Well, it has the tripod mount screw hole. As long as you had some way to keep it from spinning around, the mounting to a bicycle is pretty easy. Get a pipe clamp the right size. Clamp it onto a tubular part of your bike. Put a bolt through it and screw the bolt into the tripod hole. I’m not sure, but I think an electrical conduit ‘stand-off strap’ would be the cheapest and most widely available. One way you might be able to keep it from spinning at the tripod hole is to use a back-up nut to make it extra tight.
Depends on how bumpy your route is but I’m not sure if I would trust the tripod mount hole for fixing the (heavy) Q8 to a bike, in combination with some form of strap it should be ok.
I have not tried this, but when you are in battery check mode, if you dbl click it takes you to a temperature readout (blinks out temperature) then another dbl click will blink out the firmware number (either a 1 or 1.2). This is listed in the cheat sheet for the Q8.
Long before the Q8 appeared, I modified a 2” (50mm) theater lighting ‘truss clamp’ to securely hold my Noctigon Meteor, which doesn’t have a tripod mount.
The Q8’s tripod mount is very useful, but this method is much sturdier for mounting lights to a car, bicycle, ATV, or other moving/vibrating object.
Truss clamps are available in several sizes and styles. I like the ‘quick release’ style like the one pictured above. Search eBay and Amazon for options.
There are also clamps that fit 1-1/4” to 1-3/8” (32mm to 35mm) tubing.
Depending on your bike’s dimensions and mounting location, perhaps you could combine two clamps to create an adjustable mount?
Checked out my temperature step down in both my lights. One is 28c and the other is 14c. 14c seems a bit cool. I know how to get into thermal temperature step down but I don’t see how to change it. The timed step down I see but not the temperature. Any help would be appreciated.
My apologies blinker…. I have been out & about since I wrote that…. playing in the snow…
I had a brain fart when I wrote that this morning…. :person_facepalming: …. But I see Jason & joechina got you squared away.
Again…… my apologies.
Snow in Alabama. That must be rare. Not where I am. Am still having a hard time with my temperature step down and the timed step down for that matter. Would like to change it but I must be doing something wrong.
If you are in ramping mode you go into the configuration menu and on the third blink (thermal/timed stepdown) you click the button twice. It does a couple of blinks then goes to Turbo. At this point you just hold on to the light until it gets to the temperature that you want it to step down at and then click the button once. It does a blink or two then continues to the 4th menu option.
Note: If you click the button in less than 5 Seconds the settings will not be changed.
I confirmed this on my Supfire L5-S which has NarsilM v1.
Yep… pretty rare blinker. Usually an inch or two every now and then… we did get 5 inches this time… but it will warm up tomorrow & melt.
However back in early March 1993 we had a blizzard. Where I was got just over 2 feet of snow as did about half the state. The whole state had snow & a deep freeze for about a week. Even the coast had 2 - 4 inches.
The state was pretty much crippled for several days….
As far as temp stepdown, I have not fooled with that. I am just leaving mine on timed…. so I can be of no help there.
We had a little snow here in Houston last night. That’s a very rare site. Luckily it didn’t get to 32° so there was no ice on the overpasses or bridges.
Did you add flux? You might need to remove the old solder and use fresh along with flux. Flux it what helps it stick.
Actually, it might be best to not use the normal leaded solder with its lower melting point of 190°C. This job might be best for unleaded solder which melts at about 220°C. Which reminds me I need to buy some lead free.
Thanks Jason. It’s working. I have one of mine going for coming up on 2 hours and it is still just warm. Not close to hot. I don’t have 30qs in. Just solder blobbed Samsung batteries from a almost new laptop battery. Thanks again.
I had AIT at Fort McClellan in Oct./Dec. of 1969. It got cold but I can’t remember snow. I wasn’t prepared for how cold it got. Somewhere around freezing if I remember right.
Temp stepdown taken care of I think. Thanks.
