Updated my UV-led test method (=final), tested a Luminus SST-10 365nm led (and some others)
51 posts / 0 new
djozz
djozz's picture
Last seen: 2 hours 8 min ago
Introduction of an updated method of testing UV-leds.
I make a point of posting my test methods very thoroughly because the equipment that I use never looks like a slick designed box that makes you automatically trust in what it is doing, but it usually is a messy combination of loose (but well-chosen) components, carefully bought, found in the kitchen drawer or scavenged from other equipment. That does not imply that it works less well than expensive manufactured equipment, it may work less well, just as well, or - who knows - better.
Measuring the output of UV-leds can not reliably be done with a luxmeter because if your luxmeter does a good job, it does not pick up any UV. And if you own a cheap luxmeter that does pick up UV, the detector's sensitivity probably is on a a steep slope for 360-400nm, making the read-out very sensitive for peak wavelength and spectral profile. And I fear the UV will cause damage to the delicate and expensive optical filter that is in front of my luxmeter detector. The solution could be using a radiometer, but those have their own pitfalls (like, again, large sensitivity differences in the 360-400nm region), apart from that they are expensive and I do not own one.
My way of measuring UV-leds, forced by not owning a radiometer, has been measuring radiometric output indirectly, by inducing fluorescence in photocopier paper (which absorbs a broad band of radiation from blue light to deep into UV) and measuring the resulting blue light with a common luxmeter. Having read into other methods of measuring UV-leds, this even circumvents some problems and errors that other methods have (like fluorescence of the integrating sphere coating). But of course it introduces errors too, and I'm not equiped to measure or estimate them all. The desired goal of this fluorescence method is: the number of blue photons (which I can measure well) should be a decent measure of the radiant power of the led (which I can not directly measure). There's a number of assumptions in this principle: 1) the radiometric power/blue fluorescence ratio does not vary with wavelength (I can not measure that), 2) the fluorescent substance responds to the UV-illumination in a lineair way, i.e. is far from the saturated state (can be measured but it is difficult to distuinguish from bleaching), 3) the fluorescent does not bleach (nope, copier paper at least does bleach!).
One and a half year ago I devised my latest test method for UV-leds (link), which was already method #3, but I was never very happy with it, mainly because the used photocopier paper bleaches significantly: when after a led test the paper was illuminated with a uniform UV-source you could see that the area used for the test was a little bit darker, indicating that at least the latest numbers in the led test are too low. Also not every sheet of paper showed the same amount of fluorescence, even within a single sheet there is usually a slight variation measurable, so I had to calibrate each piece of paper before a test.
The solution was to find a source of UV-fluorescence that does not bleach. What I remembered from working (in a distant past) in a lab that worked extensively with fluoresecent dies, is that basically every fluorescent substance shows bleaching (=the absorbed energy from photons may cause a chemical reaction of the die molecule which converts them into a non-fluorescent compound, so less and less fluorescent molecules are leftover). But thinking of that, I could imagine one substance that may not show bleaching at all: vaseline glas (other names: uranium glass, Anna-green glass), which is glass that shows some UV-fluorescence caused by a few percent uranium in the glass-matrix (which gives the glass its distinct green glow in daylight). I could not think of a way that the uranium in this glass could undergo a chemical reaction easily and an old collegue of mine that I consulted about this agreed with me. So off I went searching for vintage glassware (vaseline glass was popular at the beginning of the 20th century) and I found a plate with a suitable flat center that (with the edges smashed off, I did not tell the previous owner that) could serve well enough as a piece of measuring equipment Big Smile .
So together with some other finetuning compared to method #3, here's method #4. And I do not intend to change the method any further in the future. The picture below shows the parts, that during the measurements are stacked on top of each other over the 80mm hole of my integrating sphere.
