Features
Emitter: CREE XPL HI LED (CW and NW for your choices)
Maximum 420 lumens output, power by 1x AA battery
Maximum 800 lumens output, power by 1x 14500 battery
Driver: Most efficiency constant current circuit, maximum runtime up to 300 hours
Material: Aircraft-grad 7075 aluminum body
Surface treatment: Premium Type III hard-anodized anti-abrasive finish
Clip: Titanium coated stainless steel clip
Lens: Toughened ultra-clear glass lens with anti-reflective coating
Reversible & removeable Stainless Steel Bezel
Forward Clicky Tail Switch
Dimensions: 105mm (length) x 35mm (Head diameter)
Weight: 45gram (without battery)
Accessories: o-ring *1, lanyard *1, pocket clip *1
Brightness levels & Runtime:
Powered by 1x 2500mAh AA NiMH battery
Working voltage: 0.8v-1.6v
Moonlight 0.5lm 300hrs,
Low 5lm 13hrs,
Middle 58lm 5.5hrs,
High 220lm 1.5hrs,
Turbo 420lm 1.3hrs.
Powered by 1x 3.7V 750mAh 14500 battery
Working voltage: 2.7v - 4.2v
Moonlight 7lm 90hrs,
Low 45lm 12hrs,
Middle 100lm 3.5hrs,
High 270lm 1hrs,
Turbo 800lm, 0.5hrs.
Operation:
Forward clicky tail switch,
On / Off: Click for on and off, 5 output mode in total.
Change modes: click within 0.64 second to change modes,
the light will memory your last mode if the time get over 0.64 second between two clicks.
Manker Torch Club; wasn’t this Manker’s first light? And if I’m not mistaken, this light was also made from 7075-T6. Could you please tell me why Manker chose this alloy instead of the more conventional 6000 series aluminium?
Will you offer a smaller and floodier version of this light? I’d buy 3 if it was made, best AA flashlight ever!. Would also love something like the Trunite Archer 1A V3 but with your awesome driver
