The NEW Sofirn C8F Triple XP-L W2 w/side e-switch
287 posts / 0 new
Gerrit
Last seen: 40 min 36 sec ago
As always a great and detailed review Dale, ordered one at Ali. Thumbs Up
Caleb
Caleb's picture
Last seen: 11 hours 19 min ago
Thanks for the review!
Lightbringer
Lightbringer's picture
Last seen: 17 min 11 sec ago
Damn. Code’s limited to one-per-customer?
JasonWW
JasonWW's picture
Last seen: 16 hours 11 min ago
Hmmm, that UI sounds like a pain. Couldn’t they make it one click on/off, press and hold to cycle through the brightness settings? Dbl click for turbo. Have memory stay on all the time.
It still looks like a good host for a TA fet driver, though. Wire up the switch leds so you know when the tail cap is tight or loose. It might give my modded supfire a run for its money.
Delta_V
Last seen: 4 months 1 day ago
Agreed. That’s basically what Zebralight, Olight, and Armytek all use on their e-switch lights – some variation of click-on, hold to switch modes, click to turn off. This click on, hold to turn off UI that is so common in budget lights is annoying in comparison.
Would also like to see how this does with XP-L HI emitters – should give it a little more throw, and the HI emitter just gives a nicer beam IMO.
DB Custom
DB Custom's picture
Last seen: 6 hours 3 min ago
The HI emitter really needs the reflector tailored to it, without special attention to it’s placement the beam can have some ugly colorations and not give a nice beam at all. I’ve had my own ups and downs with the HI, find it works decently behind optics but can be a real bear to get perfect in a great many reflectors.
So, let me get this straight… y’all expect an entry level company to come in with UI’s like the high dollar proprietary firms? Interesting. $80 lights for $30 huh? And this is realistic, how?
I’ve dealt with hundreds of lights, and I suppose you wouldn’t guess that some of those named lights are my least favorite. ZebraLight I’ve never bought, I do have one, never use it as it’s UI is freakishly weird to me. (You know that’s a personal opinion, right?) Armytek, well, they’re the only major brand name light that has ever taken MY PHOTO’s and used them in their Facebook ad without asking. Also have a weird UI that frustrates me every time I try to use the one headlamp of theirs I have. And while I do like Olights, they tend to be somewhat stuck on their designs and are proprietarily overpriced for the most part. I have seem them doing some amazing things to help a “family” member and they’ve given some nice discounts in the past few months so I can’t complain about em too much. The last one I got though, I pulled their emitter and changed it within a couple of hours of receipt.
All to one’s personal taste, of course, but for me the major players make major mistakes in their UI. But that’s only my own personal finding after dealing with some 5 or 600 lights…. My own memory issues directly influence the UI preference I choose, so of course that is my own opinion and everyone else has theirs. (I can say this kind of thing in my own thread, right? Wink )
JasonWW
JasonWW's picture
Sure! It’s just software coding, right? Easy as pie! Party
Much easier than Narsil or biscotti, etc…
Delta_V
Fair enough on the reflector issue. My personal preference in a light this size is that I would gladly trade a few hundred lumen for extra throw. But I understand it might not be as simple as an emitter swap if you want the best results.
But on the UI, it’s not about how fancy or complex it is. I don’t need or expect the programmable functions offered by Zebralight or Armytek, and all of their shortcuts can be excessive and more cumbersome than it’s worth. I’m actually reasonably impressed with the mode groups offered here. My issue is the simple control mapping.
All e-switches register the same inputs – click, long press, double click, etc. The difference is what they do with those inputs. Do they have “long press” mapped to “change modes” and “single click” to “turn off”, or do they have it the other way around? That is not a difference of complexity, it is just a design choice, and I happen to think the first way is much easier to use. It’s more intuitive to turn off and makes it harder to accidentally register a double click when switching mode groups. When you click to change modes instead of long press, it is too easy to double click. At least here you don’t have to worry about activating strobe I guess. But you are still liable to accidentally activate Turbo.
It’s not a deal breaker, and this otherwise seems like a very nice light, especially at this price. It’s nice to see some competition for Convoy. It’s just the UI is something that I feel could have been made better without adding cost or complexity. It’s like my UTorch UT01 – I carry it every day because I like the tint, brightness, mode spacing, and compact design. But the UI still annoys me because a few simple changes could have made it almost perfect.
Again, excellent light for the price, the UI has just become a bit of a pet peeve for me lately because so many e-switch lights seem to make questionable UI choices.
DB Custom
DB Custom's picture
I think it boils down to utilizing the personnel you have on your staff. A new company wants to build their own product, using their own engineers and inputs. So a lot of the times these engineers will purposely steer clear of other companies known works. They want to be known for what they can do, not how well they can implement other’s works. Many times it’s a pride point, to stand on their own merits and not on someone else’s.
Sofirn is proud of their accomplishments with the 4 mode groups, and I think it’s justly so, as a new company breaking into a complex and comparatively limited world… they’re doing great work. If you think about all the flashlights that are out there, imagine how difficult it is to design something new. They took a legend, the C8, and improved it as a factory offering. From the well done aluminum reflector to the factory spring bypasses, they’re impressing with their efforts.