From left to right (=from top to bottom in the stack)
  • my usual cooled copper mount for testing leds
  • a reflector with the bottom sawed off so that it fits the ledmount (reflector facing down), this is to make sure that as much of the light of the led as possible is directed downward, and enters the fluorescent glass. It should make the set-up quite independent of beam-profile, and some simple tests including shining a narrow UV-source down the reflector in various angles proved that to be true.
  • a sheet of ZWB2 filter. This removes any visible light that the led produces (which will add to the light measured in the integrating sphere but does not contribute to the UV-power that you are trying to measure), as well as favour leds that truly peak at 365nm, because the filter has its transmission peak at 365nm.
  • A flat-ish piece of vaseline glass, this will convert (a portion of) the UV-radiation into visible green light. It has scratches and slight irregularites, but because quite a surface is used the fluorescence that enters the sphere is pretty consistent.
  • a sheet of LEE 226 filter (glued in a round plastic frame). This very effectively removes the remaining UV so that no UV enters the sphere (and then may damage the luxmeter) while transmitting the green light. Also a yellow filter can be seen that can be used for measuring 385nm and 400nm leds (without the ZWB2 filter in the stack).
So this all goes on top of my (messy sealed) sphere (auxilliary light switched on for picture):
And during a test, it looks like this:
The three meters are my luxmeter, the voltage of the led, and the current through the led. The power supply can not be seen.
The tests.
One of the goals was finally getting a calibration of the measurements so that I can tell the output of 365nm leds in milliWatts, and so I did 4 tests on different leds that have a datasheet that gives output specifications, two of the four I have measured before : a Nichia 276A U365, the LiteOn 3535 365nm led, a Luminus SST-10 365nm led, and a nichia 233B 365nm led.
  LiteOn 365nm (new type compared to previous test)
  Nichia 233B 365nm
(the 276A is pictured in several other tests)
I measure the leds in my usual way, I test one bare led, cooled very well, starting at low current and at each increasing current setting letting the led settle for a moment before recording the numbers. What is typical for 365nm leds is that upon each current increase the initial output shows some gradual (slow) dropping, I think it is a temperature effect in the die. Blue leds (and thus white leds) hardly show this but I know that red leds are also very sensitive to temperature.
The LiteOn led and the SST-10 led were tested on a DTP-copper board, the two Nichia's were tested on my custom N.119 board (ok quality but non-DTP).
I took the results for these 4 leds and compared them to their respective datasheets, hoping that there would be a unifying multiplier for my test method that worked for all of them. Of course I was not so lucky, if I was to follow the datasheets these would be the multiplier (converting my integrating sphere read-out to mW) for the 4 leds:
Nichia 276A: times 60
LiteOn 3535 365nm: times 45
Luminus SST-10 365nm: times 41
Nichia 233B 365nm: times 74
A couple of options to explain the large variation:
1) my method wobbles. I do not think so, for example I re-measured the 276A led and got close to the same results, and I do not see reason why it would vary so much (I expect a few percent variation, but not 80).
2) the (some) datasheets are untrue. Could be, I don't know
3) some of the particular leds that I measured are damaged and do not perform according to their datasheet. A possibility: the 276A was salvaged from a Convoy UV flashlight, I have no idea how and at which temperature it was reflowed before. And I asked Clemence about the 233B, that I received as a present from him, and he said they were samples of the brand new leds he got from Nichia and could very well imagine that he received some rejects.
So I took the liberty to ignore the results for the two Nichia leds, while the other two were close enough together to accept, and decided to define the SST-10 multiplier ( x41 ) as my standard calibration for this method: the '365nm djozz-mW' laughing, whatever that unit is worth in the real world.
Here are the results for the 4 leds, take into consideration that the 276A and 233B may be damaged leds.
 What can be seen?
  • the nichia 233B sample led that I tested, if my calibration is anywhere near correct, nowhere meets the specified 1400Mw at 1A, but I assume that the (expensive!) versions currently on sale do meet it, Nichia is not a shady company AFAIK wink
  • the liteOn led still is a great led, and cheap. It does show some visible stray light (way more than the Nichia's) but in flashlight use that can be easily filtered out by a ZWB2 filter.
