Tom is the light glued?
Also does the driver have retaining ring? And what is the driver diameter?
Amutorch/Galuxia JM70 XPL HI
Driver diam is 28 mm. Nope, no glue accept a dab under the driver - probably to get the switch aligned to the button, but driver still came out easy. Yep, has a thin brass retaining ring on the driver. Very moddable.
The driver does not act like a buck or boost. Output decreases as the cell drops. My first test was with an LK cell at about 4.05V or so, and got 870 lumens, 188 kcd (2.55A tail). On a full LK cell @4.21V, got 950 lumens, 205 kcd (2.84A tail)
Then made a few mods:
Stock:
This got:
This is slightly better now than the specs posted. Really needs a FET driver though. Because the switch is driver mounted, I'd probably go with a piggyback driver mount.
Hello dear friends,
A kindly note: the deals for Black Friday above now are expired, thank you for your support.
There is a new deal for Cyber Monday, can be used for all Light & Lighting products( expect the "promo" tag)
15% OFF for Light & Lighting
Code: cyberled15%
Link: https://www.banggood.com/cate-c-1697.html
I will update more deals later, hope you like them
Flash Deals
1. Xiaomi Power Bank 2 10000mAh
Price: $15.29
Link: https://www.banggood.com/Original-Xiaomi-Power-Bank-2-10000mAh-Quick-Charge-2-0-Portable-Charger-p-1088932.html?
2. Smiling Shark SS-8022 Mini LED Flashlight
Price: $2.29
Link:https://www.banggood.com/Smiling-Shark-SS-8022-Q5-3modes-Zoomable-Mini-LED-Flashlight-p-934819.html?
3. Samsung INR18650-30Q 3000mAh Unprotected Button Top
Price: $18.88
Link: https://www.banggood.com/4PCS-Samsung-INR18650-30Q-3000mAh-Unprotected-Button-Top-18650-Battery-p-1067185.html?
[quote=Banggood]
Flash Deals
Price: $15.29
2.
This warehouse can not ship to your location :weary:
20 AWG bypass wires on both springs
20 AWG LED wires (stock were ~26 AWG)
bypassed sense resistor with a jumper
sanded down centering piece a little
swapped stock XPL HI with a XPL HI V3 2B from MtnE, sanded MCPCB smooth, MX-4 thermal grease
Stock:
stock MCPCB is a good one: 32 mm DTP MaxToch, screwed down by 2 screws - excellent
Reflector I.D. is 61.5 mm - outstanding
Weight: 305g - fairly light for it’s size
nice solid shelf
the blue bezel is not SS unfortunately, it’s aluminum
the switch looks like a heavy duty one. There’s 2 slots next to the rubber switch boot to unscrew the tail - the removable tail/switch housing is plastic though
This got:
1240 lumens, 266 kcd (3.74A)
This is slightly better now than the specs posted. Really needs a FET driver though. Because the switch is driver mounted, I’d probably go with a piggyback driver mount.
Thanks for all of this info Tom E, it really helps. I’m not interested of moding it, I’m just interested how it will be in compared to Nitecore P30 for example since prices are the similar. Can this JM70 out throw it since it have bigger reflector etc, and is it worth of buying compared to other lights on same and similar price range. If you have some pics you can send me on PM it will really helps.
1. Full-steam ahead for larger space
New Arrival 18% off
Link: https://deals.banggood.com/deals/edm/topic/Branddiscovery.html?
2. Cyber Week November Final Craze
$1 Snap up
New Release
Link: https://www.banggood.com/collection-4582.html?
