BLF GT official support thread [FAQ updated 11 Jan 2018]
339 posts / 0 new
Team-Giggles
Team-Giggles's picture
Last seen: 1 year 11 months ago
The QR code on the last page of the user manual points to this thread and we started to add some content:
  • Post 2: Some useful links. The user manual and joechina’s cheat sheet can be found there, among others.
  • Post 3: VOB’s video guide for the GT and JasonWW’s series of NarsilM videos are in post 3.
  • Post 5: Manual in text format for use with Google Translate.
  • Post 7: After-market accessories for the GT.
Please try to stay constructive, on topic and concise in this thread so that it does not balloon to something unusable. (No discussions regarding ordering, shipping, payments, etc.)
The group buy closed on 5 Jan 2018. Production is ongoing and orders are being filled as the GTs roll off the assembly line. The main discussion thread is here:
The main GT thread
Thanks!
Team-Giggles
LOL
Official GT team user account.
This account is NOT actively monitored and PM's have been disabled for the time being. Contact Neal, Texas_Ace or one of the other Team members directly if you have questions about your order.
Edited by: Team-Giggles on 01/13/2018 - 14:05
Team-Giggles
User manual
BLF-GT user manual draft13.pdf
(The first production run shipped with revision 12 of the manual. The revision 13 changes are minor.)
Chinese translation by steel_1024:
BLF-GT Chinese user manual V1.2
Russian translation by Narmattaru
Joe’s excellent cheat sheet for the GT
Cheat sheet
NarsilM firmware development thread
NarsilM thread
NarsilM 1.2 source code and ready-to-flash HEX files
NarsilM 1.2 files
Texas Ace’s review of the final prototype before production started. Your light should look pretty much like this:
Prototype 2 review
VOB’s un-boxing video
Maukka’s test of the stock LED tint and finds it to be nearly perfect!
Stock XHP35 HI 4000k emitter tint test
Team-Giggles
Video guides
Vestureofblood UI interface video on the GT:
JasonWW produced some good guides regarding general NarsilM use. Note that the GT uses a later version of NarsilM, so there are some minor differences:
Narsil Part 1 – Ramping and Features
Narsil Part 2 – Strobes and Blinkies in Ramping
Narsil Part 3 – Turn On and LVP in Ramping
Narsil Part 4 – Using Mode Sets
NarsilM Part 5 – Mode Sets Strobes and Special Features
and GT-specific: BLF GT with NarsilM v1.2 – new strobe modes
How to Change Menu Settings in NarsilM (Q8)
Team-Giggles
FAQ
General
  • How can I get a BLF GT?
    Post in the main GT thread saying that you want one (or more). Then wait for a private message with further instructions. It may take a few weeks before you can make the purchase, because production is slow. The group buy closed on 5 Jan 2018. Lights continue to ship as they are produced, for those already in the group buy. We expect the GT to be available for retail sale at some point in the future.
Emitter and output
  • What LED is used in the GT?
    Cree XHP35 HI, D4 flux bin, 4000 K CCT.
    Texas Ace did a detail review here:
    GT LED review
  • Can I get more throw if I drive the emitter harder?
    No, not really. It’s already driven at 2.5 A, which is just shy of the peak for the GT’s emitter. There’s very little to be gained from giving it more power; it’ll mostly just produce more heat.
  • Why is my lux meter showing me less than 1.2 Mcd for the GT?
    Could be caused by several things…
    • Lux meters usually read higher for cool white lights, so the GT’s warmer tint could be tricking the meter. This doesn’t mean it won’t throw as well as intended, just that the meter isn’t very good as measuring it.
    • The beam doesn’t fully collimate until ~20+ meters, so it may be necessary to increase the distance between the light and the meter for a good measurement.
    • The light might be running at 2.0 A instead of 2.5 A. Be sure to take measurements on turbo (which is above the normal output modes; double-click to access turbo).
  • How can I mod it to increase throw?
