Review : KDLITKER C8.2 , 1*18650 xhp50.2 flashlight
100 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 2 days ago
KDLITKER C8.2 XHP50.2 Review
Overview :
First Look / Unboxing :
Flashlight comes in a simple brown box :
Package Contains :
- Flashlight
- Lanyard
- Spare o-ring
- Gitd tailcap boot
- Soft cleaning cloth
Extended View :
The flashlight itself :
As you can see , it is a classic C8 styled flashlight . Here are some more photos :
It has KDLITKER logo on one side
And the C8.2 on the other
Anodizing is matt , and has a nice feel…
It’s head , with great machining and some cooling fins :
It has a little “Warning” logo on the head . I find it funny , if you think that it is on a flashlight Silly :
Notice the nice crenelated bezel too
Here we can see the SMO reflector and the nicely centered LED (xhp50.2) :
One more photo coming soon , sorry
The tube . Very smooth knurling , and nice machinng also here :
The tailcap . It has holes for lanyard and has the rubber boot “protected” (not protruding) :
Tailcap’s rubber boot :
And the tube’s threads , on the tailcap side . Anodized , well machined :
The other side has bare non-anodized threads for better electrical connection
The visible part of the pill , with the driver and it’s spring (+) :
A button top battery has a good fit , even if it seems to be protruding a lot because of the long driver’s spring (it compresses nicely)
A quick teardown :
Head , tube , tailcap :
As someone can notice , on one of the tube’s “end” (flashlight’s head side) it has only 2-3 full threads , but connection between body and tube is very solid
Switch’s spring :
And the switch assembly . It has the classic little reverse-clicky Omten switch:
Head assembly :
Pill made from brass , with the xhp50.2 on 20mm KD DTP copper board :
And with the centering ring on :
Bottom side , with the driver held by a retaining ring :
Pill accepts 20mm driver and driver installed is H1-A
Modes and driver info :
Driver is the H1-A boost driver . Here are some info :
Input Voltage: 3V – 4.2V
3 Volts is the cut-off voltage , the LVP kicks in
Output Voltage: 6V – 6.8V max.
Output Current: 2900mA – 3000mA max.
Modes: Very Lo(5%) > Lo(35%) > Med(65%) > Hi(100%) + Hidden Strobe: Double Click
Features :
1. Constant Current, No PWM
2. Low Voltage Warning: When voltage is below 3V, it will keep flashing.
3. Memory function : ( On for > 3 secs)
Notes: 1. The driver does not have battery reverse protection. Please make sure the battery is connected in the correct way (positive end on the head side) . 2. The max current from battery can be up to max. 8A, high drain battery is recommended for this driver.
Measurements :
Battery used in all measurements : Sanyo NCR18650GA 3500mAh
Amperage draw (Measured on the tail , with UT139 clamp meter) :
Very Low : 15 mA
Low : 0.365 A
Med : 1.3 A
Hi : 4.7 A
Lumens (measured in diy lightbox) :
Very Low : 9.2 lumens
Low : 240 lumens
Med : 765 lumens
Hi : 2040 lumens (Theoretical value is 2120 lumens for xhp50.2 at 3amps)
Current @ the emitter will be updated soon
Intensity on highest setting : 32.2 kcd
Beamshots section :
Here are 2 quick beamshots , more coming tomorrow !
Low :
High :
Camera shows the corona a bit more yellow than it really is…
Here are some better beamshots finally !
Control shot :
Low :
Mid :
High :
As you can see hotspot is pretty big … Output on high is impressive , 2k lumens reaching a great distance!
Runtimes :
High mode (referred as Turbo) :
A few words :
Very nice option for those who want a bright C8 , with big hotspot for less throw . Build quality is excellent , and overall it is an excellent flashlight !
Flashlight was provided by Kaidomain for review purposes . You can find this flashlight here .
Edited by: giorgoskok on 03/26/2018 - 13:57
giorgoskok
Reserved !
I still have to add a thing or two Wink
8/5 – Updated beamshots
Tangra
Last seen: 1 hour 3 min ago
Nice review George.
It is interesting how much is the battery current and voltage after 20 minutes on high mode?
EasyB
Last seen: 1 min 12 sec ago
Thanks for the review. The XHP50.2 in combination with the H1A boost driver is impressively efficient. The same combination and results that djozz found in the KDIY KF8.
The throw suffers though, from a combination of the low current density and new cree flip chip design LEDs, which inherently have less luminance and throw.
Speed4goal
Last seen: 1 year 9 months ago
Thanks for the review. I want this light or at least the driver. Its crazy that 2k lumen single cell c8s are a ordinary thing now. With this set up or 3v its over 2k and with the XP-L2 it’s over 2k as well. I think this driver with a mtg2 would work nice in a c8 with a single cell.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
timbuchanan
Great review
BanL
Last seen: 6 days 7 hours ago
Thank you for the review.
Enjoy Big Smile
kaidomain.com KD - LED Flashlights, DIY Parts and Accessories
Inquiry for KD, please feel free to contact me.
mrheosuper
Last seen: 5 days 20 hours ago
2000 lumen highest with just only 4.7A, doubt it !!!
Forgot my pen
doubleone44
doubleone44's picture
Why? The battery voltage under load should be about 3.8V, using a good battery, so this means about 3.8 V *4.7 A = 17.86 W input into driver, with the 90% efficiency of the H1A this means 0.9*17.86 W=16.074 W to the led, and cree lists 2654 lumen with the 18W max input, taking this into account, and 10% losses from reflector/lens, expected lumens are 2654 lm/18 W*16.074 W*0.9 = 2133.02 lm, so above the 2000 lm at startup.
