I think the problem is the driver not batteries. Already 4 of them in this group.
Both. Flickering leds is most likely driver problem. Uneven battery discharge cannot be a driver problem; it must be in the carrier/battery tube.
chakrawal: JasonWW:Do button tops add so much length?
So raised flat tops?
Maybe regular flat tops, but with thin magnets added?
I guess you could solder blob them to get just a tiny bit more height so they make contact.
Just put in Keeppower button top, let’s see what will happen.
I don’t know which Keeppower you’re using, but they might trip on turbo. As far as I know only the 3120 and 3000 Keeppower can handle the power. You could run the MT03 on high for some time, and check battery voltage if they’re even.
Please send code for this NW thanks
Is there a review with this version? I’m still deciding between MT03 XHP 70.2 vs Olight X7. The construction with HaikeLite isn’t as solid as Olight (I haven’t own any HaikeLite yet, I read about it). There’s a mid turbo mode X7 at 5000lm but MT03 doesn’t. The MT03 has the newer XHP70.2 and slightly cheaper. Which one? :question:
Looks like Haikelite solve the flickering issue with new driver.
Haikelite Official thread
Hi
MT03s from End of Novermber are used a TA-based driver with HaikeLite UI , the brightness increased above 12000 lumens.
i saw 2-3 people had a driver problem with mt03, please contact the dealer/us to find a solution.
Thanks
haikelite
_
Haikelite Official threadHi
Thanks
haikelite
_
That is big news! The latest version now ship with a FET driver based on the Texas Avenger design from Texas Ace. This means 12,000 lumen! Same Haikelite UI, though.
I wonder if NarsilM can be flashed on it? Hmmm.
Ya. But one thing still bothering me is that BG is still showing 8xxx lumens on their page. It could be old stock.
Interested in NW
Have you seen their new MT09R? It has a TA and it says Stepless control. Maybe ramping? Maybe NarsilM? 15,000 lumen. Deeper reflectors and more heatsinking. Very interesting.
DENGOH:Ya. But one thing still bothering me is that BG is still showing 8xxx lumens on their page. It could be old stock.
Ya, i am very excited to see Haikelite rolling out new products unique to their brand. I like their current UI though, ramping is fine too i guess.
Interested!
MT03 II with new driver now.
Interested in the white in NW tint,
Any changes to the new driver?
Probably not interested, but would like to know the price.
freeme:MT03 II with new driver now.
DENGOH:Looks like Haikelite solve the flickering issue with new driver.
Thanks
haikelite
_That is big news! The latest version now ship with a FET driver based on the Texas Avenger design from Texas Ace. This means 12,000 lumen! Same Haikelite UI, though.
Please send me the code, interested in:
Tint: NW
Emitter: CREE XHP70.2
Black version
Interested in white NW, please send code, and thanks!