    Try an Oslon Black Flat for maximum throw. The hotspot will be tiny though, and the driver may need to be replaced or modified (TBD).
  • How can I mod it to increase lumens?
    Try a 12 V XHP50, XHP50.2, XHP70, or XHP70.2. It will decrease throw though, and the driver’s sense resistor should be changed to increase power to ~5 A. (We are also looking at cooler running options for the FET and inductor.) Bigger hot-spot, more lumens, less lux. Texas_Ace tried it and says the result is nice. Using 8 cells is strongly recommended for this.
  • How do I get a different tint LED?
    The stock tint is a great tint for real qorld performance but it is not for everyone. If you want to change your tint you can swap in any XHP35 you desire. A good source for XHP35 LED’s is RMM here on BLF. If you send him your stock mcpcb, he will even reflow the new LED on it for you.
Driver and firmware
  • Do I have the firmware bug?
    The firmware bug is just a wrong ‘fuse’ setting on the micro controller. The low fuse was left at the default value of 62, instead of E2. This sets the MCU to run at 1 MHz, instead of the intended 8 MHz. There are no reported cases out in the wild yet. Normally when the battery tube is tightened down the light will flash twice to confirm power. If these two flashes take more than 3 s to complete, you have the bug.
  • How does the driver work in layman’s terms?
    From a post here :
    Its a proper ‘buck’ driver.
    The FET is pulsing the inductor and the inductor, by nature, outputs a DC current proportional to the duty cycle of the FET. (Not to be confused by the PWM output of the tiny85.) The inductor is the big black cube on the board, and is basically copper wire coiled around a ferrite core.
    The brains of the buck operation is that small chip sitting next to the sense resistor. The tiny85 simply generates a 0-1.24 V ‘set-point’ for the buck chip. The buck chip compares this set-point with what it measures across the sense resistor and then does its thing to put out the requested amps.
    Some things to note:
    • There is some PWM happening in the driver, but for most output levels the LED current is almost pure DC
    • To get to the very low modes, it does output PWM to LED (modes below 10%, or 0.25 A). This is under the control of the tiny85 when we go PWM and when we go DC, so there is flexibility here for people doing their own firmware.
    • Battery current is not same as LED current. Like for a transformer, the ratio depends on input vs. output voltage: Iled = Ibat * (Vbat/Vled) * Driver efficiency
    • Driver efficiency is around 92%, depending again on voltages
    • The FET is a p-type, not our typical n-type. It is being pulsed at up to ~600 kHz, so it also needs to be much faster than our typical ‘direct-drive’ FETs.
  • What is the maximum input voltage that the driver can take?
    Officially 20 V, as per the silk on the back of the driver. It should survive up to 24 V, limit being the MIC5235 LDO used for the MCU. Main power capacitors are 50 V rated, but C1 was specified for only 25 V. Going above 25 V calls for a 40 V FET, whereas the stock FET is 30 V rated.
  • Where is the sense resistor and what is the formula for output current?
    That would be R11, the big (2512 package) resistor. Stock value is 0.091 ohm. Maximum output current is approximately:
    Imax = 0.248/R11 - Ir/2
    where Ir = 0.3 on the stock driver
  • What output current is used for the strobes?
    2.5 A
  • I set my GT for the mode-set UI, set 7, but I get two modes instead of the expected 100%-only mode?
    From the user manual, page 6:
    Note that MOON mode is enabled by default, adding
    one extra mode (mode 0) to the above.
    Disable MOON mode and you will be good to go.
  • The GT has low voltage warning and shut-off. At what battery voltages does this happen?
    • At 12.0 V (3.0 V per cell) the GT will blink the main LED and step down in power. It will do this repeatedly until the battery voltage recovers above 12 V.
    • At 11.2 V (2.8 V per cell) the GT will blink rapidly and shut down the main LED.
      Note that these voltages can be ~0.05 V per cell off in either direction, depending on the component tolerances and temperature. These voltages are monitored under load and cells will read higher when removed and measured outside the light.
