Nichia 219B 4500k D220 9080 CRI Emitter output test by Texas_Ace; Amazing tint and CRI! Output is what you would expect.
I like Lee minus green filters
I don’t understand duv, yet, but, I can see that the Greens (R3, R4, R5 and R11) are taller than the Red, Yellow, and Pink (R9, R10, R13), on the Green tinted Oslon… while on the Pink tinted Nichia the Red, Yellow and Pink bars are not shorter than the Green bars…
images clipped from maukka’s plots
looking at the relative size of the red vs green bars, I would expect all these LEDs to have a green tint
and they do: (pic is from, and is a link, to maukka’s review)
I haven’t dig too much into this but….IMHO….
Simply said Duv is how far off the tint of tested LED from the BBL (0 - 4500K) or SBL (5000 - 10000K). BTW, is there such a term as Sun Body locus? :smiley: this is just my own word.
From my understanding looking at Maukka’s chart: 0,0055 means the tint is lower than BBL while 0,0093 means the tint is higher than BBL/SBL. By carefully looking at his charts, I think it’s safe to conclude anything beyond 0,004 or 0,004 is considered too far from the reference line (BBL/SBL). This aligns very well to 219B sw45k (miss piggy tint) and Oslon (kermitt tint) facts.
- Clemence
I dont know how I missed this led… but I did… is it still available anywhere to purchase?
Link to the latest info
The reference source differs depending on the standard/method. For example the CRI standard CIE 13.3: 1995 describes the duv tolerance (i.e. acceptable duv to consider the CRI valid in the first place) as +–0.0054 with BBL being the reference source for CCTs up to 5000K and D series illuminants above it.
This is also true for CRI, CQS and CRI2012, even if the duv tolarence varies a bit.
In the TM-30-15 and CIE 224:2017 the transition from BBL to daylight illuminants is gradual.
In my data, however, duv is always the distance from the BBL, even on sources above 5000K.
I have the Lee swatch book to play with.
We’ll be very grateful to see your test results then. My personal request is how far can we trim the blue spike. Also how the minus blue spike filter affects CRI.
Many thanks
Clemence
Mauri, the CRI datas are missing
Where do you get those green filters? I have several LED’s that could use that.
Lee offered a free small swatch colour sample, it consists of hundreds of its colour gel filter. Each sample is enough for two small flashlights. Just contact your local representative marketing. I lost my colour swatch in the project site. I’ll need to order another
- Clemence
Who is Lee?
http://shop.leefiltersusa.com/Swatch-Book-Designers-Edition-SWB.htm
An actor I guess :wink:
Bruce Lee
Thanks for the link
Oh, look who the funny guy is….lol
Thanks!
very helpful, thank you
pic is a link to more details:
Considering that a perfect redendering index score happens when the different wavelenght's relative outputs follow whatever given temperature pattern/curve shape, I guess we could even fine tune (maximize) the CRI and tint out of any good CRI emitter with a custom tailored filter.
Cheers :-)
I have oslon LCW CQAR.CC-MR-6L-L2, no any grinnich. Compared with 219B sw40, it is slightly yellowish. I planned to order 7 pieces OSRAM OSLON® Square LED 4000K CRI 95 2W HIGH POWER 3030 GW CSSRM1.BM | eBay with C5/D5 chromaticity coordinate (below of BBL). If C5/D5 is missed, here is guaranted reddish tint https://ru.aliexpress.com/item/OSRAM-OSLON-SSL-80-High-Power-LED-1-3-Watt-LED-BLUE-LB-CP7P/32295974290.html
How about these:
Can’t find info on the chromaticity though, only the colour temperature (3000K)