1) 15% off for Cyber Brand Tools
Code: CyberTool
Link: https://www.banggood.com/collection-4776.html
2) 10%OFF cyber Computer (Valid For computer And Networking,except Tablet PC products)
Code: cybercomputer10%
Link: https://www.banggood.com/cate-c-427.html
https://www.banggood.com/cate-c-2187.html
https://www.banggood.com/cate-c-4335.html
https://www.banggood.com/cate-c-1977.html
3) 15% OFF Cyber Jewelry
Code: cyberJewelry15%
Link: https://www.banggood.com/cate-c-170.html
4)15% OFF Cyber beauty
Code: cyberbeauty15%
Link: https://www.banggood.com/cate-c-892.html
5)15% OFF Cyber Bag
Code: cyberbagshoes15%
Link: https://www.banggood.com/cate-c-3798.html
6)15% OFF Cyber Light & Lighting
Code: cyberled15%
7) 15% OFF Cyber Auto
Code: cyberauto15%
Link: https://www.banggood.com/cate-c-1134.html
Hot Sale Products
1. iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol Transmitter With Receiver
Price: $75.99~$83.99
Link:https://www.banggood.com/IRangeX-iRX-IR8M-2_4G-8CH-Multi-Protocol-Transmitter-With-PPM-S_BUS-Mini-Receiver-p-1226058.html?
2. BlitzWolf® BW-BS3 Sport Versatile 3 in 1 Bluetooth Tripod Selfie Sticks
Price: $15.99~$21.99
Link: https://www.banggood.com/BlitzWolf-BW-BS3-Sport-Versatile-3-in-1-Bluetooth-Tripod-Selfie-Sticks-both-for-Sport-Camera-and-Smart-Phone-p-1224204.html?
3. Digoo DG-DM1 Wireless USB Mirror LED Digital Alarm Clock
Price: $8.99
Link: https://www.banggood.com/Digoo-DG-DM1-Wireless-USB-Mirror-LED-Digital-Therometer-Temperature-Night-Mode-Black-Alarm-Clock-p-1220154.html?
4. ANENG AN8009 True RMS Digital Multimeter
Price: $19.99
Link: https://www.banggood.com/ANENG-AN8009-True-RMS-NCV-Digital-Multimeter-9999-Counts-Backlight-AC-DC-Current-Voltage-Tester-p-1216900.html?
5. XANES SFL03 Flood Light
Price: $6.99
Link: https://www.banggood.com/XANES-SFL03-600LM-XPGLED-German-Standard-Smart-Induction-Bicycle-Light-IPX4-USB-Rechargeable-Large-F-p-1216191.html?
6. Xiaomi Redmi Note 4 (4GB+64GB) Global Edition
Price: $179.49
Link: https://www.banggood.com/Xiaomi-Redmi-Note-4-Global-Edition-5_5-inch-4GB-RAM-64GB-ROM-Snapdragon-625-Octa-core-4G-Smartphone-p-1148122.html?
any deals on button top samsung 30qs?
Nur US$33.00, kaufen Sie den besten 4PCS INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery With Protected box Online-Shop zum Großhandelspreis.
Well throw is 205 - 200 kcd, pretty darn good. The P30 is rated at 95 kcd -- no comparison there.
I did find out the other JM70 I received had the old style driver - actually performs a bit better, stock, in Turbo at ~1,150 lumens, ~220 kcd, drawing about 3.6 amps.
vidramon:Thanks for all of this info Tom E, it really helps. I’m not interested of moding it, I’m just interested how it will be in compared to Nitecore P30 for example since prices are the similar. Can this JM70 out throw it since it have bigger reflector etc, and is it worth of buying compared to other lights on same and similar price range. If you have some pics you can send me on PM it will really helps.
Well throw is 205 - 200 kcd, pretty darn good. The P30 is rated at 95 kcd — no comparison there.
I do not trust any more of those numbers, need to see it or that someone trusted tell me.
For example Utorch ut02 is marked with 124000cd and I can’t see any improvement comparing it with P30, even more P30 is better to me.
I will wait if price again drop under 40$ I will take it.
Gutsy I’m pretty sure Tom E is a “trusted” member around here. Over 5 years on BLF and 10,000+ posts should earn a least a little credit.
I did not mean anything bad, just say I don’t believe manufacturers specifications any more.
Except perhaps Nitecore, Olight, Xtar and other high brend manufacturers that can be taked seriously about their ratings.
