Ok I got here one Narsil 17mm build but soldered already ba accident spring and cables to it, but got an error when I tried flasing Bistro OTSM :person_facepalming:
Any lead time on the 21mm drivers?
Oshpark shipped them friday 10 days ago, should be here any day
The other manufactory with 230 single boards on 20 10x10cm PCBs are still not even produced
I’m not sure if you got my pm, but is there a 17mm driver with Narsil left for sale?
Hi,
I got ordered a very big amount of boards from Seeed, when they arrive I can make more 17mm drivers, last week the last 17mm sized got already taken
I hope they will deliver soon
Hi Lexel how much is it for MF01?
last order from Oshpark arrived today
The boards from Seed are in local post office as I had not the import tax. amount fitting in my wallet
MF01 driver Oshpark batch is
when I sold the last 4 of the Oshpark ones the Seeed boards will be 2.5$ less
NarsilM Attiny85
13$ flashed standard Narsil settings 60°C uncalibrated, SD=2.8V, PO=(2B),
14.5$ with temp+LVP calibration and max temperature preset,
per loose bronze spring add 0.3$
silicone cable can be presoldered for 0.12-0.2$ per inch
47.5mm MF01 MT03 Q8 +4,85$
LDO 1.2$ 21mm and bigger only
add 1$ for SRK Size with more than 8 AMC7135 Bank with all 16 AMCs
2$ envelope priority air mail shipping worldwide
adds 3$ for optional tracking + insurance up to 25€
Did reflow stuff
Damn, they are pretty :sunglasses: But they’ll be even prettier inside my lights
Nice work Lexel, thanks for doing that and keep it up !! :+1:
PM sent
4,85$ 47.5mm MF01 MT03 Q8 +4,85$
1.2$ LDO 1.2$ 21mm and bigger only
2$ envelope priority air mail shipping worldwideadds
Total $26.55?
is that correct?
This is correct
there was a mishap from DHL Express on Thursday as the driver did not schedule new delivery, when I had not the import tax to give him, as they seem not to have any to exchange larger bills
so I had to phone the hotline and its delivered again on monday
4 envelopes shipped today
list up to date
So big Seeed order arrived
Was busy with new stuff
:+1: Lexel
Keep this up and I’ll have to get another even before I receive the first.
Nice Lexel. How was the cutting out?
wow you even have solder mask made for the boards. Cant wait to have mine, this is a second board from you Lexel :+1:
Cutting out was not so easy, I have already begun to drill the last 7+9 boards lineed up through holes in my vise and started to drill quite some holes to make cut out easier
Also found out that the cutting is quite bad for my saw blade, even hardened steel wears out fast
Used a Dremel to sand the boards round which goes quite nice
