XHP50.2 J4 4000k output test by Texas_Ace - Really impressive improvement from the last gen
40 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 12 hours 28 sec ago
So to go along with my XHP70.2 test Lumintop also provided me with some XHP50.2 to play with.
The results are about what you would expect from 4x XP-G3’s. Although it looks like they are not the highest bin dies where the XHP70.2 gets the highest bin dies. I suppose that makes some sense, the xhp70 should be more popular, the xhp50 is mostly for retrofit installations and the XP-G3 is a very popular LED in itself.
So it makes right at 5000 lumens hot and a bit more from a cold start. Pretty good for some situations. It also should provide more throw then the xhp70 as well.
Only other thing to note about the test is that the test rig got bumped about half way through and the readings dropped slightly after that (didn’t notice until I was graphing it out afterwards). You can see the drop around the 6.5A mark (dog was very excited and I didn’t notice the test rig shifted). The difference was not enough to re-run the test. Just add a few lumens to the numbers after that.
Click the images for full size.
MRsDNF
MRsDNF's picture
Last seen: 13 hours 58 min ago
Thanks again TA. I’m always referring to these charts when building a light. Thumbs Up
Texas_Ace
Texas_Ace's picture
lol, so am I.
The_Driver
The_Driver's picture
Last seen: 4 days 22 hours ago
Nice test!
I think this LED is greatly underappreciated. It has HID levels of output and luminance.
Texas_Ace
Texas_Ace's picture
It is a good middle ground between the XHP35 and XHP70 that is for sure.
pommie
Last seen: 18 hours 42 sec ago
Thanks for putting in the effort.
3550lm at 4.75A will make a nice cheap(ish) mod for the GT Smile
Cheers David
Nothing to see here folks, move along...
JaredM
JaredM's picture
Last seen: 4 hours 11 min ago
Cheers David
Actually, this test was done in 6v configuration so 4.75A in 12v would be near peak output at about 5000 lumens!
pommie
Hmmmm must be time for an afternoon nap for me to miss that Facepalm
Cheers David
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 14 hours 34 sec ago
Thanks for the testing mate! Its good to see the output double when pushed same as the XHP70.2.
Agro
Agro's picture
Last seen: 3 min 1 sec ago
Only at high currents.
When you use the most powerful 17mm boost driver out there (Schoki’s driver) it’s 4200 vs. 5400 lm.
Texas_Ace
Texas_Ace's picture
Cheers David
lol, it is easy to miss. I am interested to see what the 50 looks like in the GT myself.
Flomotion
Flomotion's picture
Last seen: 1 year 1 week ago
Where to buy a reliable/genuine XHP70,2?
Flomotion
Texas_Ace
Texas_Ace's picture
http://www.mtnelectronics.com/index.php?route=product/category&path=60_114
I think KD also sells some and you can find them on sites like mouser as well.
pommie
When the XHP50.2 J4-5A 4000K finally arrives, should be any day now, and the resisters arrive, only ordered today, problem one will be it is on a 20mm star so some fancy wiring to be done, hopefully I can do the same as my Courui D01
problem two, it is on a 1.6mm board and the GT’s board is 2mm, maybe use a rubber spacer at the bezel??
Cheers David, . . . . . . who has just had his two solder stations burn out within a week of each other Ughh
Texas_Ace
Texas_Ace's picture
I thought about trying something like that but after my own D01 experience, that is something I prefer not repeat lol. I ended up having to use a mill to shave down the solder joints for the D01 to get the reflector properly positioned.
Kourtinoksylo
Last seen: 12 hours 16 min ago
Thanks for the test. I am more confident now for my quad xhp50.2 and its output. Pulling 40 amps means my estimate for >18.000 lumens was right.
At how many amps you would say it will burn? 13?
-Air cooled 4x XHP50.2: http://budgetlightforum.com/node/56829
-SkyRay King 4x XPL HI, TN40 clone: http://budgetlightforum.com/node/55195
-XHP70.2 Maglite 2D: http://budgetlightforum.com/node/54791
-SkyRay King 7x XML2, TIR, 8x 18650: http://budgetlightforum.com/node/54886
Texas_Ace
Texas_Ace's picture
By 13A you would be loosing lumens but the XHP series is pretty tough, they generally don’t burn until you drive them REALLY hard if you have a good thermal path.
10A is about the most I would try to run them at, personally I think around 8A is a good number before the diminishing returns.
