Please add me to the list too. I created an account here just for the F3WA.
I’m curious why XP-G3 is used instead of XP-L2? Is there a chance the more efficient XP-L2 V6 bin will be used or nichia 219c?
Consider Nichias plz.
Looks like I’m the first one to get a prototype. Here are some images and early observations about it.
Note: This is only a first prototype. The FW3A is still in development, and all issues mentioned here should be fixed before release.
The prototype appears to use new host parts designed for this light, but some of the components are probably just whatever Lumintop had laying around. For example, it has cool white XP-G2 emitters instead of neutral white XP-G3, and the driver’s 7135 chips are the wrong brand. These things are not cause for concern.
First, some pictures.
FW3A prototype:
(yes, the tail anodizing doesn’t match… Lumintop was experimenting)
With some other 1x18650 lights: (Convoy S2+ silver, FW3A, Emisar D4 grey, BLF A6 bare)
The beam (XP-G2 cool white, 10507 optic):
The business end, next to an Emisar D4:
Without the bezel or optic: (looks like XP-G2)
The battery is replaced by removing the front half, not the tailcap:
What I can see of the driver without removing it: (not sure if people have seen Fritz and DEL’s driver design, but it’s a thing of beauty)
Some initial thoughts / observations, in list form…
The good:
The bad:
Other notes:
Firmware on my prototype is a beta version of Anduril. Basic use is mostly the same as NarsilM, but it has a few extras.
I have a few things to fix right away. Development may be a little awkward because it looks like I may have to solder every time I reflash the driver, but that’s not a huge obstacle. Anyway, some things for me to fix…
That’s all for now. The FW3A is real, and is making good progress, but there are still things left to do.
Thanks for the update on the “work so far” TK! It really seems to need some improvements and changes, but I must say I’m very pleased to see this “project” getting real shape
From what you said some things are of more “concern” to me, like the button and the noise, and the capacity of heat absorption. But, due to the design and to keep it “small”, this has to be a light for really short turbo boost!
I won’t enter the LED choice discussion as I’m not expert on that, but for what has been said, the LEDs can be easily replaced as well as the optic? Maybe this is not a major concern for me but for other members it may be…
Thanks for the update on this and… please get that Anduril ready to rock on this beauty :smiling_imp:
BTW, I hope The Miller is ok! :+1:
Nice report! I’m still very much looking forward to having a few of these lights. The size is wonderful and wish more manufacturers would make them this short. I think that’s why I like my Zebralights so much. A single emitter one would be a hit with me as well due to the small size for an 18650-powered light.
As for the power, it’s nice to have lots on tap, but I’m very happy with the middle settings of my Convoy S2+ and Astrolux S1. It’s fun to crank up my D4 to impress others, but I think that this light will still be popular for having a great size, extra light when you need it and ramping to allow anyone to adjust to their heart’s content. Oh, and a pocket clip!
Looking forward to seeing changes and updates as they come.
This thing really is small for an 18650 light. It’s shorter than some 1xAA lights I have, and even shorter (and lighter) than the Brass Beauty (though not as narrow). It brings good runtime and hotrod burst mode to a small form factor, with plenty of flexibility and extras. Once we get it finished, I think it’ll be a huge hit.
Like! Thanks for the update.
Just so I understand, is the inner tube around the battery electrically isolated from the body? Is this the circuit path that the E switch uses?
It looks like it. The klarus xt11s has an identical inner tube/setup
What do you mean? What has changed?
Was that question about the tube? It seems to be there…
The long ramp from the front section, down the tube, makes it look like a Nitecore Concept 1 or HDS Systems EDC Rotary. Not saying I don’t like the style, I do, it made me buy the Concept 1, but Fritz’s design is cleaner, neater, more business art and unique. The custom straight off the lathe look is what drew me to it in the first place.
Oh, now I see what you mean! Yup, indeed this prototype seems a bit different from the original drawing! Maybe it’s just due to being a prototype? Or will it be like this in final version?
Oh, you mean the shape under the clip? The hard edge would grab your clothes and make it difficult to unclip. The tapered edge allows for it to slide cleanly.
This change was posted a week ago so a didn’t realize that was what you were talking about.
A simple 45º bevel at the hard edge in question would solve that without adversely affecting the simple elegance.
Sure, I could just chuck it up and recut the tube, no problem, but figured I’d ask why it was changed.
Just like Fritz’s clean lines as compared to mimicking others…
They would not need that taper if the clip were longer, but then it would rub the head when you unscrewed it.
A shorter clip probably wouldn’t work very well.
I personally don’t like the sand blasted finish. A raw clear coat would look better. I think that’s what was called for in post 1. A raw, machined look.
Very interested! Put me down for one please.
From what I hear, the bead blasted finish was a misunderstanding or something and the real thing should have more of a fresh-machined look.
About the sharp lip at the front vs the smooth ramp, I’m not sure which I like better. The sharp edge gives a nice symmetry compared to the back and may look a bit nicer, while the smooth ramp seems more practical and ergonomic. It adds a bit of thermal mass, makes it easier to unclip, and helps differentiate one end from the other by feel. Both ways seem okay to me.
