Cant agree this. I know knipex quality, but for small tools I would prefer Pro`sKit as best price/quality ratio. For example, I have been used PK-25P-E cutters for near 5 years and they were always able to cut even most thin wires (until met something too strong). They cost under $10.
Thank you and i agree if i can buy tools that will work just fine for a better price then i will as it is for hobby only. Bench power supply is one of the other things im wanting to build lol, just gotta get my electronics skills where i want them first, so i’ll know exactly what i want out of it. I’ve realized if you don’t know what you want then you can spend alot of money and still not get it right.
Yes, gotta take price/quality into consideration no doubt! But no reason to quibble over cutters here. I’ve got plenty of small pliers that can cut piano wires and nails!!!
This thread will be mostly usefull for US members. EU import limits (for companies) restrict product assortiment and raise prices on local markets. Im almost sure that you can find knipex dealer in your country, but wont find many Taiwan brands.
However, I think this is not far away from you: http://proskit-bg.eu/en/pliers/cutters/heavy-duty-cutting-plier-wconductive-handle-1pk5101e.html
LED reflow also works great on a small temp regulated hotplate
Or just a plate of aluminum that provides enough thermal mass so the heat up and cool down follows close to the temperature profilen that is recommended from datasheet,
you can heat it with gas torch or hot air gun
IR thermometer is also good for reflow temperature check
Can’t help ya though.
But I think sticker shock will follow.
I just use solder tabs. Use a high watt iron and be QUICK. Allow to cool if you need a second try. Put Kapton tape under the tabs, on the edge of batt (Pos side) for safety.
No prob, thanks for the reply!
Yea, i’ve looked at prices. Sticker shock did follow lol. It will def. only be bought if I pursue building battery packs heavily (quite possible but not presently).
Thanks for the tips! I was figuring something like that would work fine if you paid close attention.
Thermal adhesives:
Fujik (bad but often good enough, cheap), Arctic Alumina (good, expensive)
Thermal Paste:
Arctic MX-4 is recommended often
Overclockers’ pastes are mentioned often too
Recently I bought GD900 and I think it’s a good choice for cheap lights.
Liquid metal is the top pick for copper lights, but destroys alu ones
