal button.
But a press-in adaptor ring could work. Metal buttons are available as spares.
Exactly :student:
What press-in adapter ring did you use? is the switch a perfect fit? does it wiggle around?
SCNR. No adapter. This is genuine.
(It was a prototype for the clip-on-button recharge as for BD series.)
:zipper_mouth_face: , Oh, ok
Sofirn is selling the driver in their C8A/C8T torches as a standalone upgrade:
That close-up picture was shot by me with the help of a 37mm (Google cardboard) convex lens atop my smartphone camera lens. With this driver current went above 6A on an XP-L HI emitter in their C8T flashlight. Steps down to low power MOSFET operation after 3:25 (205 seconds) and has moonlight mode packed together with a funny strobe in group mode 2:
Cheers :-)
I ordered 2 different 10-degree lenses from leddna. But I can’t help but wonder will my 5-degree lens be throwier? Better quality vs. narrower design. But a more important question: will a good 5/8 degree lens be better than what leddna or Simon offers? And how to find a good one?
I have the 10-degree lens from LEDDNA. came in excellent packaging, gives a good throw from an S2+ (you can “feel” the beam). they had them on sale earlier this year (not sure how much I paid).
Don’t have any results from a 5-degree lens though.
I got 21x12.5 and 20x13.5 mm for $0.40 and $0.54 respectively. I may get a third S2+ here before the lenses arrive, so I may be able to directly compare stock vs. cheap 5° vs. LEDDNA 10°, even if only by the eyes…
There are some cheap lighted tail caps from Convoy now.
DIY 1288 LED Lights Lamp Lighting Switch For Convoy C8 M1 M2 S2 S2+
DTP copper MCPCB
And you can stack 7135 to have more than 8. 10 would be 3.5+Amps, if you get copper DTP the XM-L2 can handle it.
[/quote]
Says they are no longer available.
They are on BG now.
Thanks.
I guess channel separation and FET mod is just too much hassle to make sense nowadays?
Also, is it worth to pot this driver?
Inspired by PFlexPro I tried to unsolder the switch with the intention of lubricating it.
I failed to do so, it still sticks to MCPCB. The plastic on the side that I tried to unsolder melted before the solder did. It is slightly retracted (0.5 mm I guess). And the switch stopped clicking, it moves up and down, but doesn’t switch like it should, always off.
Should I replace the switch with another or fix somehow?
Regardless, how should I remove it? Heat is up less, but for longer? Heat it up more, but for shorter? Don’t heat up but cut with a knife?
Switch is dead, you need a new one. Get a Genuine Omten 1288 from Simon.
Switches to do not take heat well. It changes the spring contacts inside and fail prematurely. I always remove the SW when I bypass the springs. Replace when done.
To remove I wedge a blade under one side and lift as I melt the solder. Get one contact free and melt solder on the other side. Iusually clean off the solder from board because the lumps make it harder to replace the SW. I hold the leg I am soldering with a small needle nose pliers to help sink the heat, keep it from going back into the SW
I think those are DTP actually.
