I just came across my first post on BLF, incidentally it was about watches.
Here’s the same watch, five years later. I have been wearing it daily since I bought it and it is holding up very well. The sapphire crystal is still as new and the black PVD coating on the chest is looking great too, just some slight wear on the edges but that has no influence on the neat appearance. I had the battery replaced once and while at it the 10atm waterproofness was tested as well and found ok. The brightness of the trits after 5 years and 3 months I calculate at 84% of original brightness at the purchase date, so they are not noticably dimmer yet. The cheap strap has suffered more, the black PVD coated titanium bits have been worn some and near the buckle the nylon has frayed a bit, but it still is good enough: slightly worn but not shabby.
This is looking like a high-end version of my Traser P5900. I especially like the coating because the stainless steel bezel is way too bright for a “tactical” watch.
If someday I can replace the P5900 then I guess it will be the simplest coated G10…
Its a nice watch. And after 5 years she/he deserves a new strap. I like the straps from cheapestnatostraps.com. They also have pvd straps. Buying new straps can be pretty addicting to.
I actually believe that the watch plus strap looking slightly worn achieved some glory over the years, so I just keep the strap like it is. Once it really starts looking ugly I will buy a new strap (and probably the same type, for me straps apparently are not like flashlights )
So the stainless steel bezel is too bright for a “tactical” watch but it doesn’t matter if all of the tritium vials are glowing all night long am I right?
That glow is so dim, I wouldn’t worry about that, but that’s not my “problem”. I don’t use it in a tactiacal way, obviously, I just never really liked this shiny bezel.
Stoneashed would be better to hide the scratches.
Could it be possible (for a watchmaker) to remove the glass and put it back in after stonewashing?
After removing - putting back the glass you should have the watch tested for water resistance. That’s another expense. IMO this stone washing project is not worth the effort.
Why don’t you try to add some brushed/satin finish by steel wool first?
So you have a decent water tight watch with a nice contrasting bezel and you want to risk all of this just for a slightly different look. I would reconsider this in your shoes.
Bead blasting looks nice. Here’s my bead blasted Seiko 5:
My Braun BN0106 that I got from Amazon UK for £112. Battery was flat so I got them to knock off 15% (£16.80….) then bought five new cells for £1.50 and fitted one myself in ten minutes……
It’s a gorgeous display mate - really smooth digits. A lovely blue backlight if you need it at night, although to be honest the negative display is really very legible even in pretty low light. These often retail for silly money - certainly several hundred pounds - and I’d admired their retro simplicity ever since I got into watches I suppose. So when I saw this offer it was just too good to miss. Plus I had an Amazon voucher which was burning a hole in my pocket anyway. All in all I am utterly chuffed, it looks really cool and the strap is really industrial and spartan. I love it.