  • What is the run-time of the GT on a set of fresh cells?
    Using four Samsung 30Q cells (3000 mAh) gives about 45 minutes of regulated 2 A output, followed by another ~30 minutes of drooping output. Using eight cells doubles this time.
    MRsDNF’s run-time tests with four cells
Body / host
  • Why is the rubber boot for the button not transparent?
    It is translucent black, the green back light is visible in a dark location only. If you received a light with an opaque black button we will work with LT to correct it.
  • What is the size of the rubber boot for the button?
    12 mm. These are available online, but less common than the standard sizes.
  • Why do the front and back lanyard attachment holes not line up?
    The tail-end attachment point can rotate inside the tail cap.
  • My tailcap ring doesn’t want to spin. Help?
    There may be a pinched or insufficiently-lubed O-ring inside. If you remove the Lumintop sticker inside the tail-cap, the parts should unscrew (reverse-threaded), and then you should be able to check and lube the O-rings.
  • Why do the font lanyard attachment hole not line up with the button?
    The driver compartment and the reflector housing are two separate pieces that screw together. It is difficult to have this align and it was never intended to align.
  • Are any parts of the host glued together?
    No. But they are tightened down well and especially the bezel can be a tough one to unscrew due to its size.
[Edit 2018-01-11: Driver and run-time details added]
Team-Giggles
GT user manual (draft 12) in text format (for Google Translate)
Thank you for supporting this BLF community project. The GT was designed by BLF, for BLF, and brought to life by top-tier manufacturer Lumintop. We trust it will serve you well in whatever your endeavors might be!
– the BLF GT project team
Safety precautions
  • Use only reputable 18650 cells of known origin. Protected type cells, based on Samsung, Panasonic/Sanyo, Sony or LG cells, are recommended.
  • Use a reliable battery charger. Never over-charge or over-discharge cells.
  • Cells are used in series, not parallel. It is therefore important that all cells are identical: Same make, model, capacity, age, used cycles, and furthermore charged to the same level.
  • Remove and recharge cells when the low voltage indication is given by the GT (repeated step-downs in light level and eventual shutdown of the light).
  • The extraordinary energy density that 18650 cells offers also means that hazardous conditions are created when a cell is short-circuited or damaged. Always treat cells with respect and properly dispose of damaged cells.
  • The GT is a very high-intensity flashlight. Do not point the GT directly at a person, animal, moving vehicles or flammable materials.
  • When running at higher output levels the head of the GT will slowly heat. This is normal. In warmer ambient conditions this temperature may exceed 60ºC, so please take the necessary precautions when handling the GT.
Quick start
  • Load the cell cradles with four 18650 cells each. Note that the cradles require button-top type cells. The GT is designed to work with either or both cell cradles populated. Take care to observe the correct polarity for each cell.
  • Unscrew the tail-cap and insert both cradles. Again take care with the polarity: Arrows on the cradle rods must point towards the head of the GT. If populating only one cradle we recommend placing it towards the rear, so that the GT balances better in the hand.
  • Screw the tail-cap back. The GT will flash twice when electrical contact is made. Continue to tighten the tail-cap to a gentle stop. Do not over-tighten.
  • All functions are performed using the single side button. Note that pressing this button continuously for more than 8 s enters the UI configuration settings (indicated by the light blinking). If this is done inadvertently, exit the configuration settings by simply releasing the button briefly then pressing it again continuously for about 4 s until all the resulting blinks stops.
  • The GT comes factory-set to use the RAMPING UI: From OFF, press&hold the side button. The light output will ramp up from a very low level to full power. Release the button when the required light level is reached. (The full ramp takes about 3 s.) Use a single-click at any time to turn the GT OFF. Please see below for further details.
  • There is a very small drain on the battery while OFF. This should not be of any concern, but we recommend removing the cells (or partially loosening the tail-cap) if the GT will not be used for several months.