Ahh, excuse the confusion. The numbers Tom stated were his numbers, not the manufacturer’s. So when you said you didn’t trust them, I thought you were aiming that at Tom.
I speak genearally about that ratings from manufacturers and theirs in the big case exaggerated ratings. English is not my naturally language so I can’t express oneself on the best way.
Tom E is trying to help, now I see that they write 264000cd, I did not pay attention to that, interesting I hope it is worth 40$.
I understood what you intended there. Yea, I know - it wasn't a good comparison, I should have said that. Frequently manu specs are way off, like ThruNite kcd #'s on their throwers. There's also the variations from piece to piece out there, even in name brands. I' know I've gotten under performing Nitecores in the past - I ordered 2 EA41's together a while back and one was maybe 10-15% lower than the other, and about the same percent under it's specs.
In theory though, the P30 with it's lower "spec'd" lumens and smaller reflector should throw less.
Dale measured the P30 at 115 kcd and 1,050 lumens here: https://budgetlightforum.com/t/-/42527/22, and I trust his numbers.
Flash Deals (Lasts for Dec 4th)
1. SONOFF® S20 10A 2200W Wifi Wireless Remote Control Socket
Price: $9.99~$11.99
Link: https://www.banggood.com/SONOFF-S20-10A-2200W-Wifi-Wireless-Remote-Control-Socket-Smart-Timer-Plug-Smart-Home-Power-Socket-Support-Alexa-p-1142285.html?
2. C-17 Transport 373mm EPP DIY RC Airplane
Price: $23.49
Link: https://www.banggood.com/C17-C-17-Transport-373mm-Wingspan-EPP-DIY-RC-Airplane-RTF-p-1176723.html?
3. Meco XPE-Q5 Mini LED Flashlight
Price: $1.99
Link:https://www.banggood.com/Meco-XPE-Q5-600-Lumen-7W-Zoomable-LED-Flashlight-For-1xAA-1_2V-p-907006.html?
4. Excellway ET25 Wire Connectors
Price: $0.69~$2.19
Link:https://www.banggood.com/5Pcs-235-Pins-Reusable-Spring-Lever-Terminal-Block-Electric-Cable-Wire-Connector-p-1103030.html?
5. Eachine VTX03 FPV Transmitter
Price: $9.99
Link: https://www.banggood.com/Eachine-VTX03-Super-Mini-5_8G-72CH-025mW50mw200mW-Switchable-FPV-Transmitter-p-1114206.html?
6. LED Electronic Display Taillight
Price: $9.99
Link: https://www.banggood.com/XANES-X1-DIY-Bicycle-Taillight-Programmable-LED-Electronic-Advertising-Display-Bicycle-TailLight-USB-p-1220458.html?
7. Christmas Tree LED Flash Kit
Price: $4.68
Link:https://www.banggood.com/Christmas-Tree-LED-Flash-Kit-3D-DIY-Electronic-Learning-Kit-p-1007523.html?
8. Flysky FS-i6 transmitter
Price: $42.59
Link:https://www.banggood.com/FlySky-FS-i6-2_4G-6CH-AFHDS-RC-Transmitter-With-FS-iA6B-Receiver-p-983537.html?
9. Pet Dog Anti-lost Smart Tracker
Price: $1.29
Link:https://www.banggood.com/Pet-Dog-Anti-lost-Tracker-Smart-Buletooth-Tracer-GPS-Locator-Tag-Alarm-Tracer-Finder-p-1078311.html?
10. XiaoMi Smart Bulb
Price: $13.99
Link:https://www.banggood.com/Original-Xiaomi-Mi-Yeelight-9W-RGB-E27-LED-Wireless-WIFI-Control-Smart-Light-Lamp-Bulb-AC220V-p-1054192.html?
11. Eachine ROTG01 5.8G 150CH Mobile Receiver
Price: $18.99
Link: https://www.banggood.com/Eachine-ROTG01-UVC-OTG-5_8G-150CH-Full-Channel-FPV-Receiver-For-Android-Mobile-Phone-Smartphone-p-1147692.html?
