Test/review of Charger GyrFalcon All-88 2017 (Enova)
Enova has updated their universal 8 slot charger.
The cardboard box lists a lot of specifications for the charger.
The box included the charger, a power supply, some accessories for special battery sizes and a instruction sheet.
The accessories are spacers for handling small batteries and some extensions for the plus connection for handling C, D and 32xxxx size batteries
The extension in use.
The DC input is the usual barrel connector and it is rated for 12V input at 4A.
The display has many elements on it, because the charger can handle many types of cells.
One this image the charger is in automatic mode, i.e. it is not possible to select voltage, that will be done automatic and only NiMH and 4.2V LiIon can be charged. (Hold down Fn and CV for some time to switch between manual and automatic)
In manual mode it is possible to select both voltage and current for each slot:
Press button for slot to select it.
Press button for slot again to select voltage.
Press CV to select current setting.
Press button for slot to select current.
Press CV to select voltage setting again.
Hold button for slot down to start charging.
Start a slot (Method 2):
The above methods are rather long if you want to charge many cells, the charger has some shortcuts to handle that:
Hold button for charging slot down and tap button for other channel will copy the settings and start charging on the other channel.
Hold Fn down and press CV will select 1A and 4.2V charge voltage for all idle slots, pressing multiple times on CV will change voltage.
These short-cuts means that charging any number of (4.2V) 18650, 26650, 32650 can be started by holding Fn down and tapping once on CV.
Charging any number of AA can be starting by holding Fn down and tapping CV twice.
The C.A line shows selected current and is also used to select current when the “>>” marking is at this line.
The V.V line shows selected charge voltage and is also used to the select voltage when the “>>” marker is flashing at this line.
The battery icon is animated when the charger is charging.
The display will automatic dim after some time, any button press will bring it back to full brightness.
In this image adjustment of current is select (>> is at the C.A. line).
The sliders work very smooth and can handle from 30.2mm to 71.7mm, up to ø26mm cells can be placed in each slot and it is possible to use ø32mm cells in each other slot when the extension is used (Only two supplied). For NiMH extension must be used for both C and D cell.
Due to the wide slots, care has to be taken with thinner batteries to get a connection.
Using the “Extensions” both C and D cell can be charged.
With 10180 cell the 100mA charge current is on the high side, but because most 10180 are high current cell it will usual be acceptable.
C, D & 32xxx cells can have trouble with the plus connection, using the small extender will fix this.
Measurements on charger
  • Power consumption when idle is 0.8 watt with display off (1.4 watt with display on).
  • Will discharge a LiIon with 0.1mA when not charging.
  • Will discharge a NiMH with 0.15mA when not charging.
  • Will not charge at 0 volt.
  • LiIon charging start at about 1.0 volt with a few mA.
  • NiMH charging start at 0.7 volt with selected current.
  • Ib automatic mode it will assume LiIon above 2V
  • From about 1.5 volt to 3.0 volt it will charge with 50mA (72mA for 0.5 and 1A charge current), this is the same for all LiIon chemistries.
  • Above 3.0 volt the select current will be used
  • Meter starts working at 0.7 volt, but is first precise at around 1 volt.
  • Meter is within 0.03 volt.
  • Meter stops updating when battery is full.
  • Meter will not reduce reading.
  • Charger will restart silent if LiIon battery voltage drops below 4.1 volt (4.2V charging).
  • Power cycling and insertion of a battery requires button press to start charging in manual mode.
Charging 4.20V LiIon cells
The charger uses a CC/CV charge curve with 100mA termination at 1A charge current.
All the other slots look the same, but there is a small variation in final voltage, it is within acceptable tolerances.
These cells are also handled nicely, even the old one.
A very low charge current also works and there is not timeout.
This very old cell drops significantly in voltage when charging stops and the charger restarts again. I could probably have avoided this by selecting a lower charge current.
The 14500 is not as worn and the charger stops as it is supposed to do.
It looks like the termination current at 0.5A charge is 100mA, this is a bit on the high side.
The charger can handle 8 cells at 1A simultaneous.
Charging 8 cells requires nearly 4A from 12V
M1: 44,4°C, M2: 46,3°C, M3: 49,0°C, M4: 48,4°C, M5: 49,5°C, M6: 46,1°C, M7: 46,2°C, M8: 41,0°C, M9: 48,6°C, HS1: 54,4°C
When charging 8 cells at full current some cells are fairly warm.
