I have made several test fits and found out than Ф20.1mm circle can perfect fit inside stock positive contact ring.
Any ideas about proper height? 2.0mm to make it 0.5mm taller than stock contact ring?
+1 for the UF-1406 and/or 1405 pills if that’s still on the table. Can’t seem to find anything better than the light-weight aluminum crap it comes with reverse threaded in. Thanks!
Sorry, moq for threaded parts is 50pcs.
What is moq?
Minimum Order Quantity
Thanks, that makes sense. Has the demand been anywhere near 50 or much less? I feel like these are popular lights, especially to mod. And the only pills available are really crappy aluminum
Near zero.
Does that mean I have to order 50 pieces to get it? Or you have to have 50 people interested in it before you make them?
Very interesting looking , reminds me of the Lux-RC FL33 :
Quad or triple ? and what tube will it fit ?
Let first make it real
If that is what I think it is, it will provide amazing sustained brightness/size paired with a well regulated driver, can’t wait to know more!
Yesterday I received an order from kiriba-ru (1 Copper pill triple Convoy S2+ – custom retaining ring, both pill and ring have milled cuts; 1 Copper spacer for Carclo triple Convoy S2+). Took 21 days to arrive at my house (Portugal), tracked package.
I’ll use these for 1 or 2 triple builds I’m planning.
Just wanted to show some pics in order to compare it with a regular S2+ Pill, as it may be useful for those intending to make a mod
Quality is excellent and this really got me pumped to get the rest of the components, as I think this pill will be a beast in functions :sunglasses:
Some points I’d like to mention:
- The retaining rings are different, but each one fits perfectly the other pill, no threading problems;
- The pill fits perfectly on the 4 Convoy S2+ I have, threading perfectly as well;
- The spacer is solid and well built, and will imply a mod in the “regular” pill (drilling its center for the wires), but they match perfectly.
I want to thank to kiriba-ru for the nice work done in here! Keep it up
receive my order.thank you
TWO SPACERS ,s2+,s3
ONE SPACER,convoy s8
ONE Copper spacer Astrolux S2 ,Ledil Cute-3 triple
ONE,P60 copper quad drop-in – Surefire non-compatible, driver press fit/solder version
ONE Q8 positive driver rings
ONE,Aluminium spacer+liner set for Convoy C8 Cute-3 triple
ONE,Ledil Cute-3SS C11333 triple TIR for C8
TWO,Carclo 10622 24mm quad Narrow Spot Plain TIR for P60
This is not lottery, just teaser.
Recieved my U11 spacer setup on Friday. Excellent quality and awesome packaging. Will post pictures when the rest of my parts arrive. I will be ordering more parts soon!