  • By default the button back-light is illuminated while the GT is OFF. This is normal and is done to easily locate the button in a dark environment. Turning the GT ON, then OFF, in rapid succession, disables the back-light until the next use. This is also normal.
  • For the complete user manual and any questions you might have about your GT, please visit the GT support thread on BLF. The link is on the last page of this manual.
Default UI: Smooth ramping
This feature-rich UI provides for smooth ramping of the light output between 0 and 80%, with an easily-accessible 100% TURBO mode.
  • Turn the GT ON:
    single-click the button, GT turns ON using the previously used light output level
  • Ramp light level:
    press&hold button
  • Reverse ramp:
    while ramping in one direction, release button briefly and press&hold again
  • Instant TURBO:
    double-click
  • Turn the GT OFF:
    single-click
  • MOON mode:
    from OFF: press the button and release as soon as the GT turns on
  • Strobes:
    double-click for TURBO, and then double-click again
    (Use single-clicks to cycle forward through the different types of strobes, but you have to be quick: If resting on a strobe longer than 1.2 s it locks in and the next single-click is OFF. Press&hold at any time to cycle backwards through the strobes.)
    Battery status: triple-click (4 blinks, a short pause, then 1 blink would indicate 4.1 V average per cell, for example)
  • Electronic lock-out:
    four clicks to disable the GT, same to re-enable the GT
  • MOMENTARY mode:
    five clicks (loosen and re-tighten the tail-cap to return to normal operation)
  • Factory reset:
    triple-click (battery status mode), then double-click (driver temperature mode), double-click again (firmware version mode), then press&hold for about 2 s. Four blinks confirm a successful reset.
Alternative UI: Mode-sets
The GT is factory-set to operate using the contemporary RAMPING user interface, as described in the previous section. However, the GT can also be operated using a more conventional MODE-SET style user interface. (See next section for detail on how to set UI options).
Using the MODE-SET UI the output does not ramp, it steps from one mode to the next using single-clicks.
  • Turn the GT ON:
    single-click
  • Next mode:
    single-click before the current mode ‘locks in’ (1.2 s)
  • Previous mode:
    press&hold
  • Last mode [100%]:
    from OFF: press&hold
  • Turn the GT OFF:
    single-click button, after resting on a mode more than 1.2 s (mode locked in)
  • Strobes:
    press&hold
    Battery status: from OFF: single-click followed by press&hold (4 blinks, a short pause, then 1 blink would indicate 4.1 V average per cell, for example)
  • Electronic lock-out: from OFF: double-click followed by press&hold, same to re-enable the GT
  • Factory reset: from OFF, single-click followed by a press&hold (battery status mode), then double-click (driver temperature mode), double-click again (firmware version mode), then press&hold for about 2 s. Four blinks confirm a successful reset.
Advanced operation
By default the GT firmware is set to suit most users and applications, but several settings are user-configurable. To enter the configuration settings, press&hold the button for about 8 s (3 s if in the MODE-SET UI), do not release until a double flash followed by a single blink is seen. The single blink is the prompt for the first setting. Click the button as many times as required for that setting, or leave the setting alone and simply wait for the next double flash, this time followed by two blinks, indicating that we are now at setting #2, etc.
The GT confirms each click with a blink. A press&hold skips to the next setting. A continuous press exits the setup menu completely. Four blinks indicate that the setup is completed.
