Have to wait till Black Friday Sale is over. It is hard to get hold of people during major sale period.
Replied.
Thanks Freeme
Im interested - White NW please.
I’m interested in a black one with NW, depending on price. Thanks.
Interested in one NW Thanks!
im in NW
Freeme can you send me the code please! and thanks!!
I just took batteries out of the MT03II 70.2 and found out the 2batteries were at 4.2V still full but other 2 were at 3.90V. Haikelite should look into the problem right away and I think most of the first badge are defected.
How is it even possible that 2 cells are not making contact?
The polarity protection rings? Are you using button top cells as recommended?
Is there a problem in the tail cap pcb? A burnt trace maybe?
The 2 emitters were blinking like disco light since the first time I turned it on and I have already E-mail Haikelite about the problem. They promised me that they would give me a good solution but I have been waiting for about a month now and still no solution LOL. Now new problem.
What type of batteries are you using? Do they fit around the plastic polarity protection rings?
I’m using Sony VTC6.
JasonWW:What type of batteries are you using? Do they fit around the plastic polarity protection rings?
Button top?
If you using flat top it may not work and that is what is causing the non contact.
chakrawal: JasonWW:What type of batteries are you using? Do they fit around the plastic polarity protection rings?
Button top?
Haikelite MT03 Devourer Review ![image] ! Hey folks i started a new thread for the review the other thread will be turned into a mod thread for the MT03 Hey folks today we take a closer look at the Haikelite MT03 devourer I am trying to say while spelling it and its still hard. If you follow any threads on BLF you would have seen the MT03 coming to life in the Haikelite thread? Lots of people put there time and effort and input into the thread about what they wanted from the MT03 and now th…
They reccomended LG HG2 which are the same as Sony VTC6.
“You will need raised cells but not button tops. The button tops will not fit the light properly. It will still power on but it will not be waterproofed because the battery compartment will be open. I suggest LG HG2 or any style of battery that will work in series.”
Do button tops add so much length?
So raised flat tops?
Maybe regular flat tops, but with thin magnets added?
I guess you could solder blob them to get just a tiny bit more height so they make contact.
I think the problem is the driver not batteries. Already 4 of them in this group.
JasonWW:Do button tops add so much length?
Both. Flickering leds is most likely driver problem. Uneven battery discharge cannot be a driver problem; it must be in the carrier/battery tube.
chakrawal: JasonWW:Do button tops add so much length?
Just put in Keeppower button top, let’s see what will happen.
I don’t know which Keeppower you’re using, but they might trip on turbo. As far as I know only the 3120 and 3000 Keeppower can handle the power. You could run the MT03 on high for some time, and check battery voltage if they’re even.
Please send code for this NW thanks
