Great, now Iām on ebay looking at carbide lamp prices because it would be cool to buy one and have it around in case the power goes out. :confounded:
Hereās the caves.org page on carbide lamps, a good resource:
You want spare ātipsā (brass and ceramic with a pinhole for the gas, press fit into the gas delivery tube, easily blown out and lost)
And a wing nut that holds the reflector onto the gas delivery tube; backing the wing nut off pulls the tip out if itās properly been pressed in.
and a tip cleaner (a little bristle-wire brush useful for cleaning out the pinhole when it gets sooted up)
and spare felts (the gas is evolved in the lower container as water drips in; the felt is held onto the water drip delivery tube by a spring clip, and the gas has to move through the felt and a perforated plate to get into the gas delivery tube that goes up and turns 90 degrees to exit (through the tip) and burn at the focus point of the reflector.
When the water gets low, gas can start to back up from the fuel chamber into the upper water chamber through the water delivery tube; if you hear it bubbling, expect a small explosion to be possible, dumping a cup of water down over your face.
(Hey, strapping lights to oneās forehead has always had some hazards.)
And flints. Donāt forget the flints to strike a spark.
And a trash bottle to collect the white lime, you donāt want to be dumping that crap in a cave or anywhere else. Neutralize it properly: https://www.google.com/search?q=calcium+hydrdoxide+disposal
(Hey, old lithium-ion batteries are a disposal issue tooā¦)
You hold your palm over the reflector, capture some gas behind it, whip your hand off to the side turning the sparker and POP the lamp is lit with a nice flame that hovers in the air a fraction of an inch away from the tip orifice.
There are also 2-hole acetylene burner tips where the flame burns at the point the 2 jets of acetylene intersect in front of the reflector.
If you got it wrong, after the POP your tip has gone for a short flight and you have an unfocused orange flame sooting up your reflector (if the gas stayed lit).
Felts get clogged with the reaction product (calcium hydroxide, a white powder); replace them in the field, wash them out and dry the clogged ones later).
Very warm white at low gas pressure (short flame that deposits a lot of soot)
Neutral to blue-white at high gas pressure (better combustion in a longer flame)
PS, for those who like parts, the supplier listed above has these:
Why would you charge a Q8 with a battery bank instead of just putting the batteries IN the Q8? The only reason I could see is if you needed uninterrupted long-run time. This for example can make sense for some bicycle gadgets (camera for example) for long rides if you don't want to get off the bike and stop to change batteries.
I doubt you'll get much over 50% efficiency with an inductive charger off a battery bank. So that's twice the battery weight, twice the cost, plus the weight cost, and bulk of holder and inductive charger, instead of... just carrying batteries.
Yup, thatās the one. It has been used against free software a lot, and recently has gotten much more common in other contexts too. I find I have very little patience for it.
Anyway, my Q8 has been a nice night light and development host, and the batteries seem theyāll last a rather long time per charge. Iām only down to 3.9V on the first charge so far, and it gets used a lot.
Not sure I understandā¦ the green switch ledās are supposed to be on when the light is off. Is that it? And the switch ledās go off when the light is on.
Normal operation of the Q8 has the switch ledās stay lit when the Q8 is turned off. However, if you are using ramping mode there is a simple way to get the switch ledās to remain off when the light is turned off. I am not sure if this can be done with the Q8 set to discrete, non ramping, modes.
Turn on the light. Then ramp up or down and then very quickly click the switch to turn off the light. When done quick enough the light turns off and the switch ledās stay off too.
That might take some practice but I can now make the switch ledās remain off whenever I want.
Thanks guys , MtnDon i understand but now I have another problem In my second Q8 if turn off Q8 leds in no light ? So, maybe my second sweety have defect ?
That is normal. I think it was said it will last for years with the indicator lit.If you would like to turn it off, do 4 short clicks. That locks it out, and you have to do 4 short clicks to turn it back on. I think there is somewhere in the configuration to turn it off, permanently.
