He’s busy.
Here. I have something better than my mcpcb, I have a few of clemence’s two-pad mcpcb, it should perform like a DTP-board, or even better.
But first we need a seller
I think this emitter will be potent performer, and his higher forward voltage will make it one of the best led emitters for single cell FET driver configurations.
Then there are these: http://led-mounting-bases.com/new-version/en/actualites/news/new-star-boards-tri-xq-and-quad-xq
This is interesting… http://led-mounting-bases.com/en/led-mcpcb/16853-star-pcb-for-4-leds-cree-xq-e.html
Wonder how hard it’ll be to convince them to make a 3x3
Have you checked out they boards Clemence had made? Perhaps he could whip up a 3x3 after we try this in a 2x2 config.
When I can get the XD16, I will test it on one of his boards
I hardly wait for your review :+1:
2 pc XD16 will fit perfectly on VR16S1. Up to 4 pcs in 4p config (scraping required). Not so with the VR16SP4….
E21A on VR16SP4 (rev. 2)
XD16 on VR16SP4
Zoomed in
The XD16 pads oversized the E21A pads by 0,17mm (at three sides), and the gaps is 0,3 mm as opposed to 0,2 mm with E21A. The board can be used but not a perfect match.
- Clemence
Please make single pad dtp board in classic size (17 and 20 mm). Even if it will not reach surface brightness(probably it will not but fingers crossed) of lets say old version XP-G2 it should be very good performer for single cell fet flashlight(especially aspherical version)
Hope someone will send them to Djozz for testing and of course with your DTP board.
Just regurgitating stuff here, but this was in a email from LpN this morning:
“Cree Launches Industry’s First Extreme Density LED — LED professional - LED Lighting Technology, Application MagazineFREE+Information+Service&utm_campaign=47c4f03172-LED+professional+Newsletter%28LpN%29+Dec+15%2C+2017&utm_medium=email&utm_term=0_ff8d2246a5-47c4f03172%5BLIST_EMAIL_ID%5D&ct=t%28LED+professional+Newsletter%28LpN%29+Dec+15%2C+2017%29&mc_cid=47c4f03172&mc_eid=%5BUNIQID%5D”:Cree Launches Industry’s First Extreme Density LED — LED professional - LED Lighting Technology, Application MagazineFREE+Information+Service&utm_campaign=47c4f03172-LED+professional+Newsletter%28LpN%29+Dec+15%2C+2017&utm_medium=email&utm_term=0_ff8d2246a5-47c4f03172%5BLIST_EMAIL_ID%5D&ct=t%28LED+professional+Newsletter%28LpN%29+~~+Dec+15%2C+2017%29&mc_cid=47c4f03172&mc_eid=%5BUNIQID%5D
http://www.cree.com/led-components/media/documents/ds-XD16.pdf
Hope this will be good led and bye bye to dedoming
I saw similar comments when the XPL-HI was released. I think it will take a long time before dedoming is a thing of the past
OK,
Than we will dedome it
We just need to buy it but where?
I want to get my hands on some of these too!
For me personally dedoming did become a thing of the past with the Cree HI LEDs. I hate the tint shift with dedoming so for throw applications I only use the current HI LEDs. I don’t do 1000 meter throw lights though, it’s not my cup of tea. These new ones look real interesting though! Eager to try them out.
Available now here
https://www.arrow.com/en/products/search?q=xd16
Now we need to wait for mcpcbs to mount to.
Got my shipment from arrow. I’m making a board with 1.6mm thick copper. The two pieces will be adhered together with JB weld. It will be electrically insulated from the shelf with some kapton tape.
I will do lumen measurements on this one and put it in an X6 to do throw measurements. I then have a design for a 3x3 3V array. :laughing:
Could you use thermal tape to adhere your invention to the pill? Something like what Taskled use to stick there drivers down with.
Heres a link to Cutter for thermal tape.
Interesting, can’t wait to see the results. I have an mcpcb coming from Clemence to test these out myself at some point.
That tape looks pretty good, but I think I have a good plan. Instead of covering the whole surface with kapton tape, I’ll use just small strips to isolate the board from the shelf, leaving mostly air separating the two. The space will be filled with thermal paste. This kapton tape is 50 microns thick, so it will be just a bit thicker than a normal application of thermal paste.
