Olight S1 Mini teardown
45 posts / 0 new
-X3-
-X3-'s picture
Last seen: 1 day 2 hours ago
EDIT : The simplest way of doing it is to drill in the optic and light the bezel with a tiny flat screwdriver.
The optic will be ruined, but you can swap it with any 17mm optic from Yajiamei on Aliexpress.
Everything else will be saved, so don’t think twice about it.
Original post :
Yeah, I know I can’t help but destroy everything…
Still, I finally got to open the brand new S1 Mini that Oligth sent to me…
I’ve received two S1 Mini today : HCRI XP-G3 and XM-L2 CW so I decided to sacrifice the HCRI to see what could be done with it.
Let’s be honest, this one is NOT modding friendly AT ALL.
I had to decide that it could possibly never work again after this operation but I still wanted to show everyone if it could be done.
IT CAN.
Steps :
- remove battery
- pry the button bezel (you’ll scratch the light for sure…) with a blade
- remove the rubber button
- remove the black plastic washer in the battery tube (protecting drivers components)
- push the driver by the switch opening to TEAR THE WIRES (really, or maybe unsolder them but I never saw a thin enough soldering iron…)
- remove the driver
- remove the remaining wires to free the two holes from the LED shelf
- put some thin pliers down in the battery tube to allow pushing the optic through the wires holes
- HAMMER ! well, I used a wall to tap against the pliers handle, thus push hard on the optic (that will let some scratches under the optic…)
- DONE
Pics :
Alu MCPCB… we’ll see if I replace it.
Now I have to choose an emitter, I think it’ll be a 219C 3500K 9050.
I don’t want to open it again…
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Edited by: -X3- on 01/30/2019 - 03:14
CRX
CRX's picture
Last seen: 1 hour 5 min ago
Thanks Thumbs Up
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 13 min ago
Ouch. This is approaching Zebralight levels of mod-unfriendliness. Or perhaps it’s even on par now?
maukka
maukka's picture
Last seen: 1 day 8 hours ago
Thanks for your determination!
While I understand the design choices by Olight to make this thing as short as possible, I’d prefer the lights come with a disassembly manual and tools Wink
Interesting to see how the optics work with a Nichia. Would actually be nice to see several different emitters tested with it (Oslon, Luxeon, Samsung…) before you put it back into the light for good.
-X3-
-X3-'s picture
I could try Oslon square, 219B, 219C, XP-L, XP-L HI and XP-L2.
I’m not sure to use the light in the end, so I’m not in a hurry to re-assamble it.
BobbyMK
BobbyMK's picture
Last seen: 5 days 6 hours ago
WOW, you’ve done some risky business trying to open the light. One wrong move could made the light useless, at least in stock form.
Ill probably stay away from this one. I just cant risk it. To expensive to ruin it.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
Geuzzz
Geuzzz's picture
Last seen: 18 min 7 sec ago
Thnx, x3. Conclusion if you want this light, hurry and buy one of the discounted old s1 mini’s.
jon_slider
jon_slider's picture
Last seen: 34 sec ago
X3 wrote:
I could try Oslon square, 219B, 219C…
I await your success!
fwiw
the Ti SMini is on sale here for 30% off w code blacknovember
also
the black copper s mini is on sale for $35, no code required
but neither has the XP TIR, so no Nichia..
some people don’t mind CW, and others are fine with Low CRI NW
Im tempted by the Copper SMini, but low CRI is not my thing.. and I have concerns about its Flicker Index.. I also wish it had the low battery warning of the Aluminum SMini.. in fact, I wish it had the battery level indicator of the Klarus Mi1c too..
but my buy it now finger is twitching, sometimes it does not respond to reason Smile
"High CRI lights for sale":http://budgetlightforum.com/node/72660
Geuzzz
Geuzzz's picture
Do it! The olight tir in the s mini gives a real useful edc / close range beam. Love my Smini ti with 5D 80+cri emitter.
MastyrOfPuppitz
Can you post a pic with the lens face down taken from above and to the side?
-X3-
-X3-'s picture
-X3-
-X3-'s picture
So I’ve done a couple of test, with different emitters :
219 B : Beautiful beam, no artifact
219C : beautiful beam, no artifact
XP-L HI : beautiful beam, no artifact
Oslon square : beautiful beam, no artifact, narrowest beam (due to smaller emitter surface)
I’ll go with a 219C Smile
maukka
maukka's picture
Thanks for the tests! Now, where can I send my S1 Mini to be improved? Wink
jon_slider
Outstanding! Thanks Smile
I will take a CuSMini with the High CRI TIR and N219b 4500k 9080 please.. where do I send the check?;-)
-X3-
-X3-'s picture
Well… I’m still stuck with a non working S1 Mini, so I can’t make any promise but we’ll see how I can make it work Wink
If only we could source this new TIR alone…
MastyrOfPuppitz
Can’t see a second image, just a “no” icon. Was it an overhead from an angle (in stead of straight nine onto back? If so can you repost?
somnambulism
Last seen: 7 months 4 weeks ago
Oof, I was hoping it would not be so troublesome to mod this.