I say Kudo’s to Sofirn on a job well done! Smile
Lightbringer
They’re kicking buttocks.
DB Custom
DB Custom's picture
hahaha, you might could say that.
First factory C8 I’ve ever seen make 3000 lumens out of the box.
AND they even went to the trouble of sourcing a cell that will do it, and supply it with the light, as well as a charger. They’re motivated!
Lightbringer
Now ya know why I wanted more’n one…
vwpieces
vwpieces's picture
Last seen: 3 days 58 min ago
I think my new ver C8F is a pretty well done light. Sofirn was quick to address All the issues from the first version.
Working on getting the side SW LEDs wired up. Wish Sofirn would have connected them from the factory since they are already there.
Did 20AWG on the MCPCB and driver spring but the gosh darn SW retianing ring is locked up hard. First time my two starter punches in hand method let me down. Guess its time for a good retaining ring pliers.
Supposedly a host will be available soon with MCPCB. No emitters or driver.
DB Custom
DB Custom's picture
Got my switch retaining ring off today, it came loose relatively easy with 5” curved jaw hemostats but then seemed to lock up before it was out, I started it back down then unscrewed it with my fingers and it came right on out. Went back in easily.
I’m still trying to figure out why the switch pcb has emitters and resistors on board if they weren’t going to be enabled? Maybe they are still revising it…
DB Custom
DB Custom's picture
Just dawned on me what you said vw, as a host needing emitters and driver I can imagine Anduril pushing 3 XP-L2’s…. wow! I sliced and diced an XP-L2 in my D1S and it’s doing 2000 lumens, so could 3 be doing 5000? More? Interesting indeed!
vwpieces
vwpieces's picture
Yes, I want hosts!!
I think ZozzV6 got in touch w/ SF in IMA4W review. I did just check SF Ali store and nothing listed yet.
Did you utilize the Side SW LEDs? it has the same SW board as the Q8 with green LEDs installed. I changed mine out to white but my lights still on the bench apart. The SW button is translucent black, looks neat lit up.
Man Without Shadow
Man Without Shadow's picture
Last seen: 1 hour 14 min ago
Could you describe, post pictures or show a link on how to enable the switch LED’s?
Thanks!
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
vwpieces
vwpieces's picture
Thanks!
its easy, there is an empty pad on back of the SW board. Ad a wire there and solder it to the red wire for emitter on the driver.
Man Without Shadow
Ima noob…I would need a picture of that…
JasonWW
JasonWW's picture
I thought the flashlight business was all about copying what works and selling a lot of them. You don’t want to turn folks away with a weird UI that is only weird for the sake of being weird.
They did copy the basic C8 body so they should just make the light easy to use. You will sell more units in the end.
JasonWW
JasonWW's picture
One of those red wires goes to the emitter and is hot all the time (at battery voltage). You just add an extra wire there and then solder the other end to the extra pad on the back of the switch pcb. This is assuming the leds are wired into the switch ground already on the switch PCB.
khas
Last seen: 1 month 4 weeks ago
Great review Dale Thumbs Up
I have one of the “old” model C8F and I think the XP-L HI emitters gives it a much better beam. I don’t have two C8F’s but here is a comparison between a UniqueFire UF-1408 and a C8F :
UniqueFire UF-1408 XM-L2 (left) C8F XP-L HI(right)
Maybe it’s not a completely fair comparison but I think it illustrates the difference quite well.
The picture below is two identical Q8’s one with XP-L HI and one with XP-L HD
Q8 XP-L HD (left) Q8 XP-L HI(right)
sovereignknight
sovereignknight's picture
Damn bright! But the run time @ 10 amps from a 3000mAh cell has to be awful.
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x2 Sk68 modded 1 Nichia 319AT, 1 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, w/ Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x2 Lumintop Tool AA - x1  x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - x1 Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light - x1 Lumintop Zoom 1 - x2 Zebralight Sc700d - x2 Lumintop Tool AA 2.0 Ti - x1 Olight I3T EOS
Majoroverkill
Majoroverkill's picture
Last seen: 3 weeks 4 days ago
Just great. another flashlight I have to buy now Facepalm Big Smile Very nice specs!
Doug S.
JasonWW
JasonWW's picture
The key is to use the turbo only in bursts and to use the lower levels for longer times. It would be nice to see this light with a 26650 tube. Then you would have a high drain 5,000mah battery.
sovereignknight
I agree. 26650 would be better for sure.
Flashlights:
NikolaS
NikolaS's picture
Last seen: 1 month 1 week ago
With C8 body, hardly possible, but 20700 might be best solution ! High drain 4250mah
JasonWW
JasonWW's picture
No, what I meant was keep the C8 head diameter, just make the body the same size. There is a lack of 26650 sized lights with triple reflector setup and side switch.
KawiBoy1428
KawiBoy1428's picture
Last seen: 6 hours 21 min ago
Nice review Dale and great pics! I got my version last week and put a D4 V2 driver in it. Had to alter the lighted e-switch switch, it was making the driver do silly things! Facepalm
Great light, love the ramping!
KB1428 “Live Life WOT
ImA4Wheelr
Nice review.  Good catch on the cell.  That explains its performance and low internal resistance in my review.
