The high Vf is a blessing for functional lights with our direct drivers, like the BLF-A6 or the Q8, those modern low Vf leds are driven far into the inefficient top of the output curve in direct drive, which is interesting for output addicts but it makes it a less useful flashlight. This could be competition for the XP-L, especially if it comes in good tints.
Btw, both the looks and performance are very close to the LG H35F0, I’d be surprised if these two korean leds are not very close related. Expect unbearable green-ness in the high CRI versions!
(I tested the LG H35F0 4000K 90 CRI led but did not post it, the led that I tested maxed out at 8.5A at a Vf of 4.09, with 1730lm output. Considering it was a 90CRI led, the 21% lower output compared to this Samsung led is perfectly consistent)
Edit: forgot my manners for a moment: thanks TA for another insightful test!
Thanks for the update, that would be my bad. I updated the charts if you refresh the page with CTRL + F5 it should show them. It also includes the bin now.
Yeah, it will limit the current to make the light more useful but on the flip side if you already have a regulated driver it will drop out of regulation much faster then other LED’s.
For example I generally use the TA drivers with the all 7135 mode but it is nice to have the turbo mode for when you want some extra.
Sad to hear that the high CRI versions could be green, I have had enough green LED’s for my lifetime.
Wow! 1000lm - 137lm/w (XP-G3 - 100lm/w). Way be very usefull for small capacity lights.
LEDs from same reel were tested by maukka: Samsung LH351D color testing
Yeah, these blow the G3 out of the water. The tint is much better then the G3 or L2 as well, no ugly tint shift that I saw.
Good to see that they also have good tested tint as well.
These samsungs are not using the flip chip setup, which in part explains the higher Vf. It could also mean they can be dedomed, although I have never really liked or been very good at dedoming.
Nice test, TA. It looks like DigiKey has these at a pretty decent price and with good price breaks, too.
I’m wondering… would you be able to do a combination chart with this vs the XP-L V5 data you have? Looks like a real close competitor and a graph might help.
Also, what (if any) reflectors have you tried this in? How’s it look (especially with regards to tint-shift)? Maukka mentioned it looked good in his initial findings, then said it looked ugly when put in an EE X7.
Not necessarily, that is only for buck drivers with the same amount of input cell stages as in series output emitter stages. Besides all the theorizing, this for example is no problem with 2+S input for a single emitter, the down-side of this approach may be finding good 18350/26350/whatever short cells, formats which are not developed/manufactured by the big players in the li-ion industry.
This is the reason many times I've wished for a buck/boost driver which, on the other hand, would be necessary for driving violet/UV based emitters properly, I believe.
Stupid question here: are these led “good” to be used with the MTN DD drivers in triples or quads?
Since I started using the Wuben TO50R with these Leds, much has changed in my perception of neutral white and high CRI, so I wanted to build another light with these. But I want it to be triple or quad, floody!
These LED’s seem to be better suited to reflectors vs TIR optics in my experience. I think that the large die is just bigger then most TIR optics are designed for.
In reflectors they actually look pretty good.
I recently built a few AAA lights with some of these that a member on here sent me for my family members “purse lights” and they look really good in those.
That said, if you’re pleased with how they look in the TO50R optic and you can find a suitable optic for your build, I doubt you’d have any issue with a triple/quad and a FET driver. Between these having a higher vF and you running multiple (presumably in parallel), I don’t foresee any problems.
I like these in reflector lights, because of the big die the beam looks nicer and is easier to center and focus than small-die leds, i.e. the White Flat is quite a pain to center and focus.
TA, gchart and djozz, thank you very much for your input on my questions!
I didn’t realize these leds are larger than the other “typical” LEDs!
Still, I guess I can mod an optic to make them fit Or…maybe I can use them just in reflectors!
BTW, I know that OP reflectors are probably better for these, but do they “perform” well with SMO reflectors? My Tool AA lights could benefit from an improvement if they are good for SMO as well.
Once again, thank you very very much for the replies