The available settings differ, depending if the GT is currently set to the RAMPING UI or the MODE-SET UI. Note that changing setting 1 flips to the other UI and immediately kicks you into the table for that UI:
RAMPING user interface settings
Setting		Function		Clicks
1		User interface		1: MODE-SET 2: RAMPING [default]
2		MOON level		1-7 [default 3]
3		Auto step-down		1: Disable 2: Temperature [default]**
					3: Timed, requires another 1-6 clicks for 60s/90s/2m/3m/5m/7m respectively
4		Strobes			1: Disable 2: Strobe 1 only 3: All strobes [default]
MODE-SET user interface settings
2		Mode-set		1-12 [default 4]
3		MOON mode		1: Disable 2: Enable [default]
4		Mode order		1: Low to high [default] 2: High to low
5		Mode memory		1: Disable [default] 2: Enable
6		MOON level		1-7 [default 3]
7		Auto step-down		1: Disable 2: Temperature [default]**
8		Strobes			1: Disable 2: Strobe 1 only 3: All strobes [default]
If [temperature] is selected for auto step-down, the GT goes to 100% output. Leave the GT to heat to the desired limit, and then click to set that temperature as the trip point (the GT is huge, so this can take 20 minutes or longer, use fresh cells for this). Or click within 5 s to keep previous setting.
The mode-sets have been selected to suit a high-power thrower like the GT:
Mode-set no.	Modes [% of light]
		1	2	3	4	5	6
Sets 1 to 6:  100% = 2.0 A LED drive
1		100
2		25	100
3		11	33	100
4		12.5	25	50	100	[default]
5*		1	7	22	52	100
6*		1	5	15	32	60	100
Sets 7 to 12:  100% = 2.5 A LED drive
7		100
8		25	100
9		11	33	100
10		12.5	25	50	100
11*		1	7	22	52	100
12*		1	5	15	32	60	100
Modes in sets 5, 6, 11 and 12 are equally-spaced on a cube-root curve (considered an ideal mode-spacing by many).
Note that MOON mode is enabled by default, adding one extra mode (mode 0) to the above.
Pre-programmed strobes:
Strobe	Type
1	16 Hz
2	Police strobe (dual frequency)
3	Biking (low light with hi-vis stutter)
4	2 s beacon
5	10 s beacon
Additional UI settings are available to control the button back-light. While in the battery check mode, press&hold the button. A double flash followed by a single blink is again the prompt for the first setting:
Advanced UI settings
1	Button LED on while GT OFF		1: Disable 2: Enable [default]
2	Battery level blinks on button LED only	1: Disable [default] 2: Enable
3	Button LED				1: Disable 2: Enable [default]
Specifications
  • Emitter:
    12 V Cree XHP35 High Intensity, neutral white, mounted on copper DTP MCPCB
    Flux: >2000 lm
  • Intensity:
    >1 Mcd (ANSI throw >2000 m)
  • Firmware:
    Tom E’s open-source NarsilM v1.2
  • User interface:
    • By default the GT is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5 A TURBO mode is also provided.
    • A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
    • MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
  • Battery:
    Four or eight button-top 18650 cells (4S1P or 4S2P). Protected cells are recommended. Cells are not included.
  • Driver:
    35 W, 2.5 A regulated buck driver with conversion efficiency that exceeds 90%. Parasitic drain while OFF is ~150 μA (~250 μA with button back-light on).
  • Reflector:
    118 mm ID, aluminum, smooth finish
  • Lens:
    Glass with anti-reflective coating
  • Body:
    Aluminum with Type III hard-coat anodizing
  • Tripod socket:
    Standard 1/4 inch threaded (1/4-20 UNC)
  • Button:
    Tactile with back-lit rubber boot
  • Ingress rating:
    Equivalent to IP65, do not immerse in liquids
  • Weight:
    Approximately 1.8 kg without cells
  • Dimensions:
    135 mm Ø head x 315 mm length
GT support thread:
http://budgetlightforum.com/node/57676
GT main thread:
http://budgetlightforum.com/node/50303
[Edit: 2018-01-11: Added the two thread links]
joechina
Last seen: 1 week 6 days ago
So what does the team do on mars?
Team-Giggles
Accessories for the GT
Thank you joechina for this compilation:
Team-Giggles
[reserved]
Team-Giggles
[reserved]
Team-Giggles
[reserved]
thijsco19
Last seen: 5 hours 10 min ago
Please don’t post it if you subscribed.
Please keep this thread clear of any ‘offtopic’ chatter.
