Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17431 posts / 0 new
joechina
Last seen: 17 hours 27 min ago
hank wrote:
Yes, that’s normal. The green light under the switch stays on, normally.
So the switch LEDs work.
Maybe you switched it off in the Advanced Config Settings?
The first one “Locater Led Feature” does this.
You can try to switch it on again or reset the lamp to the default settings.
Reset to factory in RAMPING:
The lamp can be OFF or ON:
3x, 2x, 2x, press&hold (for 1.2sec) till 4 blinks
Reset to factory in MODES:
Only from OFF:
1x, click&hold (for 2.5 sec), 2x, 2x, press&hold (for 1.2sec) till 4 blinks
There is a newer cheat sheet under
http://bit.ly/narsil-cs
With few more notes on NarsilM.
you probably need Q8 v10
The Q8 v12 is for firmware version v1.2
Dusty
Last seen: 12 hours 31 min ago
Only from OFF:
Yeah try that ^ much easier
Bug
MtnDon
MtnDon's picture
Last seen: 5 min 13 sec ago
Or do a factory reset….
Restore to Factory Settings
This is a feature, undocumented in the user manual, that will restore all configuration settings to factory defaults, in the
state as originally shipped. It comes in handy in case there’s any doubts of how the light is configured. To access this
feature, while displaying the firmware number (dbl click for voltage display, then dbl click for temperature display, then
dbl click for version display), press&hold the switch until the light blinks quickly – this acknowledges the configuration
settings have been reset to factor defaults.
saypat
saypat's picture
Last seen: 1 week 1 day ago
yes, do the simple restore to factory settings as stated above. After doing this, the green LEDs should be ON! If not, you have a problem as others have had.
Johnsonbrook
Last seen: 8 months 1 week ago
SebaZ74 wrote:
Ok, but she stay a few hours and leds in switch still is green, this is normal ?
Yes. It’s on all the time the light is off. You can lock out the light with four clicks if this worries you. Then four clicks to turn it on again.
SebaZ74
SebaZ74's picture
Last seen: 1 week 6 days ago
Works ! Thank You Very Much for All Smile Great flashlight Smile
FreeMagenta
Hmmm…
My second Q8 arrived today. However it looks like it has a switch LED problem (unstable light), also sometimes in modes (i.e. ramping disabled) there is a second or two seconds delay between pressing the button and brightness increase.
https://www.youtube.com/watch?v=hk04HQEyY6Q – switch LED problem
https://www.youtube.com/watch?v=a5HJyW2hvgo – delay after mode change
BrianK
Still loving the Q8! Despite using it as much as possible and even as a nightlight in lowest moonlight mode every night (ceiling bounce) I have difficulty getting below 4.0v after using it for 2 weeks at a time. I guess I need to let it scream more often. Despite my frustration at it’s efficiency when used below 2 flashes of the switch LEDS I’m going to compound my frustration by switching to GA cells from the 30Qs for even more runtime. Big Smile
Really nice job Q8 team! Please frustrate me some more. I eagerly anticipate my further frustration with Giggles and the FW3A.
But despite my use of the Q8 in it’s more efficient mode it’s nice to have the light output on tap when I need it.
FWIW, I have yet to hear any negativity regarding the Q8 from anyone I’ve given one to. The reports I have gotten back, everyone who sees it and what it’ll do asks where they can get one. Thumbs Up
Very appreciative here and I hope that comes through.
Just an aside… We entered the realm of Li-Ion cells and LED lights from old tech SunLite SL-6s and NiMh cells. This forum has been nothing but gold in leading the wife and I to really great replacements for the SL-6s. The BLF designed lights are simply superb. I couldn’t be happier with what the movers and shakers on this forum produce. The wife, she accepts my passion and is happy with a C8 since it’s so much more than the old SL-6s. Time and Tech’ march on and I dip my hat to you folks. The SL-6s were good in their day, 20 years ago. But our older eyes today need more illumination. It must have been the pits to be older folks not even 20 years ago and not have todays Li-Ion and LED technology, or not have access to the BLF with it’s affordable hotrod lights. Again, a dip of my hat. I greatly appreciate what you folks do for us. So do my dogs. They haven’t gotten into a porcupine since we got the new lights. They work so much better than the old SunLights.