  • The Nichia 276A led in the test does not perform to specs either, possibly because of a careless reflow session in the Convoy flashlight it was in before.
  • The SST-10 is the winner here, not much visible stray light (observed by me but not shown in this post) and great output, possibly over 2000mW  when current is over 2A (not measured). The voltage though is pretty high, direct drive on a single li-ion cell the current will not pass 1.2A and 1500mW. This can also be an advantage: you can use any popular direct driver, like the BLF-A6 driver.
Conclusions:
I really like the method as it is now, but it still has to prove itself over time.
And get the SST-10 led, it is great!
Thanks for reading!
Edited by: djozz on 12/11/2017 - 08:42
Jensen567
I like the new test method, U-Glass seems like a good fluorescent source, wouldn’t even have thought of that. I do wish your multiplier was x42 though, just because that is the answer to life, the universe, and everything after all, so it must apply here.
More anecdotal evidence but I can confirm the observation that the SST-10 seems to have a lot less waste light than the Lite-on. I really like my SST-10 UV emitters, worth the small extra cost over the Lite-On IMO. They also have SST-10 in a few colors (royal blue, deep red, and far red right now, normal red and green are scheduled), and IR wavelengths.
MRsDNF
MRsDNF's picture
Last seen: 3 days 11 hours ago
With the highest respect intended, what a great lesson on UV light Professor djozz.
I’m a bit dumbstruck about the technicalities on measuring UV and the effort you have gone to. Thanks.
Discolouring paper as it leaves bits of light behind in it, amazing. I’m not sure if I should be scared when I come to visit now. Smile
djozz
djozz's picture
Thanks Jensen, I’m glad you approve the method
MRsDNF wrote:
With the highest respect intended, what a great lesson on UV light Professor djozz. I’m a bit dumbstruck about the technicalities on measuring UV and the effort you have gone to. Thanks. Discolouring paper as it leaves bits of light behind in it, amazing. I’m not sure if I should be scared when I come to visit now. Smile
LOL, professor djozz Smile , hardly so. If I try to read what the experts write down on light measurements, I ignore half of it pretending for myself that I would easily get it if I would dive a bit more into the subject Innocent
But thanks! Smile
FmC
FmC's picture
Thanks for the testing again!
If my current A/C leak detection torch ever dies (or more likely gets lost..), I’ll have to make another using that SST-10.
CRX
CRX's picture
Last seen: 16 min 57 sec ago
Looks good.
Scientist
Scientist's picture
Last seen: 4 days 6 hours ago
Thank you djozz for your excellent data. Do you think running the SST-10 at 1500mA or 2000mA will shorten the lifetime significantly? Any way to cram three of these in the Sofirn host that is now on sale for cheap?
ggf31416
Last seen: 14 hours 27 min ago
LOL. You will need to apply sunscreen with a high protection factor before using it in a triple Cool
djozz
djozz's picture
Agree, that will be one bright and throwy UV-light, it should work but since there is no affordable UV-pass filter in that size you will have to live with the little visible stray light.
About the lifetime question: I obviously have no longterm data on the SST-10 at 2A, but in general 365nm leds seem sensitive to overdriving them for a prolonged period, at least the Nichia 276A is reported to dim or fail over time.
Scientist
Scientist's picture
I’ll let you know how it turns out…
Jerommel
Jerommel's picture
You won’t get 2 Amperes through the SST on a single cell.
2Q19
djozz
djozz's picture
You are correct of course, and at the 1A per led that you will be able to run the triple direct drive on a single cell, the lifetime expectancy should be good.
The output should still be impressive though, at more than 3W radiation OTF.
clemence
clemence's picture
Last seen: 14 hours 59 min ago
Whoa professor Djozz. That’s a great DIY way to measure the UV. Salute! I thank you for doing this. I can imagine the joy you had doing it.