Thank you Wink Thumbs Up Thumbs Up
byarnell05
Last seen: 6 days 12 hours ago
Got mine today. My switch LEDs are different brightness levels like someone mentioned before. Not sure if it bothers me though. Anyone else have the same issue?
ToyKeeper
ToyKeeper's picture
Last seen: 17 hours 22 min ago
FAQ: How can I get a BLF GT?
  • Post in the main GT thread saying that you want one (or more). Then wait for a private message with further instructions. It may take a few weeks before you can make the purchase, because production is slow.
FAQ: Can I get more throw if I drive the emitter harder?
  • No, not really. It’s already driven at 2.5A, which is just shy of the peak for the GT’s emitter. There’s very little to be gained from giving it more power; it’ll mostly just produce more heat.
FAQ: Why is my lux meter showing me less than 1.2 Mcd for the GT?
  • Could be caused by several things…
    • The light might be running at 2.0A instead of 2.5A. Be sure to take measurements on turbo (which is above the normal output modes; double-click to access turbo).
FAQ: How can I mod it to increase throw?
  • Try an Oslon Black Flat for maximum throw. The hotspot will be tiny though, and the driver may need to be replaced or modified (TBD).
FAQ: How can I mod it to increase lumens?
  • Try a 12V XHP50, XHP50.2, XHP70, or XHP70.2. It will decrease throw though, and the driver’s sense resistor should be changed to increase power to ~5A. Bigger hotspot, more lumens, less lux. Texas_Ace tried it and says the result is nice. Using 8 cells is strongly recommended for this.
FAQ: My tailcap ring doesn’t want to spin. Help?
  • There may be a pinched or insufficiently-lubed O-ring inside. If you remove the Lumintop sticker inside the tailcap, the parts should unscrew (reverse-threaded), and then you should be able to check and lube the O-rings.
DEL
DEL's picture
Last seen: 2 years 8 months ago
Thanks TK! Done and done into post 4.
ToyKeeper
ToyKeeper's picture
There’s another question I’ve been asked a few times, but it’d probably be out of place in the main list…
FAQ: When will other firmware be available?
  • As soon as I get a GT. I have no idea when that will be, but it should only take a few hours after I get hardware to test on.
pepinfaxera
Last seen: 19 hours 31 min ago
Team-Giggles wrote:
User manual BLF-GT user manual draft13.pdf
Google Translate does not translate PDF files
Any solution for non-English speakers?
EDIT
Team-Giggles wrote:
Please see if post 5 is useful. (Still need to somehow add the various tables to it.)
Solved. … http://budgetlightforum.com/comment/1231963#comment-1231963
Thank you very much.
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
Team-Giggles
Ag76
Ag76's picture
Last seen: 3 hours 7 min ago
Either I have the wrong switch cover, or my LEDs are so dim that you can’t tell they’re working unless you’re in a dark room or at night, but I’m beginning to think it’s the LEDs
DEL
DEL's picture
Hopefully TA can chime in, most of the team lights shipped with opaque button boots.
It is supposed to be very dim, as mentioned in the FAQ above. Two Three ways to have it brighter:
  • Change the boot to a clear one. The boot is 12 mm, not a common size unfortunately.
  • Change or stack the resistor controlling the back-light current (R8). Stock value is 33k for ~100 μA. Change to 15k or stack another 33k on top of the stock resistor to double the current. The resistor should be 0603 footprint, but a 0805 will fit as well. Note that this will take the parasitic drain from ~240 to ~340 μA.
  • Rewire the button LEDs in series and drop R8 accordingly.
Edit: For the mismatched LEDs, that can happen with LEDs wired in parallel. Still preferable to having one off-center LED I guess. It may also simply be the way the rubber boot is orientated. A simple hack here would be to rewire the LEDs in series and change R8 to 10k (MCU is running at 5 V on GT, so there is enough voltage to do this). Bonus, double brightness for same parasitic drain.
