I finally got lexel’s TA narsil driver working and i must say it is nice . I bypassed all the springs on carrier and with a fresh set of vtc6’s got 15800 lumens with 15300 @30s.
Spring on driver wasn’t doing right so i changed it to one of those like in a d4. Ihad to scrape off some mask to get it to fit.I got 16900 at turn on.
Hi guys! I have a question about my MF01 V1. On a turbo mode, one group of LEDs does not work. On fully charged batteries, everything is OK. But as soon as the voltage on them falls to 3.5 volts, then in turbo mode one group of LEDs does not shine. This problem was initially, as soon as I received a flashlight from Banggood. What do you think about it?
^The 3.5V is the resting voltage of the batteries, or the voltage under load?
If it is the resting voltage, then the voltage under load may already be under 3V, and then the LVP (low voltage protection) may have kicked in. As the driver is clearly divided in three sections, each driving 6 leds, the LVP may also be implemented for each section individually. Since the voltage readout of flashlight drivers is usually not very precise, one group may have shut-down already while the other two groups have a bit lower voltage threshold and may kick in later. This delay will be a bit extended even because one group already shut off, decreasing the battery load so that the battery voltage goes up somewhat again.
(I’m not a MF-01 owner btw)
3.5-3.6V - resting voltage of the batteries
I wrote in support of Banggood, and here’s what they said to me:
“we are so sorry we are not sure if this problem was caused by the man-made damage”
Strange support, however.
That is your issue, there is nothing wrong with the light. 3.5v is practically a dead battery. Under load it’s probably dropping to 2.8v. I’m surprised turbo would even turn on.
Using HKJ’s comparator @10A for 30Q and VTC6 results in about 3.2V~3.3V with 3.5V resting voltage. I’m not familiar with driver designs, but my guess is that LVP is built in the controller, so either all three drivers work, or all three quit, as the voltage is below a specific value.
Of course. What I wrote is also a guess. I have noticed that other people’s guesses in general lead to thinking about what exactly might be going on; and this eventually helps in better understanding what is happening inside a flashlight.
