PM sent
14.5$ with temp+LVP calibration and max temperature preset,
4,85$ 47.5mm MF01 MT03 Q8 +4,85$
1.2$ LDO 1.2$ 21mm and bigger only
1$ for SRK Size with more than 8 AMC7135 Bank with all 16 AMCs
2$ envelope priority air mail shipping worldwideadds
3$ for optional tracking + insurance up to 25€
Total $26.55?
is that correct?
This is correct
there was a mishap from DHL Express on Thursday as the driver did not schedule new delivery, when I had not the import tax to give him, as they seem not to have any to exchange larger bills
so I had to phone the hotline and its delivered again on monday
4 envelopes shipped today
list up to date
So big Seeed order arrived
Was busy with new stuff
:+1: Lexel
Keep this up and I’ll have to get another even before I receive the first.
Nice Lexel. How was the cutting out?
wow you even have solder mask made for the boards. Cant wait to have mine, this is a second board from you Lexel :+1:
Cutting out was not so easy, I have already begun to drill the last 7+9 boards lineed up through holes in my vise and started to drill quite some holes to make cut out easier
Also found out that the cutting is quite bad for my saw blade, even hardened steel wears out fast
Used a Dremel to sand the boards round which goes quite nice
First S42 driver married with original piggy back board
and no more pink boards I had to use my Dremel to grind down 0.5mm from original diameter, as I have to cut them out anyways no extra work, looks messy on Macro but in real light does not make a difference
MCU of old is partial unsoldered so the breathing mode does not drain 1mA
downside the Charging indicator LED does not work, but it charges
Is it still possible to order ?
I’d like a 30mm with Narsil for my Amutorch JM70 (tail clicky + side e-switch)
I have now dozens of drivers ready to go and over 200 boards, so the sale is hot
I have shipped yesterday and todays quite some orders
added shipping date to the excel sheet so you can see when it got shipped
Have you thought of a name for this new business your are running now? Lol
Interested in an MF01 V1 board if it can be met:
NarsilM, 2S, SD=6V, PO=(NO), lighted side switch + 8 7135 for full 16AMCs
So that means protection current of 3v per cell, but it won’t shut off correct?
Will the indicator function as the Q8s? If not no big deal, but I’d like the side switch to at least stay lighted.
I would like a bypassed spring if possible.
Postage to the US no tracking or anything, whatever is cheapest.
LVP shuts down the light and put the MCU into deep sleep so parasitic drain in around 30uA
You won’t get side switch light function like with Q8 due to it being 2S. The leg of the mcu that would normally control the switch light gets used instead to monitor voltage.
You can still have a lit side switch, though. You will just need to wire it to a positive voltage source. You can wire it so both red and green lights stay on or just one or add custom colors. Then just break the battery connection to turn it off and eliminate all drain.