As for the 233B. Yes that’s just samples I got for PCB footprint testing. Please ignore the output.
- Clemence
djozz
djozz's picture
- Clemence
Correct Party , designing test methods is way more fun than continuing doing tests on new leds once the method is settled, but I will try to measure a new UV led every now and then.
Agro
Agro's picture
Last seen: 1 min 2 sec ago
But is there a triple optic that will work with UV?
Lexel
Lexel's picture
Last seen: 12 hours 37 sec ago
I got information Simon is using a LG UV LED in next Convoy UV batches, as the SST-10 UV 365nm are more expensive at same performance
it is listed with 1360mW@0.7A
and drive current on the G1performance group is 700mA und the H1 1500mA max. he got the one that’s only 0.7A, but I think it will run fine at 1.5A
https://www.lasercomponents.com/fileadmin/user_upload/home/Datasheets/lg...
djozz
djozz's picture
^ Cool! I have been trying to find that led for sale for 2 years now, but I can’t find it in small quantities with normal shipping costs. I even emailed lasercomponents.com because they are distributor of LG UV leds, but had no luck getting samples from them.
Lexel
Lexel's picture
ask Simon from Convoy for a test sample
djozz
djozz's picture
Good idea!
djozz
djozz's picture
djozz wrote:
Good idea!
No need, he already lists the led for sale. But his picture is an older generation of LG UV-leds than I thought it would be. Still cool to test but not the latest and greatest.
Lexel
Lexel's picture
At least he has 2. best flux bin and 3. lowest voltage bin
960-1060mW @500mA is impressive
The_Driver
The_Driver's picture
Last seen: 18 hours 47 min ago
Djozz, this is a great thread! I applaud your efforts to find a repeatable measurement method. Thumbs Up
Lexel
Lexel's picture
Simon asked me for your shipping address to send you a free smaple djozz
mrheosuper
Last seen: 18 hours 34 min ago
http://budgetlightforum.com/node/57915
this host with triple UV led and a DD driver will outperforming many high-end UV flashlight, i guess
Forgot my pen
gravelmonkey
Last seen: 2 days 16 hours ago
mrheosuper wrote:
http://budgetlightforum.com/node/57915 this host with triple UV led and a DD driver will outperforming many high-end UV flashlight, i guess
Yes, could be a perfect combination, but the large diameter filter glass (ZWB2) is difficult to purchase.
Jaded
Jaded's picture
Last seen: 5 months 4 weeks ago
Nice work, djozz. Would you care to update this thread by testing the LG UV-A 365 nm? I’d like to see it fare against the 365 nm UV LEDs in your test. I’m sure it will not top the Luminus SST-10, but I think it will beat the two Nichias. I’m not sure about the LiteON. I have the LG UV-A and I’m using it. The visible stray light of the LG is tolerable, maybe not as bad as the LiteON. I’m curious to see if getting the SST-10 is worth the extra price.
djozz
djozz's picture
I have one of those LG leds in house to test but I’m waiting for the Seoel Semiconductors version from Kaidomain that is stuck in the mail somewhere, to do a test of both.
Jaded
Jaded's picture
Yes, the one from Seoel Viosys, too. The CUN66A1A. I’m curious to see both of them in your test.
Lexel
Lexel's picture
The SST-10 has no white wastelight and pretty few violett visible light, so an UV filter is not really nessesary
exekutive
Have you considered using a diffraction grating to measure the output at a desired wavelength? All you would need is a slit at the calculated angle, and your detector behind it. You wouldn’t need all that filter stuff.
Scientist
Scientist's picture
We’ll I am sure djozz will chime in but in order to do this your detector has to be sensitive to UV wavelengths and these are quite expensive. Djozz elegant solution is to convert the UV to visible wavelengths using the uranium glass so he can use regular inexpensive light meters to measure the intensity.