JasonWW
JasonWW's picture
Last seen: 2 hours 39 min ago
In post 5, specifications, emitter, could we add the details that it is a D4 bin and 4,000k color temp?
Also, I have been asked if the strobe modes are using the 2A, 2,000 lumen mode or the turbo 2.5A, 2,500 lumen mode. Does anyone know?
Texas_Ace
Texas_Ace's picture
Last seen: 22 hours 54 min ago
It seems a handful of black boot slipped through to normal people as well. Neal is taking care of them on a case by case basis.
You are also spot on with the rest of the details.
Team-Giggles
Post 5 is a verbatim copy of the printed manual so it should stay as is. No problem to add the bin info to the FAQ though.
For the strobes, these are at 2.5 A. This is from the source code:
void Strobe(byte ontime, byte offtime)
	FET_PWM_LVL = 255;
#ifdef GT_BUCK
	ONE7135_PWM_LVL = 255;	//  for GT-buck
	_delay_ms(ontime);
	ONE7135_PWM_LVL = 0;		//  for GT-buck
#else
	_delay_ms(ontime);
	FET_PWM_LVL = 0;
#endif
	_delay_ms(offtime);
Basically the buck chip is set to full power in the first line and then alternatively enabled/disabled in the next three lines.
WaylonJennings
Last seen: 1 year 2 weeks ago
Is there a way to have the lighted switch stay on when the light is turned on? Having a lighted switch is just as helpful when you want to change output levels or turn the thing off as it is when you want to turn it on.
JasonWW
JasonWW's picture
There’s no option for that. You’d have to manually run a new wire to keep it powered all the time, so you’d lose the “indicator” function. No big deal as I have two lights where the switch stays on all the time.
ToyKeeper
ToyKeeper's picture
If the GT’s lighted switch is controlled by the MCU, it should be possible to change its behavior via firmware. From the way the question is written though, I get the impression that maybe that’s not how the switch light works on this model?
I thought it worked like the Q8, but now I’m not sure.
JasonWW
JasonWW's picture
Yes it can be changed by firmware, but not the existing firmware as it has no options to make the light always stay on. I think Tom E said he was going to possibly add the option to make the light always stay on in a future version of NarsilM.
WaylonJennings
For me this would be great. I just came in after using the GT and with the temperature around -10F and I was wearing gloves which made locating the switch by feel was impossible. I had to take my glove off to find the switch, kinda cold on bare fingers holding an aluminum light.
JasonWW
JasonWW's picture
You could wait a while and see if it gets done then reflash the driver. Personally I would just pop the driver out and move a wire. You could do that now. I haven’t looked to see if a resistor will be needed or not. I plan to swap the leds and switch cover so I’ll write up all that info for anyone else.
ToyKeeper
ToyKeeper's picture
The switch control code is already written. I mostly just need to adjust the ramp values to work on the GT’s driver, and check the calibration in general. I doubt it’ll take long. I could probably even do it without hardware, but I make no guarantees that it’ll actually work.
The method I’ve been using to control the switch light is:
  • When the light is in any operating mode, the switch light copies the main emitter. The button light stays on steady in regular modes, blinks in blinky modes, etc. Button brightness also imitates the main emitter, though it only has three states — off, low, high.
  • While in the “off” state, the button goes to the user’s configured brightness — off, low, or high.
  • While in the “lockout” state, the button goes to the user’s configured lockout brightness — off, low, or high.
It seems to work well on the Q8, but I hear the GT’s boot is a lot darker so I’m not sure the “low” brightness will be of any use.
WaylonJennings
This sounds great! The thought of me “going in” with a solder iron and changing things feels like a recipe for disaster to me. What is involved in “re-flashing” the driver? I know my way around the numbers concerning lights, led’s and batteries, but I am a total noob when it comes to drivers and all of the other internal electronics you guys talk about that make my eyes glass over.
WaylonJennings
If Wisconsin was a little closer to Houston I would stop buy and have you show me hows it’s done. I need to buy a couple of cheaper lights to take apart and experiment with.
