Hello buddies, new releasing again, let’s go
X7S: Multifunctional Capsule Flashlight and Lighter Kit
· Material: Stainless steel
· Patented EDC Capsule Flashlight and Lighter kit
· Mini and match flexibility allows you to create a keyring or penlight sized
flashlight; a mini or pocket sized lighter,and a single or double pill box/
battery capsule
· Flashlight utilizes CREE XP-G2 LED, max output up to 130 lumens
· Powered by 10180 Li-ion rechargeable battery
· Max runtime up to 6 hours
· High & Low lighting modes
· Head twist switch
· Micro USB recharging with indicator
· Tail stand capability with keyring attachment point
· Micro liquid fuel (gasoline/ petrol) lighter, with pocket clip
· Capsule can be used in one or two sized storage spaces
· Capsule for storage pills or 10180 battery
· CNC precision machining
· Anti-corrosion and high hardness
· IPX8 water resistant
NOTICE:
a: The Lighter excluding gasoline
b: To refill gasoline/ petrol (unscrew the lighter’s cap, pull up lighter’s
reservoir insert for refill)
c: Use only good quality lighter fuel and flints
Flashlight Specifications
· LED: CREE XP-G2 LED
· Output: max 130lm
· Battery: 10180 li-ion battery
· Charging way: flashlight with build-in micro USB port, can be recharged by micro USB cable
· Charging time: full charged in 1 hour
http://mecarmy.com/product/details/237/291
Go buy from our dealers if you like it
