13576 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 1 hour 42 min ago
contactcr wrote:
If the entire tail end is glued I assume there is no possibility of a shorter 18350 tube? Given how popular that seems to be with the Emisar line and several mentions in this thread is that already a done deal or could there still be a short tube for sale separately?
That was just the prototype that was glued. The production version might not be.
To do an 18350 tube would require 2 tubes. One inner and one outer.
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 16 min ago
I don’t know if the glued tail end is part of the plan or if it’s just a quirk of the prototype. I’m hoping it won’t stay that way in the future.
About a shorty 18350 tube, I doubt that will happen. The host design doesn’t seem very amenable to that sort of change. It would need a new clip, a new outer tube, and a new inner tube… with the clip and outer tube redesigned instead of just chopped.
contactcr
Last seen: 7 hours 4 min ago
My 6x Aspire cells are upset but i’ll get over it I suppose. Would be cool to see this next to a BLF A6 w/ 18350 and D4 w/ 18350. It’s like a mini evolution.
joechina
Last seen: 5 days 17 hours ago
In the FW3A it seems 2 concentric tubes are clamped flat with the PCB in the endcap: Bat. neg. tube + switch signal tube.
And the inner tube must make contact. To keep that glue is a possibility.
And don’t forget you have also to clamp the clip in place.
ToyKeeper
ToyKeeper's picture
I think Fritz is supposed to get his prototype today; it might answer some questions. Like, maybe his tail won’t be stuck together. Hopefully his button won’t be as jittery (or at least I hope he can reflash the firmware to get fixes).
The way the tail end is designed, I can see why glue would be appealing. The tail PCB has no retaining ring unless you count the outer tube. This allows it to be shorter, but also means the tail parts would all be floating when the tailcap isn’t tightened. If those parts rub together a lot, it could wear away insulation and cause a short between inner and outer tubes, which would make the button not work. To avoid loosening the tailcap during battery changes, it might need to have knurling added to the middle section (and maybe removed from the tailcap), which would look and feel odd.
Perhaps something can be worked out though. I’d still prefer no glue, even if it makes battery changes a bit harder.
Firelight2
Firelight2's picture
Last seen: 1 hour 19 min ago
Maybe it’s possible to still use your Aspire 18350s!
Just mod your FW3A with a zener diode on the driver. Replace the stock LEDs with triple XHP70 (you might have to make a custom star for that) and run it on 2xAspire 18350 in series!
Firelight2
I agree… no glue please!
DB Custom
DB Custom's picture
Last seen: 32 min 14 sec ago
The tail cap has a taper to it’s outer dimension, should help to distinguish the operator end from the business end. And of course, there’s the clip.
There have been group buys here lately where everyone’s opinion is weighed and averaged to determine the final aspects of a light, I didn’t think this was one of those… Fritz designed a light and The Miller helped find a manufacturer for production. Seems everyone still want’s to weigh in with their opinion anyway. Guess I got it wrong in the beginning… not surprising really, my success rate lately has been more about successfully getting things wrong than otherwise.
djozz
djozz's picture
Last seen: 2 hours 43 min ago
I did not express my opinion with the idea that all opinions will be weighed and averaged, you are correct, from the start it was made clear that this was Fritz’s design so it is up to him and the team how it is going to look like.
But I still liked to express my disappointment in the changed looks.
Flashy Mike
Flashy Mike's picture
What happened to the beautiful light in the OP? Don’t like this prototype at all.
DB Custom
DB Custom's picture
Not meant that way Jos, sorry… I was simply saying that I thought Fritz’s design was nailed down and they were going to make it like his plan. Am surprised at all the back and forth on here as much as I am the design change by Lumintop.
It’s still a very nice light, no doubt, just has strayed from the original intent.
ToyKeeper
ToyKeeper's picture
I’m not really in the loop about host design changes. I liked the appearance of Fritz’s original design better, but I’m okay with the slope too.
However, there was a different clip proposed earlier and in some private messages I was pretty loud about disliking it, and now it seems to be back to the original design. Not sure what happened behind the scenes, but maybe I had something to do with that?
Mostly though, I’m just doing firmware.
fritz15
fritz15's picture
Last seen: 1 year 3 months ago
Hi, I received my prototype but did not yet have much time to examine it.
Some thoughts though:
  • Build quality is good, but there are some flaws in mine,
  • It is anodized in the same colour
  • I am also not 100% happy with the design. Currently it looks a little mixed up. Either there should be two chamfered parts or two sharp parts. We might make a small adjustment there,
  • The switching operation feels weird somehow. The driver responds with some delay for some reason,
  • The tailcap is glued to the body,
  • A transparent rubber ring prevents the clip from rotating, which is quite clever. I first want to have a look at the disassembled switch though before I make my final judgement,
  • It is very small and compact and the clip is really really good.
Some more information will follow shortly
ToyKeeper
ToyKeeper's picture
BTW, someone asked about dimensions, and someone asked about putting the FW3A next to a BLF A6 shorty.
