Dual Switch (Teeterboard switch) USB Rechargeable Compact Flashlight
· Dual switch Compact flashlight with USB rechargeable function
· Uses CREE XPL-Hi V3 LED, lifespan up to 50,000 hours
· Momentary ON function
· Instant access to Turbo/ Strobe
· Quick charge in just 90 minutes
· Standard Micro USB Charging port, charges on any USB port
· Charging and fully charged indicators
· Magnetic tailcap provides versatile hands free operation
· Detachable clip
· Over-heat protection to avoid high-temperature of the surface
· Rugged pineapple texture for grip and anti-roll
· Constructed from aero grade HAIII hard-anodized aluminum alloy
· IPX-8 water resistance
LED: CREE XPL-Hi V3 LED
Dimensions:
FM16: Length 99.2mm x Head 29.2mmx Body 23.3mm
Length 3.905” x Head 1.149”x Body 0.917”
FM18: Length 133.2mm x Head 29.2mm x Body 23.3mm
Length 5.244” x Head 1.149”x Body 0.917”
Charging: Micro USB rechargeable, with red/green charging indicators
Accessories:
FM16: User manual, 1*16340 Battery, O-ring, lanyard, USB cable
FM18: User manual, 1*18650 Battery, O-ring, lanyard, USB cable
Notes: The 18350 battery here we mean traction battary like IMR, INR. Which will have higher output than normal 18650
Our international dealers will receive all new items around 15th-20th December.
