I think I can live with this
the question is if a 8.5mm high inductor fits the head or if I have to take a smaller one
P.S.
Design got improved
MF02 measured 8.3mm for parts height so the 7.5mm inductor will fit
P.S.
Design got improved
Interested
Will you add this board on your boards page after you test it ? And parts list if possible!
I will order those boards not from Oshpark so witch 30 boards on the batch I should get down to about 2$ per PCB
When I sold the batch I will make em public including mouser parts list
Hmm , if you order 30 and are cheap as you mention , maybe i can get 2 pcbs from you ?
Parts ordered for 30 drivers
final design
Interested
OP changed to sale topic
Price is 22$ plus shipping
PM sent to all that replied in this topic
parts and boards for 30 drivers ordered
(10% extra parts for tests and maybe 3 boards from Oshpark)
I also added the 2x2 LED boards to the Seed order,
so if you like different colors or just more even lighted switch you can take one as well
I got SMD LEDs in different colors
CW, NW, green, emerald green, yellow, orange, red, blue, ice blue and pink
take one
lol just realized my calculation was missing the MCUs
price 1$ increased
Hi Lexel. I guess you received my payment for two drivers, just cant see my name on your spread sheet. I slipped you a couple of dollars extra so all should be good here.
Had not much time today to update the picture, wiil do now
Please add me for 2 driver’s for MF02
Interested
Nice stuff. :+1:
I have no use for it though, unless it could output 6Volts on 3S battery config.
Must say though, those traces on the Sinkpad 12V XHP boards sure look flimsy.
The driver should do fine with 3S to 6V, but its current is with 6A Inductor nowhere near DD drivers,
maybe crank it up to 8A or so ask DEL what the inductor and Diode can do and if the capacitors need to be changed
I also worked on TN42 size
Got today some stuff in a Mouser parcel for TA and GT drivers
Just a little comparison from BLF MF02 Inductor with stock driver ones
could do this basically to all components of the Buck regulators current parts
O that’s interesting.
6 Amperes is enough for me, i’m thinking XHP50.2 with a 68mm 10° TIR in a Courui, but it has to be 34mm or less in diameter…
yeah for 6A I need to stack a 2. shottky diode
I asked DEL if more or other caps needed
What a big difference. I didn’t know what I was meant to be looking at for a second.