(Correct me if my math is wrong)
mrheosuper
Maybe you are right, im just amazed how far led technology has gone
The efficiency of LED now is really impressive
Forgot my pen
mrheosuper
Btw
According to this test
http://budgetlightforum.com/node/53086
The led gives 2200 lumen at 18w
And your math said the led recieve 16W, so i guess the lumen is about 2000-2100 lumen
With 10% loss of glass and reflector, maybe the number is nearly below 2000 lumen
Still impressive
Forgot my pen
giorgoskok
Thanks for your kind words and nice comments explaining some great things . I was away from home for a few days , so now i got the time to read the comments and update the review Wink
Beamshots coming in a few minutes , and conclusion maybe too .
darrenm
Last seen: 2 years 1 month ago
Great review. Got one of these myself and am pleasantly impressed. Feels like a comfortable 2000 lumens to the naked eye compared to convoy c8 and L6, and slots nicely in between in terms of performance.
Reckon you can convince kaidomain to put a xhp35 hi into the same set up? Even keeping the current around the 4A level? I’d buy that. Don’t have enough time or skills for even simple mods myself.
giorgoskok
xhp35 is a 12V led , compared to the xhp50.2 that runs at 6V , so it will be a little more complicated …
An xhp35 running at 2 amps would be awesome in a C8 , but heat wouldn’t be so great…
darrenm
Huh! I assumed because the xhp 50 and 70 came in 6V and 12V the 35 would also. Oh well, thanks for pointing that out.
On another note, I get a brief bright flicker whenever I enter low mode on mine. Just mine or do other units also do this?
djozz
djozz's picture
Last seen: 1 min ago
It is a common thing in many lights when going from highest to lowest level, it is hardware-related but can be suppressed by the software. (I’m not an expert).
jamaya
jamaya's picture
Last seen: 6 months 3 weeks ago
+1 for me to
giorgoskok
Yes , mine does that too . I guess Jos gave a reasonable explanation Smile
vince
Last seen: 1 year 6 months ago
Out of interest, with the H1A driver that is being used, is there an MCU on-board? I've looked at the photos, and everything seems to be obscured by a huge (I assume) inductor?
lostheplot
lostheplot's picture
Last seen: 3 weeks 1 day ago
been thinking of getting a couple, wonder if they would slide some batteries in them for shipping purposes.
thanks for reviewing the light.
sorry all images down
thanks photobucket
giorgoskok
You could ask them , they will probably be able to do that.
beam0
beam0's picture
giorgoskok wrote:
Review : KDLITKER C8.2 xhp50.2
George, (or anyone who has this) Do you happen to have any convoy C8 to check if the bezel will lego with this?
I’d like to get this and add the convoy SS bezel.
hannesremo
Last seen: 1 year 8 months ago
I bought this light and I love it, dedomed the led and the beam is now alot nicer
giorgoskok
I will check it later today .
darrenm
Honestly, this light has killed xpl based c8s for me. They just don’t compete. Yes, they throw a bit further, but you can SEE so much more with this out to 200m.
I’d love to see more lights with the xhp50.2, maybe an updated A6? And bistro UI too.
I almost like it more than my Q8 (don’t tell Miller et. Al. Though!)
hannesremo
I think this is what the c8 should have always been from the start, C8+xhp50.2 is awesome, small and compact and yet throwy especially if you dedome the 50.2! I tried this in a regular c8, with just the shelf and it became too hot with the xhp50. So the pill really seems to help, barely gets warm at all for me in turbo or mode 3 which I normally use. Xhp50.2 gives a much better beam too, h1-a driver is good too imo!
kiriba-ru
kiriba-ru's picture
Last seen: 3 hours 8 min ago
Yes. It helps to block thermal transfert. Integrated shelf have much better thermal R (probably 20deg difference with 50deg host).
beam0
beam0's picture
Awesome, thanks!
darrenm wrote:
Honestly, this light has killed xpl based c8s for me. ……….
hannesremo wrote:
I think this is what the c8 should have always been from the start, C8+xhp50.2 is awesome!…..
Glad I resurrected this thread Party I wanted to get more input on this one, sounds good!
Was it hard to de dome? How did you do it with an exacto knife or razor blade?
Delta_V
That’s not necessarily a good thing. The LED will still be producing just as much heat as in the C8 with a shelf. If the C8 with a shelf gets hot, that means it is successfully transferring the heat to the outside of the light. If this host, on the other hand, isn’t getting warm, that means the heat is remaining trapped internally and not getting transferred away from the components. Depending on the output, and whether or not the light has some form of automatic stepdown, this may put it at risk of overheating.
darrenm
Lived experience is it gets quite warm, but never hot, across the whole torch. I feel it’s more because the turbo is not heavily over driven (which would be a challenge on a single 18650 anyway) like we tend to do with xpls these days.
The xhp50.2 just seems to be really efficient.
I walk the dogs with both this and the Q8, and this keeps on trooping on long after the Q8 has stepped down. I’m talking 10-15 minutes with no worrisome overheating and no degradation in performance.
giorgoskok
Just checked the bezel , diameter and threads are the same , but Convoy bezel can’t screw all the way down, leaving a 2mm gap .