The_Driver
Texas_Ace wrote:
Cheers David
For me this is the optimal configuration. I would drive it at around 12V and 4.5A. A shaved XHP50.2 K2 would be similar to the Luminus CFT-90, but with the stock U.I. and much, much cheaper.
EasyB
Last seen: 2 weeks 16 hours ago
The_Driver wrote:
Texas_Ace wrote:
Cheers David
These second generation XHP LEDs are very power-dense, but I don’t think you will get close to an effective luminance of 200cd/mm^2 in a reflector light with the shaved XHP50.2. The actual die luminance will be less than one would think just considering the total output and the die area because there is light coming from the cross and phosphor to the sides of the die, as I showed with the XPG3. Also, in a reflector light, focused at the center, the beam center lux results from an average of the luminance from the die and cross, so the effective luminance will be less, i.e. If you look into the reflector it will be filled with reflections from the bright die but some area will be filled with reflections from the less bright cross.
The_Driver
EasyB wrote:
The_Driver wrote:
Texas_Ace wrote:
Cheers David
Yes I realize they aren’t perfectly suited. But take a look at Texas_ace’s masurements with the shaved XHP70.2. With these we can determine the throw with the XHP50.2. It should be similar to the XHP-35 HI, but with a 30% larger hotspot (8mm^2 vs 6mm^2) and 50% more lumens.
WaylonJennings
Last seen: 1 year 2 weeks ago
The_Driver][quote=EasyB][quote=The_Driver][quote=Texas_Ace][quote=pommie][quote=JaredM wrote:
This is what I was wondering about. Is it possible the the 50.2 could do 5000 lumen and 800+K Lux? I think that I remember reading somewhere that the 50.2 runs a liitle cooler than the 70.2. If this is true, the 50.2 might be a great option in the GT.
WaylonJennings
It looks like it might be time to learn how to do what you guys seem to do so easily. Can you guys recommend the gear I will need to get started? I would rather get the right/best stuff the first time.
It sure would be nice to have TA or one of you other guys just down the street!
Texas_Ace
Texas_Ace's picture
Lucky for you what you need is not a lot. The basic tools of the trade are :
soldering station with temperature control
hot air reflow station (mine is a combo unit with the soldering iron)
Reasonably good DMM
magnifying goggles / heatgear, this makes it way easier to see what you are doing
Fine tweezers
The rest are the mics parts like wires, switches, springs and the like that you will figure out over time.
The soldering station hakko makes some good stuff, I use a china knock-off with good results until a few days ago when the heating element in the iron died. I have a replacement ordered now. Still I got over 1.5 years out of it for $40, well worth the investment.
WaylonJennings
Reasonably good DMM
Fine tweezers
Thanks TA. Looks like I have some shopping to do. Smile
J-Dub74
J-Dub74's picture
Last seen: 1 week 1 day ago
Nice testing work once again TA! Beer
The_Driver
WaylonJennings][quote=The_Driver][quote=EasyB][quote=The_Driver][quote=Texas_Ace][quote=pommie wrote:
The XHP50.2 will only run cooler in a direct drive setup because it has a slightly higher Vf which results in less current.
In a regulated setup the XHP70.2 will run cooler because it is more efficient (more Lumens and a lower Vf).
JasonWW
JasonWW's picture
Last seen: 2 hours 57 min ago
Has anyone tried the sliced 50.2 in the GT yet?
Texas_Ace
Texas_Ace's picture
Not that I know of, it is hard to find an mcpcb for it.
JunctionT
Last seen: 1 year 9 months ago
Thank you for this test.
I’m a newbie and i’m wondering; why is there such a big difference to the manufacturer data sheet values?
Datasheet says on Page 7:
5,65V @ 1750mA (Tj=85°C)
Your test:
5,67V @ 0,75mA
Where does the difference come from?
Texas_Ace
Texas_Ace's picture
There is a range on all the values from Cree, generally they are around 7% but it also varies with other factors as well such as tint, CRI, bin ect. Higher CRI LED’s for example generally have lower Vf.
Each reel will have a different Vf, sometimes the changes are minor, others they are very noticeable.
Wieselflinkpro
Wieselflinkpro's picture
I am thinking about using the 3V XHP50.2 in the Q8. And to keep it safe I would use AWG 22 with 10-15cm length.
AWG22 should have 0,00548ohm resistance at 10cm length. For 48Amps, it would be a voltage drop of 0,26V.
What do you think about it? How long would you make the AWG22?
Is it necessary to bridge the battery springs to protect them from overheating and melting?
