I would advise by the same lamp with two different LEDs. Sell the unwanted.
I tried that out with the Lumintop IYP365.
The Cree is 200lm
The Nichia 219B is 140lm but CRI 90, around 4000K.
I carried both a week and used it both every time. After two days I knew I want Nichia high CRI and don’t care about less lumen in real live.
It was important to use the lights, based only on 5 minutes playing it would have been the Cree.
With a coupon you should get the IYP365 for arround $12 each. Ask M4dm4x
That lamp makes also a nice gift for relatives if you won’t sell it.
You had to do that once to know if you are for lumen or nice tint.
Same lamp, same optic to keep other factors out.
You get also a clue if you’re more NW or CW.
ahhh so you got both and the output difference is small? I just ordered the Nichia version and it’s on my way! And if I really like this light maybe I’ll see if they have any specials on the coming Holidays (Black friday, Christmas, New years/ Chinese New years etc.) Then get the XP-G3 version
Tempted on getting this light, but I’m a bit apprehensive as to the 2S2P setup (Capacity and Voltage). Besides the danger of inserting batteries in the wrong polarity, what other dangers could potentially exist from this configuration using non protected cells? I’m aware that a 4p setup (Capacity) is generally safer using non protected cells, but so far all of my lights use 2s and 3s configs and they all run protected cells.
the production lights have modified battery carrier to allow protected calls and handle reverse protection with plastic discs
4P battery carrier is even worse if you insert one battery reversed while 3 normal are already in it
Mixing full and empty cells in 4P also leads to bad things to happen, while in 2S/2P you wont ever reach reverse charging like in 4S possible, just if you over discharge a cell recycle it
Ok. Thank you for the information. I’ll most likely get this light sometime soon. I have some friends who are afraid of flashlights that use Li-Ion cells because of the bad rep of exploding. I tend to think the technology is generally safe, so long as you know what you are doing, and respect the tech. Safety first!
Seen the Nichia measured from as little as 8000 lumens, my XP-G3 MF-01 measured around 10,500 lumens, but it appears brighter as there’s not much spill. Just a big wide hotspot.
It seems that banggood is selling the LED’s MCPCB separately for 30$ but the picture is showing the spring side of the driver.
Is it a sign that BG is also going to sell the (lastest) TA’s driver ?
Wut the? They must have shlapped something up quick for someone... Probably to appease someone that had a defective LED and/or MCPCB. Can't imagine them charging $30 for a driver, but they could have provided a coupon code to a customer.. Strange though.
they are violating the open source license for sure
And this is my edited SRK design and noone asked me about it
even worse that design is so old that its missing also the ground only coming from one source so noise on LDO is reduced and it does not freak out
additional caps missing stabilising the Batt voltage
AMCs dropped for small FET and resistors
and they even do not tell if it fits V1 or V2 of the driver
but seriously a MCPCB for 30$ that you already got, no other optic will fit, so it is kind of pointless
still the question is why a BG employee has my driver picture from Oshpark
I am surprised that this was spotted and it made me chuckle. They created/sent me this link when I inquired about getting another MCPCB since one I modified has an issue. I am waiting for confirmation that it is in fact a MCPCB and not a driver as pictured.
Hi Everybody,
I bought the Astrolux MF 01for this application:
drone test astrolux light
is a total disaster , this light on high or turbo what I need the most works only 1 min,
Than is getting extremely hot and turns down the ligh to about 1000-1500 lumens (estimate )
Anybody any ideas how to cool it down to stay on for about 20 min ?
On a drone 1000 lumens is useless.
I do not know much about lights, but obviously the fake advertising get to me, I bought it from bangood.
Thank you guys, any ideas will be highly appreciated.
Well is saying on their website runtime 3.5 hours.
I am a photographer not a flashlight specialist, so I believed them.
What I cared about more was the 5000K natural light with high CRI.
Than why they will make such an insane claim if they know the flashlight will run for 1 minute only?
Thank you for the idea but I think a small fan wont help much on the drone as the flashlight is “burning”, and it already have enough airflow from the drone propellers.
Thank you again. Anybody any other ideas ?