-X3-
-X3-'s picture
So I managed to fry the driver… don’t know how, but it doesn’t work anymore.
I opened my S Mini Ti (my EDC), dropped the XP board from S1 Mini with a 219C reflowed on it, put the new frosted XP TIR and have now the pefect EDC.
Nichia tint, Olight UI !
jon_slider
X3 wrote:
I opened my S Mini Ti (my EDC), dropped the XP board from S1 Mini with a 219C reflowed on it, put the new frosted XP TIR and have now the pefect EDC. Nichia tint, Olight UI !
Congrats!
jealous with admiration
When can I get one in Copper?:-)
somnambulism
You and maukka gave me such low expectations for this light that it turns out to be not as bad as I thought! Still disappointing, but not as much as it would have been otherwise. Do you think you will be able to come up with a non-fatal way to mod this?
jon_slider
X3 wrote:
… I opened my S Mini Ti (my EDC), dropped the XP board from S1 Mini with a 219C reflowed on it, put the new frosted XP TIR and have now the pefect EDC.
Perfect!
I ordered a Copper Smini, now I just want to wait for a sale on the High CRI donor.. Smile
Im not sure I can resist long enough..
-X3-
-X3-'s picture
The only way to know is to accept the sacrifice of my second one…
That will come, because I ate the CW tint anyway and I don’t see me selling it…
To be continued, but i need a pause because frying the driver was a bit heart breaking Crying
ToyKeeper
ToyKeeper's picture
I wonder what it would take to get Olight to make an aluminum S Mini (not S1 Mini) with the S1 Mini’s frosted TIR, 4500K-4750K Nichia 219 high-CRI emitter, and my Anduril firmware.
(probably also no CR123A support, only 16340, could even come with the same cell as the S1 Mini)
joechina
What is the difference between the S Mini and S1 Mini?
maukka
maukka's picture
-S1 Mini is aluminium, S Mini is copper or titanium.
-S1 Mini has a tailcap magnet
-S1 Mini comes with a usb rechargeable 16340
-S1 Mini has a dual way pocket clip
-S1 Mini has a battery/lock indicator on the side switch
-S1 Mini is a fraction of a mm shorter
-S1 Mini has a marginally higher output (640 vs 580 lm in my testing)
ToyKeeper
ToyKeeper's picture
I like the clip on the S Mini better than the bigger 2-way clip on the newer model, and I like the old square knurling design more than the staggered lines. It’s a bit longer, but the extra length at the front goes toward protecting the optic. I also kinda prefer it without the magnet, though I don’t care much either way.
The things I like more about the S1 Mini are the lighted button, the choice of two different optics, and the low-battery detection (finally). It’s also nice being able to get it in aluminum, which is generally cheaper and has a good balance of weight and thermal properties.
They’re already good, but it would be nice to combine the best parts of both and upgrade a few other things…
joechina
thanks for the answers
We need a special BLF edition:
- a deeper bezel to protect the optic with two little notches for easier disassembly
- two clips to choose
- two tailcaps to choose
I would vote for the new knurling
jon_slider
any new developments that could lead my Olight Copper S Mini to Nichia Nirvana?
or is Sacrificing an Olight S1 Mini High CRI, still the OnlyWay to Enlightenment?
coherent-rambling
Last seen: 1 month 1 week ago
Sorry for the thread resurrection, but I got an S1 Mini cheaply and am itching to take it apart. I have a question and an observation.
First, Yajiamei 17mm TIRs fit in an S Mini; I’d assume they will also fit in an S1 Mini. I suggest the 20° Beaded as the smooth versions project a square.
Second, does drilling/breaking out the optic seem like a viable way to get into the S1 Mini without risking the switch and driver? You’d still have to figure out a way to pry the retaining ring loose, but you could do that on the ring itself and work from the back where scratches would be hidden.
-X3-
-X3-'s picture
Yes, the Yajiamei optics fit.
Drilling the original optics and prying the bezel is the easiest way, I should have done that instead.
pc_light
pc_light's picture
Last seen: 3 days 2 hours ago
Getting to the emitter via the lens is definitely a viable approach, it’s the approach I took here.
The photo from -X3’s teardown (OP above) of the 5500K CRI model appears to rest the optic on a LED spacer -
My experience with the 6500K (non-CRI) has the optic sitting in a retaining cup. Something to keep in mind if drilling/breaking out the optic -
Seeking the light.