12.Convoy C8 XP-L HI 7135*8 LED Flashlight
Price: $14.99~$17.99
Link:https://www.banggood.com/Convoy-C8-XP-L-HI-71358-Integrated-Head-Long-Range-LED-Flashlight-p-1057489.html?
13. NCR18650B 3400mAH Lithium battery
Price: $18.99
Link: https://www.banggood.com/4pcs-NCR18650B-3400mAH-3_7-V-Unprotected-Rechargeable-Lithium-Battery-p-943453.html?
14. Original Xiaomi Yeelight
Price: $38.99
Link:https://www.banggood.com/Original-Xiaomi-Yeelight-Bedside-Lamp-With-Cellphone-Controlled-p-981339.html?
15.MECO XM-L T6 2000lm LED Flashlight
Price: $6.95
Link:https://www.banggood.com/MECO-CREE-XM-L-T6-2000lm-5-Modes-Lotus-Shape-LED-Flashlight-p-982571.html?
16. Nitecore TIP2017 XP-G2 360LM USB LED Keychain Light
Price: $21.95
Link: https://www.banggood.com/Nitecore-TIP2017-XP-G2-360LM-Metallic-USB-Rechargeable-LED-Mini-Keychain-Light-p-1154725.html?
17. Astrolux S42 18650 Version 2023LM USB EDC LED Flashlight
Price: $30.95
Link: https://www.banggood.com/Astrolux-S42-18650-Version-4xNichia-219CXP-G3-2023LM-USB-EDC-LED-Flashlight-INR18650-30Q-Battey-p-1219369.html?
18.liitokala lii-202 5V 2A Micro USB Charger
Price: $6.95
Link:https://www.banggood.com/Liitokala-lii-202-5V-2A-Micro-USB-Charger-For-18650266501634014500-Battery-p-1141175.html?
19.MECO XM-L T6 2000LM Zoomable LED Flashlight
Price: $6.99
Link:https://www.banggood.com/MECO-CREE-XM-L-T6-2000lm-Zoomable-LED-Flashlight-18650-p-982570.html?
20. JETbeam Mini-1 TI XP-G2 130LM LED Flashlight
Price: $25.99
Link:https://www.banggood.com/JETbeam-Mini-1-TI-Titanium-XP-G2-130LM-USB-Rechargeable-Mini-LED-Flashlight-p-1112196.html?
21. HaikeLite MT02 XHP35 HD CW 2500LM LED Flashlight
Price: $39.99
Link: https://www.banggood.com/HaikeLite-MT02-XHP35-HD-CW-2500LM-Thrower-EDC-LED-Flashlight-p-1159444.html?
22. G301 Focus Burn 532nm Green Laser Pointer Pen
Price: $7.69
Link:https://www.banggood.com/G301-Focus-Burn-532nm-Green-Laser-Pointer-Pen-Lazer-Visible-Beam-p-942428.html?
23.Lumintop Prince SS Stainless Steel XM-L2(U2) LED Flashlight
price: $36.99
Link: https://www.banggood.com/Lumintop-Prince-Brass-XM-L2U2-18650-Waterproof-EDC-LED-Flashlight-p-1051986.html?
1. HaikeLite MT07S XHP70.2 4500LM Super Bright LED Flashlight
Price: $54.95
2. 20% off coupon for xiaomi accessories
Code: 20miac
need to wait few days, we will make preorder later
Hello, when will the button top 30qs be in stock again? “LINK”:https://www.banggood.com/4PCS-Samsung-INR18650-30Q-3000mAh-Unprotected-Button-Top-18650-Battery-p-1067185.html?rmmds=cart&cur_warehouse=CN thankyou DoNkEyConN
Hottest Deals
1. Folomov A1 Magnetic Li-ion Battery Charger
Price: $7.99
2. AC85-265V E27 4W led flame light bulb
Price: $9.99
