Lexel, have you ever messed with a Crelant CH10 head mounted light? It has a 22mm driver with the switch on the battery side so there are 2 holes for the E switch wires to go through.
Do you think you could make a narsil driver for this light?
I need to unsolder the emitter to see the component side of the driver, but haven’t done that yet.
F*!!! I think I may have just destroyed my Driver. :rage: :rage: :rage:
today I received an SMO reflector for my L6 when I put it in it had a horrible look to the beam. I was trying to focus it and I think it touched the terminals on the Led star. I now have no modes. if I use the rear switch it comes on but I have no mode selection with the side switch.
A dead short with unprotected batteries likely killed the FET, easy to repair if you send me the driver, I had one driver before that got killed that way
Removing the FET and the light is at least useable with AMCs in the low and middle modes
If the FET is conductive when you use a DMM it needs to be replaced, not sure if you can do a reflow of it on your own if I send you one
Ok I got here one Narsil 17mm build but soldered already ba accident spring and cables to it, but got an error when I tried flasing Bistro OTSM :person_facepalming:
14.5$ with temp+LVP calibration and max temperature preset,
4,85$ 47.5mm MF01 MT03 Q8 +4,85$
1.2$ LDO 1.2$ 21mm and bigger only
1$ for SRK Size with more than 8 AMC7135 Bank with all 16 AMCs
2$ envelope priority air mail shipping worldwideadds
3$ for optional tracking + insurance up to 25€
