New multi-function bike light from Xanes is now in preorder for $13.59 (limited to 150pcs), then the price will gradually rise and target price is supposedly set at $20.99.
This is 3 in 1 device (bike light, lantern and power bank) that doesn’t look half bad
It has 2 x 18650 cells built in (total 4000mAh), claims to deliver 1000lm. COB LED on top serves as lantern - there’s foldable hook on the back and two magnets to affix the lamp to any metal surface. On the bottom side standard USB socket is located to charge any USB rechargeable device.
Use coupon code SHH03F to lower the price from $57.95(CW)/$58.95(NW) to $38.99 (-$19.96/-$18.96)
Both cool white and neutral white versions available in stock.
Use coupon code SHH03R to lower the price from $52.90(CW)/$53.90(NW) to $35.99 (-$16.91/-$17.91)
Use coupon code YRLTT to get nice 39% discount (-$23.38).
The difference from factory Lumintop Tool Ti is the custom Rey driver. It has Low -> Medium -> High mode order and better efficiency (stock Lumintop driver is M>L>H).
This is tried design based on prevalent C8 host with XP-L HI LED (1A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
Light output is claimed to be 600lm in high mode (3,5h runtime), 4 modes in total (high, med 300lm, flash, slow flash) and is equipped with light sensor for auto operation(can be enabled/disabled). Reviews are quite good as well.
I don’t suppose so, sorry. There is in fact 219B in product title but I believe this is mistake.
I use here product titles directly from BG product pages that’s the reason 219B is mentioned as well.
I believe 219C is used here because it can handle higher current and the tint difference is not that significant between the two.
It’s now in promo sale for $80.14$49.69 until December 31st.
This is second (upgraded) version of Xiaomi bedside lamp. It now uses RGBW LEDs - White ones are Osram LEDs with CRI up to 95.
Second version has gold colored base and now it can communicate also via Wifi (first version was Bluetooth only) and can be paired with MI Home and controlled via voice commands and automatic events (for example light color can indicate room temperature etc.)
Please note that the tints are not specified for both LED types so this may not be the case in the future as different LED batches can have different tints…
