The NEW Sofirn C8F Triple XP-L W2 w/side e-switch
Thank you Tracy. Much appreciated. :wink:
Doug, It handles the heat surprisingly well. The MCPCB is a large copper DTP, I confirmed that it is in fact Direct Thermal Path, and the shelf is pretty thick under this piece. The head has proper fins and also has the mass of the 3 protrubences that make the C8 what it is. Sure, it’ll warm up given some run time on Turbo, but it takes a bit longer than I would have thought.
The top cell I’ve found is the Sony VTC5A, other cells won’t push it as hard and so the heat and run time will of course be affected in a positive way with a lower discharge capability and higher capacity. Like with our FET drivers, it’s pretty easy to control the parameters by proper cell choice. :wink:
Sounds great to me :slight_smile: I am going to purchase one when I am able to. Just got done buying the BLF GT, Emisar D4 and accessories along with the Nitecore Tube and 4 sets of batteries. The Mrs is not real happy with me right now :person_facepalming: :stuck_out_tongue: Great job by the way! Amazing output in such a small package. I like the fact that it will run a bit longer in turbo then just burst modes. I have a old Ebay Trustfire with a three emitter lens and a three 18650 tube that I want to mod. A 9V driver and three XLamp® XM-L2 Gen 2 Emitters should really make this flashlight shine.
You might want to consider the Luminus SST-40, it can make a lot more lumens than the XM-L2 and fits the same footprint. The only ones commonly available now though have a blue-white output, not really bad but noticeable. Lumens is fantastic though!
Thank you for the info! I’ll look and see if Digi-Key has them in stock.
I’ve had my Supfire M6 running at close to 5000 lumens for quite a while now, triple XM-L2. I swapped in 3 SST-40’s and it now makes 8866 lumens. Seriously, an emitter swap!
The only way I know how to check is the usual way, by accident, but I’m really good at checking that way. :cry:
Thanks, I don’t know if that’s good or bad either, but it looks like it’s fairly low?
Nice!
That is the 2 milliamp setting. There are 1000 micro amps in a milliamp (had to look up because this stuff is hard to remember, lol). 1 milliamp is pretty high drain. The Q8 has 125 micro amps drain and it is perfectly fine, very low. This shows 9 microamps which is super low. I don’t even know how the mcu can be running on that even in its sleep mode. (It has to be partially running so it can detect a signal from the switch and turn itself on)
That sounds awesome to me at any kelvin :sunglasses: Were could one fine those emitters available, SST-40.
Kaidomain has them: http://www.kaidomain.com/p/S026881.Luminus-SST-40-N4-BA-White-6500K-LED-Emitter
I just made a triple with them: Mod: Olight SR Mini with triple SST-40 and host bypass. Three of them in a reflector light like this is very enticing indeed :stuck_out_tongue:
3-SST-40 are pretty Shocking coming out of a MMU X3 specially if your on the receiving end! The 21700 hits at 24-25amps and with the FETDD SIR800 guppydrv.program on Turbo/Strobe….it makes for a
Fist full of Lightning coming out of this thing! :smiley:
I have a Convoy Triple SST-40 Optic it is bright but nothing like whats coming out of a triple reflector light! :wink: Kaidomain has the even higher kelvin 7500k’s I just might swap out the 6500k’s for when I get the time….
Maybe Sofirn can come out with a XM triple board for the C8F too! :+1:
I have to say I’m impressed with Sofirn too, this is one of the most interesting lights out there. And also, well done. Not so long ago they had good light, but they were willing to make a number of big changes to improve it.
Now if they ported one of BLF ramping UIs to their driver…. I view ramping as the proper way of using e-switch and overall I think our UIs are simply very well done.
Yep ramping is great for e-switch lights, I like Narsil Lexel built T/A drivers in Big lights. But the D4V2 and the Q8 double click to Turbo has a lag/ hesitation going into Turbo, the Lexel built T/A Narsil drivers are instantaneous.
:smiley: Turbo lag in a flashlight! :stuck_out_tongue:
Hahaa I know I’m more of a NOS guy myself! :smiley: :+1:
I like both turbo and big displacement NA engines :smiley:
I’ve had a little boy racer, ford escort cosworth with the engine and turbo tuned up to about 500 hp. I really loved the noise of the turbo spooling up during slight lag and then the kick and the ass when it got up to speed… but turbo lag in a light? Nah, I think I’ll pass on that :slight_smile:
Sorry for offtopic again! I like old fords :wink: I had 4 sierras, two Scorpios. One scorpio still mine. 2.9 V6 estate.
The escort cosworth basically a shortened sierra cosworth with escort body. And now I have a Volvo S70 T5 turbo with the scorpio. Oh that 5 cilynder sound with BOW. …
