[WTS] Remote switch tail DD board with FET
14 posts / 0 new
Lexel
Lexel's picture
Last seen: 9 hours 22 min ago
Annoyed with the low output with remote pressure switches for flashlight?
I did a board with a MOSFET to eliminate the extra resistance from the external switch
size 16-17mm, for 16mm the battery holder fins need to be cut a bit
If you want just one mode in direct drive you don’t need a driver in the head
I use a MOSFET with a low gate voltage which gets full output down to 1.8V
The MOSFET is powered by a CR1225 Lithium battery with 36mAh should run easily hundreds of hours on
Aliexpress has cheap remote switches, you could dismantle for the cable and pressure switch, or one that fits your flashlight
https://www.aliexpress.com/w/wholesale-remote-pressure-switch.html
Availiable just the board or board with switch (Switch, cable and plastic cap)
Board 4$
Board with switch 6.5$
shipping worldwide priority air mail
2$ for just the board
4.2$ for switch and board
OK I received today last parts, so I have build 9 pieces
tested them successfully
Edited by: Lexel on 12/06/2017 - 22:17
MRsDNF
MRsDNF's picture
Last seen: 3 hours 29 min ago
Looks good Lexel. I’ll check the piggybank tonight. Smile
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 21 hours ago
I’ll take 3 boards please. Paypal it now Smile
Lexel
Lexel's picture
9 boards build
10 more boards will be build soon
6 remote switches availiable
1. pinkpanda3310 3 boards
2. Tee 1 switch and board
3. MRsDNF 4 boards
Main driver bridged or set to single mode like Bistro or Biscotti
MRsDNF
MRsDNF's picture
What is your PayPal?
Edit. I’m assuming these need a spring soldered to them for battery contact on the negative end.
MRsDNF
MRsDNF's picture
Paypal sent for 4 switches. Thanks.
Lexel
Lexel's picture
MRsDNF wrote:
What is your PayPal? Edit. I’m assuming these need a spring soldered to them for battery contact on the negative end.
yeah the center pad is for the spring
the remote switch has 2 small solder points near R4
basically the battery holder and R4 needs to be connected to the switch
sovereignknight
Last seen: 5 min 39 sec ago
Seems like quite an innovation there, Lexel.
You defiantly are a guru of flashlights!
MRsDNF
MRsDNF's picture
Got these switches today thanks. Now what lights to build to use them in? Smile
luminarium iaculator
luminarium iaculator's picture
Last seen: 5 hours 56 min ago
Hmmm… Let me guess? Hunting thrower lights of course SmileThumbs Up
I already got one from Lexel, modd it with my rat tail switch and confirmed that it does not have any lux drop in single 18650 cell fet driver combination.
Lexel is very smart guy Smile
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
MRsDNF
MRsDNF's picture
luminarium iaculator wrote:
Lexel is very smart guy.
No argument from me. A real asset to BLF. Beer
Zappaman
Zappaman's picture
Last seen: 10 hours 7 min ago
Lexel sent me a pair of these FET “switch” boards for my Pig Gun C-8 light mod- I got them today! (thanks Lexel!) The C8 is finally in LA (from Hong Kong) according to Kaidomain’s tracking email (which didn’t work for about a week… I was worried for a bit there) LOL
Being a newbie, I am figuring out things reading up on stuff around the site this last week and I saw a post today on a 3 led kit (sold at AliExpress) from a few months back I might get into now (I THINK it fit the C8?) undecided Lexel explained he was also working on a project here co-designing a driver that would work best for a hunting rig like mine (one mode- off and on). Wondering if this driver (or one like it) could be used with the 3 LED kit for say somewhere around 4k lumen (from one 18650)?
Learning every time I come here. Grad
ZappaMan
Lexel
Lexel's picture
There is a C8F Sofirn sells as host or full light with triple XPL MCPCB and reflector
Snipr
Last seen: 2 weeks 7 hours ago
Lexel sent me a pair of these nice stuff too… I just made some dirty hack for one of my Convoy C8 (factory tailcap + cheap remote switch from china + this nice FET switch), it works like a charm Smile absolutely no light loss, in fact with this FET remote I measured a little bit better values than with the factory tailcap!
Nice work Lexel and thank you again!
ps.: I will recommend it to my hunter friends Wink