JasonWW
JasonWW's picture
Last seen: 19 min 59 sec ago
Now that all the Q8 stuff has slowed down, has there been any thoughts on offering it in a cool white or warm white version?
Click this to go to signature links.
d_t_a
Last seen: 2 days 18 hours ago
Just received email from Banggood that the BLF Q8 I pre-ordered is now shipping (originally expected shipping date is Dec. 5, so it seems they got them earlier)… Hope I can get them in a couple of weeks, but isn’t it suggested to use button-top batteries for the BLF Q8?
For now, my only button-top 18650s are protected NCR18650B (good thing I bought some before the Liitokala Official Store in AliExpress stopped shipping to our country). The only other ‘genuine’ 18650s I have right now are Samsung INR18650-30Q and LG HG2s. Are the protected NCR18650B (button-top) usable for the BLF Q8? I read that the INR18650-30Q do not make sufficient contact and is not recommended for the Q8. How about the raised flat-top LG HG2? Will the protected NCR18650B be high-drain enough for the BLF-Q8? (I’ve tried the protected NCR18650B on an Astrolux S41S Nichia219 w/ 18650 tube and it automatically shuts down when on ‘Turbo’ or even on ‘High 2’ mode).
Having a hard time getting button-tops since most store in AliExpress have also stopped shipping — I found a few ‘not-so-well known’ (ie. lower feedback scores) stores that still sell the branded 18650s button-top, but I’m wary if they are genuine or not…
bella-headlight
Last seen: 1 month 3 days ago
FreeMagenta wrote:
Hmmm…
That first video, showing the indicator led“s flickering, is just how my batch 1 Q8 behaved before the indicator leds died completely.
Light works fine but indicator leds dead.
Ian
JasonWW
JasonWW's picture
It depends on the protection circuitry that was installed. Do you know what company added the protection circuit or at least where you bought them from?
This is only in reference to the factory flat top cells. If it has the added button top or raised flat top, then it is fine.
BTW, any flat top cell can have a solder blob added to raise the positive end.
Should be fine.
d_t_a
Should be fine.
The protected NCR18650Bs are from here:
https://www.aliexpress.com/item/2PCS-lot-New-Protected-Original-Recharge...PCB-3-7V-For-panasonic/32360453063.html
The description only says: “The PCB use 2*MOS protection board, maximum power voltage is 4.2V, the minimum voltage of 2.5V”
I have tested this (freshly charged) protected NCR18650B on Astrolux S1 (ie. BLF A6) and S2 (ie. BLF X6v2), they do not trip even when set to Turbo mode.
However, I just got the Astrolux S41S quad-Nichia, and when freshly charged, the said battery trips (turns on and immediately turn off) on Turbo and on High-2 modes.
Any idea what are the parameters/characteristics of the “2*MOS protection board”?
My INR18650-30Qs are the unmodded flat-tops. Maybe I’ll use the unprotected LG HG2s then…
Thanks for the response!
How many amps is the highest current draw of the stock BLF Q8 (I believe that’s being shipped is the newest revision)?
JasonWW
JasonWW's picture
I don’t recognize those particular cells. Just saying “2 MOS protection board” isn’t enough information. I know the higher rated boards (8A to 12A) tend to use 3 mosfets, but without specific details we can’t say for sure what the max current is.
It says output is 600mA, but that might be a typo. If it said 6,000mA then that would be 6 amps and is about the rating I would expect.
From some quick searching I see that the S1 light can draw 4.5A on unprotected cells and maybe 3.5 using protected.
The S41 can draw 9 amps with an unprotected cell. I can’t find any data about the amp draw on High 2. I wish I could so we would get a closer idea of this batteries limit. I would guess that High 2 is maybe 5 to 6 amps.
So we know it can deliver at least 3.5 amps, but not 6 amps.
The Q8 on 4 cells can draw 16 amps with unprotected cells. So maybe 13A to 14A using protected cells. That is 3.5A per cell. You might be okay using those protected cells on the Q8.
BrianK
Jason, if the cells won’t put out the amps the light calls for, it will still power the light just not at maximum output, correct?
JasonWW
JasonWW's picture
That seems to depend on the way the protection circuit is built. The protected cells d_t_a linked to obviously cuts all power if the amp draw exceeds the added protection circuits limit.
