The NEW Sofirn C8F Triple XP-L W2 w/side e-switch
whats the stock throw on the light?
im curious how it would stack against astrolux c8…
Remember that this is a triple reflector light, like the Q8 is a quad reflector or like the BTU Shocker is a triple, only much smaller than that here in the C8 format. So, it’s better than building a C8 with a Ledil CUTE-3 Optic but of course less, much less, than a built C8 with throw in mind….
28.5Kcd Lux
337.64M throw
Hi everyone else :-D and Dale, saw your last comments in my C8T review thread a while ago. Ya know, don't be jealous about what others do in their reviews, jealousy virtue is not. Everyone shares his/her two cents and so do you. :THUMBS-UP:
I am also going to receive one of these C8F torches hopefully in a few days. This seems like a nice bundle, even if the chosen cell wrap seems funnily misleading.
In the meantime, my kitchen lamp's central 5730 led array got ruined and is now undergoing a prolonged downtime while I receive a new 100 pack of Osram Duris E5 CRI85 5700K 5730 emitters and bases. In about two weeks everything should be at home but damn, Christmas is just around the corner…
Cheers :-)
Not to de-rail your C8F thread, but what advantage would you say you gained over the stock XP-L2?
I’ve seen around 40-50% increase in a light running at about 3A, so say a light has 900 lumens max… swap in an SST-40 and it’ll be in the 1400 lumens range. A bit on the blue-white side, but not bad and certainly acceptable if that increase is needed. (most of the time)
The idea of a triple with a reflector in the C8 format is enticing. I just might have to get me one. Do you know what the driver diameter is? Looks like 17mm in your photo. I will be replacing it with one of my own.
Went outside and took a little video with my smallest camera, probably talked too much but I guess y’all are used to that by now. :stuck_out_tongue: It’s uploading to YouTube, will post it directly. (now, this is unedited so don’t expect too much)
Not sure about the C8F, I’ll leave that for Dale. But I do know they sell C8 hosts in both 17 and 20mm.
Driver in this one is 17mm.
Great review!
And looks like a great light. Sofirn is putting out a lot of quality offerings. :sunglasses:
Another great review, Dale. Thank you!
Ordered one to add to my small collection :wink:
So, a dozen lights is a good start, right?
All the best and Merry Christmas
Mike
<drooling uncontrollably>
Merry Christmas Mike. :slight_smile:
And the rest a y’as too! :wink:
Hey Dale, gave you taken a look at the switch pcb yet? I’m curious if it has pads for leds.
This looks like a good candidate for one of Lexels TA drivers.
A rear switch might be nice to avoid parasitic drain. Have you tested the drain yet? I guess the anodized rear threads mean you can give it a quarter turn to lock it out.
Concerning the stock driver, what do you think of the UI? Is it one click to turn on, press and hold to turn off? How does the memory work, do you have to press and hold 0.5 second to get it to come on in the last mode? Does a normal click on always start in low?
I hope it will be offered in CW color as well.
A 26650 version of this light would be really sweet.
The switch pcb already has two led’s on it with resistors for each one.
A simple 1/8 turn of the tail cap gives lock out.
The UI has 4 groups, I like group 3 with press and hold for moon from off and double click from anywhere for Turbo.
Click on, press and hold for off, yes.
A short press and hold utilizes last mode memory, a short click starts in low 1, press and hold from off for moon, which does come on in the last mode memory then shifts down to moon. Not ideal, but easily dealt with.
Pretty complex light for such a new company, nice to see they’re into it and thinking. :wink:
As always a great and detailed review Dale, ordered one at Ali. :+1:
Thanks for the review!
Damn. Code’s limited to one-per-customer?
Hmmm, that UI sounds like a pain. Couldn’t they make it one click on/off, press and hold to cycle through the brightness settings? Dbl click for turbo. Have memory stay on all the time.
It still looks like a good host for a TA fet driver, though. Wire up the switch leds so you know when the tail cap is tight or loose. It might give my modded supfire a run for its money.
Agreed. That’s basically what Zebralight, Olight, and Armytek all use on their e-switch lights - some variation of click-on, hold to switch modes, click to turn off. This click on, hold to turn off UI that is so common in budget lights is annoying in comparison.
Would also like to see how this does with XP-L HI emitters - should give it a little more throw, and the HI emitter just gives a nicer beam IMO.