M1: 60,4°C, HS1: 69,9°C
Here I tested in automatic mode, where the charger starts in about 2 seconds.
It is possible to change current during charge.
Charging 4.35V LiIon cells
The charger supports both 4.30V and 4.35V cells, I only did a test with 4.35V and it looks fine.
Charging 3.6V LiFePO4 cells
The charger charges LiFePO4 to 3.6V, but the restart voltage is too high, i.e. the charger will restart a couple of times after it is finished.
Charging NiMH cells
The NiMH charging stops on -dv/dt and looks fine.
On all slots, there is a small difference in current, but that is not important.
The two high capacity cells are handled fine.
Here I use a very low charge current on a NiMH and the charger terminates fine.
With -dv/dt termination it will take some time to detect a full cell, here it is about 13 minutes.
No problems with a AAA cell at 0.5A
No problem with charging 8 NiMH cells at a time.
It needs a bit below 2A at 12V for charging 8 NiMH cells.
M1: 47,8°C, M2: 49,0°C, M3: 50,3°C, M4: 49,0°C, M5: 50,6°C, M6: 49,2°C, M7: 47,9°C, M8: 43,1°C, HS1: 55,3°C
8 cells at full current will give some heat.
Starting is exactly the same as for LiIon.
Current change is also the same.
With NiMH the charger stops every 20 seconds to check the voltage of the cells.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems with the transformer.
Conclusion
This is a fairly advanced charger with support for most round cells on the market, both fairly large and very small. The automatic mode makes it very simple to use and the advanced mode adds support for just about any cell on the market. To use the advanced mode it is a good idea to learn the short cuts, this makes it fast to program multiple slots.
Due to the wide slots, it is necessary to be a bit careful when loading thinner cells (Like AA), they have to be centered in the slot.
I will rated this charger as a very good charger, but it requires a bit care when starting a charge.
Notes
The charger was supplied by Enova for review.
A grand review. But then again: it’s a big charger. Thank you Henrik.
If I did not already own chargers up the wazoo, I knew what to buy when waiting for my BLF GT!
But if you have “only a few” chargers, and live in/around the US, check out RMM ’s store.
Thansk HKJ. I’ve been using the old version of this charger for over 12 months now and very happy with it.
Thanks for the review HKJ.
I got this charger some few weeks back and I really like it.
I did not get the spacers, but I got four of the extensions plugs for the plus connection.
Some of my experiences with this charger:
- Charger will remember the state of each slot, you don’t need to re-setting each slot if you want to charge a same type of battery at a same slot, just put battery in and press and hold slot button for 3 seconds.
  • If power is recycled, memories will lost.
Thorough review as usual, HKJ.
I have been using the previous version of this charger and it has become my favorite, due to it’s versatility.
Also love the capacity!
I’ve noticed that when I pull a cell straight off the charger after it says full ,the charger says 4.2 volts but it’s actually about 4.17 volts.
It’s a bit like the opus 3100 but with the opus you can open it up & desolder the j1 solder bridge which makes it charge to 4.2 instead of 4.17.
Does anybody know if there is a similar thing that can be done with this charger?
If you look at my charge curves you will see the voltage drops when the charger is finished. The meter shows the full voltage, but do not update when the voltage drops.
I was playing with it last night & I pulled the battery out as soon as it said it was full & had the multimeter ready ( fluke) & it was 3.7volts & I also did tests with the multimeter connected whils charging & it never reached 4.2 volts ,it was 4.17 , so I think the voltage readings are optimistic just like my opus used to be before I desolderd the bridge
Just to clarify , the charger thinks & says 4.2v but is actually 3.7v ,I know the specs say +\ 0.3volts & it’s within that ,so it’s not malfunctioning I just wondered if it’s possible to bring the accuracy up just like you can do with the opus.
Not good enough, you have to measure while it is charging.
Yes I also did that , I edited my previous post to say that. .
I have the latest version of this charger. It’s my favorite out of the many I have. The only thing I would add to make it the perfect charger is a test function to measure the capacity of a given battery.
I also think it could be better if it had 700 ma charging setting in between 500 ma& 1000 ma.