Then there are other circuits that will limit output instead of turn off. On my L6 it will draw 17A to 18A with unprotected cells, but my KeepPower protected cells will simply limit the amp draw to about 10A instead of shutting off all power.
So it really depends on the added circuits.
To answer your question, let’s say you had protected cells that only had a 2A limit then it cuts power. Four of those in the Q8 would limit the total amp draw to 8 amps. You would still be able to use the light at lower levels, but once you ramp it up to about 3000 lumen the lamp will cut off. So it’s usable, but annoying.
One thing I will say is that these protection circuits always increase the internal resistance and on a fet driver they will always pull less amperage than the same cell without the protection circuit. Assuming the amp draw does not exceed the limit of the protection circuit.
Oh yeah, if I were running protected cells in a Q8, I’d make sure and get some that are tested to do at least 5A. That should be fine for a stock light.
BrianK
Thanks. Understood.
d_t_a
Thanks for the detailed explanation, JasonWW.
I think my flashlight IQ just leveled up! Wink
FreeMagenta
I am using those:
https://www.banggood.com/4PCS-NCR18650B-3_7V-3400mAh-Protected-Rechargea...
Compared to 30Qs, the output is like 250 to 300 (lux @ ceiling bounce) , so I suppose it’s good 4,5k lumens.
bella-headlight wrote:
FreeMagenta wrote:
Hmmm…
Shall I ask BG for replacement LEDs/driver? Or someone here wants to look at it?
After a night rest, leds were good. But after 1hour green light began to blink again.
JasonWW
JasonWW's picture
FreeMagenta wrote:
I am using those:
Are you referring to the batteries d_t_a linked to?
They do not appear to be the same. Different button top size, different button top ring, different sticker on side. I’m pretty sure the protection circuits where added by two different companies. Most likely different circuitry added.
Bob_McBob
Last seen: 2 hours 39 min ago
I killed a cell doing this runtime last night, so everyone can enjoy my fuck-up. This is with GAs and thermal management disabled because I normally use it outside where it’s too cold to matter. Let’s just say it got rather hot.
MRsDNF
MRsDNF's picture
Last seen: 17 hours 26 min ago
Are you saying heat killed the battery Bob? I have done lots of testing with run time tests with thermal management switched of with 30Q’s in the Q8, yes the light does get extremely hot but I’m yet to kill a battery or damage any other components in the light.
FreeMagenta
JasonWW wrote:
FreeMagenta wrote:
I am using those:
I know, just posted an example of NCR18650B’s that works in my Q8 without problems. A little less light than 30Qs, but longer runtime.
I wonder what happened in the second Q8…. while problems with switch LEDs were happening already (though I got Q8 from the second batch, after September production stop), the delay in mode switch is pretty strange.
Bob_McBob
I’m not sure what happened, but one of the cells was dead after the test (reading 0.8V right now and dropping). They are new flat top GAs, but I haven’t had any issues with uneven drain. The light did get rather hot.
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 1 day ago
I had some liitokalas failing sone moths ago , out of the blue . They just turned 0.1V after one or two days after they were charged . One of them was inside a light (not a parasitic drain issue) , the other not . Still a mystery what happened…
SIGShooter
SIGShooter's picture
Last seen: 13 min 2 sec ago
The flat top 30Q’s that I had worked in my 2 Q8’s even before I soldered some 14 gauge wire (bent into a small circle) to the top of them. The only reason I added the wires was that I was concerned that the wrapping would be ripped off the top of the batteries when the body was screwed down. Solder blobs work just as well but I like the look of the wires so that’s what I always add to the flat top’s to raise them.
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
Mr Excitement
Last seen: 2 months 4 weeks ago
I made a diffuser out of a sauce bottle. After you cut the top off is is a push fit. Big W and Spotlight carry these in Australia. I also put a small convex blind spot
mirror in the bottom to block light from going straight out the end, and reflect it downwards and outwards.
blinker
Mr Excitement. lol cool
Not a flashlight guru, but like them just the same.
Misspellers of the world UNTIE!!!
Mr Excitement
DavidEF
DavidEF's picture
Last seen: 22 hours 19 min ago
NICE! Crown Thumbs Up
- The YKK Philosophy
