Ansmann AA 2850mAh (Silver)
Official specifications:
Nominal voltage: 1.2V
Nominal capacity: 2850mAh
Minimum capacity: 2650mAh at 0.2C
Minimum capacity: 2450mAh at 1C
Max. continuous discharge current: 5000mA
Standard charge: 285mA
Quick charge: 800mA
Fast charge: 2850mA
Recommended charge termination: 0…5mV, 0.8…1°C/minute, 45…50°C
Continuous overcharge current: <200mA no conspicuous deformation, no leakage
Internal impedance: <30mOhm at 1kHz for fully charged battery
Cycle life: >500 according to IEC standard
Self discharge: >60% after 28 days at 20°C
Made in China
Maximum temperature raise at different discharge currents: 1A:+1,2°C, 2A:+3,8°C, 3A:+6,4°C, 5A:+12,7°C, 7A:+19,0°C, 10A:+24,5°C
High capacity AA batteries from Ansmann.
The discharge curves are normal for AA cells, the capacity is very high.
Conclusion
These cells are high capacity AA cells, but the price to pay for that is fast self discharge (How fast is rated in the data sheet\*).
Notes and links
\*Ansmann has real data sheets for their NiMH batteries.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