FW3A proto1 dimensions:
  • Length: 92.9 mm
  • Bezel diameter: 25.6 mm
  • Tailcap narrowest diameter: 24.0 mm
  • Body narrowest diameter: 21.5 mm
I don’t have a BLF A6 shorty, but I have a Convoy S2+ shorty… pretty close.
Convoy S2+ 18350 dimensions:
  • Length: 85.9 mm
  • Diameter: 22.9 to 23.9 mm
So the full-sized FW3A is about 7 mm longer than a Convoy or BLF A6 “shorty”… and its grippable section is 2.4 mm narrower so it feels smaller. The FW3A head is 1.7 mm wider, which allows the entire optic to be exposed instead of having the edges blocked. A glass lens protects and holds in the optic.
The sizes are actually pretty close. The FW3A is almost shorty-sized, but has 3×-5X as much battery capacity.
It’s also shorter (and lighter) than both of my Brass Beauty lights, which are two of my favorites…
Brass Beauty v1 dimensions:
  • Length: 97.3 mm
  • Diameter: 19.7 to 21.1 mm
Brass Beauty v3 dimensions:
  • Length: 102.4 mm
  • Diameter: 19.5 to 21.7 mm
Firelight2
Tailcap is glued?
That doesn’t sound good. Looking at the design of the light, removing the tailcap is necessary to remove the clip. Does that mean we’re stuck with the stock clip and can never remove it or replace it unless we somehow break the glue?
joechina
Thanks Fritz15 for answering here.
What about two chamfers like on a Lumintop Tool AAA? 45 deg. The step down is also 1.5mm
Tixx
Last seen: 9 hours 29 min ago
Yes, I like to have the 18350 option.
Tixx
  • Length: 92.9 mm
Almost same size as a Zebralight s64! Not much larger at all
Dimensions
Head Diameter: 0.96 inch (24.5 mm) Length: 3.64 inch (92.5 mm)
g_sintornillos
g_sintornillos's picture
Last seen: 13 hours 33 min ago
Tailcap is glued?
+1
I do not like that
Please no glue
Sorry for my bad English (gogole transtorla)
Bruno28
Last seen: 1 month 1 week ago
I would like to be on the list please.
DB Custom
DB Custom's picture
Agree with the 45º step down to the tube on the Tool, I have all 3 versions (Brass, Copper and Titanium) and they did the 45º bevel on the step down to the tube on all of them and it looks nice, doesn’t take away from the clean lines and virtually eliminates snagging.
(Finding a picture online, this from outdoornerd, was easier than snapping a pic and uploading it)
Dman7777
Dman7777's picture
Its funny how people have completely opposite ideas about the aesthetics of the old and new design.
I personally think the new design is a huge improvement.
I was not too crazy about the original, but functionally it sounded really cool. In my opinion the new design is much much better.
I dont like the luminitop Tool design at all, to me it just looks incredibly low effort and unimaginative. I have seen nicer looking spark plugs.
shirnask
shirnask's picture
Last seen: 9 min 32 sec ago
Yes I have a completely opposite view of this than you do
Trevi_lux
Trevi_lux's picture
The first design is original (at least for me). The new design remember me the Nitecore Concept, remember the HDS lights…..I not find the new design as improvement. Of course I like the Technical qualities, the interface, the switch…. but is a shame lost the original design.
Zulumoose
Zulumoose's picture
Agree 100%
Beam me up!
legopacific
Last seen: 1 month 6 days ago
Please add me to the interest list. (Better late than never.)
ToyKeeper
ToyKeeper's picture
Nobody is late yet. Development isn’t finished, and it won’t be available until sometime next year.
pepinfaxera
Last seen: 11 min 22 sec ago
I like the original design better as well, but I will still order this tapered version.
(google translator) , (https://www.deepl.com/translator)
ZozzV6
ZozzV6's picture
Last seen: 1 hour 27 min ago
I don’t know. I like both versions but the new tapered maybe will be better if it has a 45degree bevel at the tailcap too like Dale said and showed on Lumintop TOOL.
ToyKeeper
ToyKeeper's picture
I’ve already managed to mess up my prototype a little. I replaced the 1×7135 chip with a different brand to see if it’d help, and it seems to have made the driver stick out a little so now I can’t thread the thing together quite as far. It still works, but I’ll have to fix it next time I take out the driver.
OTOH, I greatly improved the button debouncing. It’s not 100% yet, but it’s at least like 90% now.
Regardless of how the tapered section works out, whether it’s 5 degrees or 45 degrees or 90 degrees, the narrow middle area makes the light much more comfortable to hold. It fits comfortably between any two fingers, which isn’t something I can say for most of my 18650 lights.
This prototype has the wrong emitters (XP-G2), and there are some thin wires, and my main contact points are weak at the moment due to the replaced chip not fitting quite right, and my battery wasn’t full, but I did some quick output tests…
  • Moon: 0.24 lm (after swapping 1×7135 chip)
  • 1×7135: 160 lm
  • 8×7135: 1063 lm (highest regulated level)
  • FET: 2160 lm
The real thing should go significantly higher (though keep in mind the high modes are basically burst only, not for sustained use).
