Convoy L6... XHP70 Beast!
try the code “cl6gift” on gearbest, works for me on the black version… and i dont think u want to run this light with 18650.
Has anyone tried these Keeppower 27700 batteries in this L6?
http://www.keeppower.com.cn/products_detail.php?id=554
I’ve got older Keeppower 26650 with protection, and they quite tight. Since i have understood this new 27700 is about the same size as normal protected 26650, i think it might fit, but i’m not sure.
Those are protected cells so they’re likely to be as much fatter as the 26650’s that you found tight. I’d venture a guess that they won’t fit the L6.
With a rated 10A continuous discharge I don’t know if they’d drive the L6 like many of us use it. A stock light, should probably be ok. You might could hone the inside of the battery tube and get a snug fit, you’d have good run time with a stock light and 5700mAh capacity.
[quote=mortuus]
Why not? If you get a good set of spacers (Simon sells them), the only downside as far as I can see would be less runtime.
For those awaiting a good deal on the L6, it’s around $45 right now not sure BG or GB-…
Check the various deals/coupons and codes threads.
Edit: i must have dreamed it… can’t find it anymore. :person_facepalming:
Edit2: now i’m sure i’ve seen it. I actually wondered wether i would rather get another Q8 instead as they were about the same price - at that instant. Probably during that “black” weekend frenzyness.
Right now on GearBest it is available for 42.51€ (roughly 50$) with FinGB30 code.
Had the clear L6 and 26650 unprotected KeepPower black listed in this thread were just right in L&W.
Just got a Black L6 today to replace the modded Clear I sold and the same KPP black are pretty tight on OD.
I really doubt those 27700 are going to fit in either direction, especially if protected.
You weren’t dreaming, it was around Nov 15th. I got a CW Black one for bout $45. I was in the market for one for a while and think it is the best price I have ever seen.
It just arrived today. Will mod it soon.
I know the recommended battery for the L6 is generally the Keeppower ICR26650 5200mAh, but looking at HKJ's test it is very easy to find better performing cells. So I'm a bit hesitating. Why the KP ICR is considered the best match? Apart from size consideration, is it only because of its protection's circuitry, making it a safer choice for 2x configuration?
I’m not sure where you heard that, but the recommended battery for the L6 is the Liitokala.
Maybe as far as protected cells are concerned, the top choice is the KeepPower 5200.
It's listed in first post of this thread at least two times and it is repeated in various other forums. Does the Liitokala exists with protection?
It’s been a long time since I read post one. The last update to it was 11 months ago. It does seem to be biased towards safety and not towards performance. For newcomers the protected cell is recommended.
Most folks here (modders) don’t run protected cells, though. They can’t, because they just don’t produce enough output.
My modded L6 pulls 17 to 18 amps with the Liitokalas for about 8,500 lumen.
It only pulls about 10 amps with the protected KeepPower 5200 for about 6,500 lumen.
That’s a big difference and clearly seen with your eyes. It’s also why almost all L6 modders use unprotected cells.
If your light is stock and you are worried about safety stuff then stick with protected. It is fine for lower powered lights. In fact, Orbtronic makes a 26650 protected cell with a 15 amp rating. I don’t know if it cuts all power at loads over 15A or just limits the load like the KeepPowers do.
Everyone using unprotected cells in series just need to follow a few safety rules. Always use a matched and married set and always check that the voltages are identical before charging.
Liitokala does not make protected cells.
I hope that helps.
Eh doesnt simon himself recommend to use keeppower icr? not that u must but i never heard that litokala was the main battery choice for this light and ive read almost the entire thread of this massive light. I will myself tho use efest batteries for this light once it arrives.
I guess this particular thread is mostly about the stock L6.
If you read this thread you get a very different battery choice.
L2 and L6 Modding Thread
It’s a matter of choosing what is best for your particular situation.
This thread kinda swings both ways from what I remembe. Mainly because Simon recommends Protected cells on his site.
Most members here do not want protected cells, including myself, and Jdub managed a deal with BG early on for the black unprotected Keep 5000mAh. I bought those for my first L6 because I intended to mod it.
But seriously consider measurements with any cell you may buy. L6 is pretty picky on diameter and length and the tops of cells need to be high enough to contact the other cell in series.
Convoy recommend the 69.5mm protected Keeppower (which as far as I’m aware is actually INR, not ICR as commonly thought). I doubt that in the stock L6 there would be any significant difference in performance between the protected Keeppower and unprotected Liitokala.
There’s not. I tested it.
I actually got a bit higher amps on the brightest setting with the KP for some reason (it might be an anomoly), but as soon as you resistor mod it, the Liitokala has the advantage. Then with a FET driver the Liitokala has a much bigger advantage.
The Black LiitoKala 5000mAh 26650 or the light blue one are the best cells for the L6. Hands down.
Edit: Unless you want to adapt it to iJoy 21700’s. :wink:
*If you want high drain and unprotected.
That wasn’t the question, not a matter of what someone wants the question read which is best. :wink: :smiley:
