Saw the 15A protected. Kinda wonder on that if its just a burst delay or full current before protection. Full 15A sorta defeats the purpose of a protection circuit. I don’t know.
Just measured the tube of my recent L6, 26.85mm at both ends. Would definitely need to be smaller than that.
Not really. The protection circuit protects against 5 things:
1. Over voltage
2. Under voltage
3. Over temperature
4. Short circuit
5. Over discharge
Most people only get protected cells for the first few reasons. The discharge limit is sometimes an aggravation that’s it too low. It prevents people who want a protected cell from being able to use a high current light. Like the Emissar D4 at 11 to 12 amps for example. With this battery they can get the 4 other safety features and still have turbo. It sounds good to me.
Texas Ace Lumen Tube calibrated with Maukka lights
I had a clear L6 I modded and sold, and the batteries I still have fit tighter in my new Black L6. Black litto need the tube off and pushed through to get out. Not tight enough to hurt the battery at all, but the air can’t pass to allow them to fall out even with a bump. I can see just the addition of the metal strip up the side of a protected cell making them too tight. My black Keeps are just slightly looser.
Didn;t know the tubes got smaller, I initially just thought it was the difference in the black compared to clear anno thickness at first. But I did notice the difference.
Maybe that is why the L6 has had good coupon deals lately for $45? I just bought another black NW this morning.
It was around April of this year that certain batteries seemed to grow in diameter and the L6 tube got a tiny bit smaller. So people started measuring. Some were tubes were 26.79mm and some were 27.12mm. A lot of variations.
Do you imply that KP protected the Shockli cell, hence the 4mm length difference? And by the way are Shockli rebranding cell from a big name or are they doing their own stuff?
wow that 6000mah cell KP looks interesting its gonna cost alot i bet just 1 battery, i hope Nkon will bring that in.. they never seem to even have the other 5200mah battery in stock i hope my L6 arrives soon im anxious to get this badboy before holidays hopefully unless shipping screws up…
My l6 came today from gearbest after almost 1 month of travel. Its an amazing flashlight it feels so well built for the price its crazy nothing remote what i can think of comes close. I am using the efest 4200mah batteries they work perfect u can see on the pic there is some space left i was worried they wouldnt fit maybe but they do. Happy to own a few lights from convoy and now the l6 in hand
Make sure the reflector is screwed down snugly so you get good heat transfer from the mcpcb to the body. If not the led output could shift to blue very quickly and burn up.
but would the KP 6000 even fit l6, i asume they are the same as the 5200 dimensions? i agree its hard to even find the kp 5200, i have been checking nkon from time to time no luck, just says out of stock all the time not even a date or anything when to expect them there…
I’ve forgotten what the diameter limit was on the L6. 26.8mm doesn’t sound like an issue, though.
Wow, they show to have protected 18650 cells with a 15A ability.
Click this to go to signature links.
IMO KP 6000mA = Shockli IMR26650 .
Shockli IMR26650 5500mAh (Black) 2017
http://lygte-info.dk/review/batteries2012/Shockli%20IMR26650%205500mAh%2...
View BLF with NO Commercials Here!
The link doesn’t work.
Are you referring to that reddit post where they suspected the KP 6000 as being the same as the Shockli 5500?
1. Over voltage
2. Under voltage
3. Over temperature
4. Short circuit
5. Over discharge
I measured mine on both ends and got 26.99mm. It’s an earlier version, though.
I remember reading that some of the newer batches of L6 battery tubes were a bit smaller in diameter than normal. I wonder if you have one of those?
I think about here or the page before is a good starting point if you want to read about it.
http://budgetlightforum.com/node/43503?page=133
Rise and Shine my precious...
I have seen a source, but don’t have it at hand. ICRs are old tech now.
Recent Reviews:
XTAR DRAGON VP4 Plus Zanflare S2
Klarus XT2CR BLF Q8 Convoy S2+ DT
Nitecore P10GT Klarus XT11GT
Nitecore NU25 Nitecore HC65 Nitecore P26
Yongnuo YN360 Convoy C8+ Klarus FX10
Nitecore MT22C Folomov 18650S
FW3A Strobes
The L6 is at $46 in this coupons & deals thread:
http://budgetlightforum.com/node/57247
Nah, it’s just the holiday season. There’s tons of sales going on.
...where Frugal meets with Flashlight!
There it is again: L6 for $45 in this thread:
http://budgetlightforum.com/node/52547
You will run into problems if you use protected cells that are longer than 70mm. You’re way safe.
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x6 Sk68 modded 3 Nichia 319AT, 3 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, w/ Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x6 Lumintop Tool AA - x1 x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light - x1 Lumintop Zoom 1 - x2 Zebralight Sc700d
I posted this on the mod thread but here’s what I did to my L6 last night.
Driver is from MTN with D4 ramping. Got the led from KD.
Getting just over 15A from the tail with the new setup vs 7A with the old led with resistor mod.
L6 uses screws to hold down the mcpcb
- George
My Reviews : KDlight C8 / ThruNite Archer 1A V3 / Thorfire C8s / ThruNite TN12 (2016) / Utorch UT01 / Utorch UT02 / Jetbeam WL-S2 (xp-l) / ThruNite TC12 V2 / Massdrop Brass AAA / Manker LAD / Lumintop SD26 / ThruNite Mini TN30 (3x xm-l2) / Qualilite D81 / Nitecore MH20GT / Odepro TM30 / Klarus XT30R / Nitecore NU20 CRI / Ultrafire XM-L2 / Foursevens Mini MK II / Manker E02 / Manker E14 II / Teekland Flashlights / Lumintop Elfin / Thorfire S70S / ThruNite Neutron 2C / Jaxman M8 / KDLITKER C8.2 / Zanflare F1 / Nitecore Concept 1 / Emisar D4 / Astrolux MF-01 / ThruNite TC10 V3 / Amutorch JM70 (xpl hi)
No it doesnt. It has either one or 2 screws to prevent rotation. The reflector is what pushes it down.
I thought all of them had 2 screws like mine … Interesting . Bought mine from BG
- George
Yup that’s right. The screws is just to prevent rotation.
Amazing output with the 70.2! Quite happy with the tint as well.
Hi anybody have a good protected battery sugestion for the L6? Keppower sems to be inpossible to get today.
Micael
Texas_Ace BLF Calibrated Lumen tube
Have you tried https://www.illumn.com/
They are out of stock there.
There definitely seems to be a shortage of protected 26650 cells right now.
I’m wondering if KeepPowers 5200 is being replaced by their new 6000 model? Can you buy them directly from Keeppower?
http://www.keeppower.com.cn/products_detail.php?id=571
Have you considered this one?
https://www.orbtronic.com/protected-26650-li-ion-battery-5200mah-orbtronic
Mtn Electronic has some protected Evva 5200 cells, but they a bit long. You can make the longer cells work by unscrewing the battery tube from the head a couple of turns. I did this when I ran the long KeepPower cells.
http://www.mtnelectronics.com/index.php?route=product/category&path=59_108
Are you in Sweden? I don’t think MtnE ships overseas anymore.
Thanks for the help but not in stock. Yes I’m in Sweden that dont help
I found thes at Nkon Enerpower 26650 4800mAh (protected) – 12A.
Thanks for the help.
Micael
I just checked the Chinese website and see they have them listed! I’d like to get a few
found a shop in finland from KP distributors link,, the new KP 6000 but damn 25euro for 1 piece
too expensive….
https://www.akkula.fi/epages/akkula.sf/en_GB/?ObjectPath=/Shops/20110228...
